Full Version: [RELEASE] ustvnow
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
(2014-07-06, 22:54)dmdsoftware Wrote: [ -> ]
(2014-07-06, 21:11)Jutje Wrote: [ -> ]
(2014-07-05, 04:11)dmdsoftware Wrote: [ -> ]I created my own fork that tries to resolve some of the Raspberry Pi issues.
https://github.com/ddurdle/XBMC-ustvnow/...master.zip
First of all thank you 4 your work.
The Link you post it does not work
sorry, fixed https://github.com/ddurdle/XBMC-ustvnow/...master.zip
Hi dmdsoftware,
I have a problem it does not work for me. I do not see any image appearing.
Does anyone have problem running USTVNOW on Gotham 13.1?
I just updated to Gotham 13.1 and my USTVNow plug in has stopped working.
I have a paid account.
Running a new Win7 install.
I will upload a log if someone can tell me where to find it.
This release, 0.4.1, adds two parameters to your settings file.
1) Run in Kiosk Mode
Immediately when you start the video addon, it will start playback. To return to the traditional "live and recordings" screen, hit back, then Yes on exit prompt.
2) Take over controls
To change channels in this mode, press UP and DOWN (not channel up or down, action up and down). To view the station information and title of show, hit OK or SELECT. hit again to hide.
If playback stops, the stream will attempt to resume. Hitting back is overidden, so it won't freeze your Raspberry Pi like it used to.
If your stream starts to act up, you can hit STOP and it will stop and will attempt to resume again.
Fast forward & Rewind are disabled.
If you disable both 1 and 2 in settings, the plugin will act like it used to. If you disable 1, the plugin will start at at the "live and recordings" screen.
Naturally, this plugin will work with any XBMC, not just the Raspberry Pi.
Please test, provide feedback, and request features.
This sounds great but unfortunately the kiosk mode hung RaspBMC on my Pi. I'm back to version 0.3.4 from xbmchub.com.
I reverted back to xbmc v12.3 and deleted and reinstalled it still doesn't work.
Going to try 12.2 today.
I received an email today asking me to sign up at [link deleted], among other things it states "Register today at [link deleted] and stay up to date with the best in streaming quality from anywhere in the world! USTVNow will be closing and registrations at ZoomCast will not be open for long. "
I haven't been able to log onto ustvnow to check there. I have searched here and google and nothing comes up.
Anyone heard anything, or is this a scam?
(2014-08-13, 12:40)denzo Wrote: [ -> ]I received an email today asking me to sign
It's spam for illegal services, you should remove the links... otherwise someone might confuse your post as spam.
Is there any possibility of adding an epg type listing to this addon? The information is on the website... is it something that would be difficult to scrape? (without having to use PseudoTV)
(2014-07-14, 23:07)Jutje Wrote: [ -> ]
(2014-07-06, 21:11)Jutje Wrote: [ -> ]First of all thank you 4 your work.
Hi dmdsoftware,
I worked through some traces with others who were having the same problem with the normal addon or my addon. What I saw, the users who have their USTVNOW linked to facebook (created their account using the "use facebook login") have an issue with the iphone login that the XBMC addon uses. There is no token returned during the log on, and all the channels show up, but you are not able to play them back, because you are not logged in. Everyone who contacted me who had the problem all had their accounts linked using Facebook, and all the accounts I got confirmation work, none of them reported having their accounts linked.
The plugin could be updated to use a different login method, but anyone with the issue would be better off registering a second account that isn't linked to facebook.
I had to log in on a browser, click on a channel link to play. A dialog came up asking to verify my account, I entered my id and password again. The addon started working again after that.
All of a sudden USTVNOW will NOT play any feeds within xbmc gotham 13.2 windows 7. Anyone else having this issue?
log details - my email/api key has been excluded and replaced with $$$$
23:08:28 T:4484 NOTICE: -->Python Interpreter Initialized<--
23:08:28 T:3148 NOTICE: Thread BackgroundLoader start, auto delete: false
23:08:29 T:4472 NOTICE: Thread LanguageInvoker start, auto delete: false
23:08:29 T:4472 NOTICE: -->Python Interpreter Initialized<--
23:08:29 T:4472 NOTICE: PHPSESSID: 25e8ovr5og3r0au53je11gfqv4
23:08:29 T:4472 NOTICE: token: sqiewxcarh5lopoymlus
23:08:29 T:1900 NOTICE: Thread BackgroundLoader start, auto delete: false
23:08:32 T:3160 NOTICE: DVDPlayer: Opening: rtsp://lv7.ustvnow.com:1935/dvrtest?key=$$$$$$$$$$$$$8E44A88E42AC9E35E8885B72CBCD/mp4:16A0DWHTMUSTVNOW1
23:08:32 T:3160 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
23:08:32 T:2324 NOTICE: Thread DVDPlayer start, auto delete: false
23:08:32 T:2324 NOTICE: Creating InputStream
23:08:32 T:2324 NOTICE: Creating Demuxer
23:08:32 T:2324 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
23:08:32 T:2324 NOTICE: CDVDPlayer::OnExit()
23:08:32 T:2324 NOTICE: CDVDPlayer::OnExit() deleting input stream
23:08:32 T:3160 ERROR: Playlist Player: skipping unplayable item: 0, path [rtsp://lv7.ustvnow.com:1935/dvrtest?key=$$$$$$$$$$$$$8E44A88E42AC9E35E8885B72CBCD/mp4:16A0DWHTMUSTVNOW1]
23:08:32 T:3960 NOTICE: Thread BackgroundLoader start, auto delete: false
23:08:32 T:3160 NOTICE: CDVDPlayer::CloseFile()
23:08:32 T:3160 NOTICE: DVDPlayer: waiting for threads to exit
23:08:32 T:3160 NOTICE: DVDPlayer: finished waiting
23:08:32 T:4512 NOTICE: PrimeWire: Playback Stopped
23:08:32 T:4512 NOTICE: PrimeWire: Service: Resetting...
23:08:48 T:3160 NOTICE: CJoystick::EnumJoysticksCallback : Enabled Joystick: Controller (XBOX 360 For Windows)
23:08:48 T:3160 NOTICE: CJoystick::EnumJoysticksCallback : Total Axis: 5 Total Hats: 1 Total Buttons: 10
Works ok in xbmc 12.3 vista.
same result on both my winows 7 machines, all of a sudden not working
Fixed, for some reason it was a problem with the livetv pvr backed. when i went into settings and disabled live tv, of which i did not have a backend installed, it now works...strange.
Teach me some tutorials to install this.. Im using android,. Tnx in advance
