@gfisher:
Have a look in LinuxRendererGL.cpp at approx Line 1700. Also look at the Prepare Code.
I see two possibilities, where this can be done:
a) CLinuxRendererGL::UploadXVBATexture
b) CLinuxRendererGL::RenderXVBA
fritsch. Thanks. If I get it working I will report back.
I'm trying to update to 12.9 Quantal driver (following guimxm's guide) but it appears there is an unmet dependency on xorg-video-abi-11 but there is no installation candidate (it says package not available on
http://packages.ubuntu.com/quantal/fglrx). I'm very new to this, any help appreciated
This is the error i get when installing the driver:
dpkg: dependency problems prevent configuration of fglrx:
fglrx depends on xserver-xorg-core (>= 2:1.10.99.901); however:
Version of xserver-xorg-core on system is 2:1.10.4-1ubuntu4.2.
fglrx depends on xorg-video-abi-11 | xorg-video-abi-12 | xorg-video-abi-13; however:
Package xorg-video-abi-11 is not installed.
Package xorg-video-abi-12 is not installed.
Package xorg-video-abi-13 is not installed.
And when i try to install it:
sudo apt-get install xorg-video-abi-11
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package xorg-video-abi-11 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'xorg-video-abi-11' has no installation candidate
@skyhigh12:
Oh man - you are directly installing the fglrx deb you got from this page :-( It is _not_ compatible with precise without rebuilding ... just click three pages back and you see how to do it.
@skyhigh12:
lsb_release -a
uname -a
what do they tell?
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 11.10 - XBMCbuntu
Release: 11.10
Codename: oneiric
Linux xbmc 3.0.0-26-generic-pae #43-Ubuntu SMP Tue Sep 25 17:39:44 UTC 2012 i686 athlon i386 GNU/Linux
Thanks for your help, i'm guessing i've messed something up here!
@skyhigh12:
This won't work on oneiric. The howto was written for Precise. I made that clear with editing the post.
in order to recover, try:
sudo apt-get -f install
fritsch, sorry, my mistake! Thanks again for your help
@skyhigh12: i added a mention to clarify building and installing 12.9 catalyst from Quantal sources is only compatible with Precise
will you pull the pvr api updates for the testing ppa soon ?
@KRA77:
Testing packages have been updated two days ago. Remember those packages are there for testing xvba / vdpau implementation and new patches. Currently there is no need to rebuild the ppa as nothing relevant for this testing has been added. Also there has not been an API bump on mainline since last build.
fritsch
I believe the testing build is on PVR api 1.3 while the master is 1.5 or maybe even higher ?
This is required for some pvr plugins.
