2012-08-06, 23:42
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
2012-09-04, 04:56
Started failing on all content.
03:48:50 T:152944640 NOTICE: CRUNCHYROLL: --> Attempting to log-in with your user account...
03:48:50 T:152944640 NOTICE: CRUNCHYROLL: --> Cookie file doesn't exist; saving new one.
03:48:54 T:152944640 NOTICE: <addinfourl at 158255788 whose fp = <socket._fileobject object at 0x96e546c>>
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> format_fime video_format%3D102%26
03:48:54 T:152944640 NOTICE: -1
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> format_fime video_format%3D106%26
03:48:54 T:152944640 NOTICE: 16967
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> found 106
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> format_fime video_format%3D108%26
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D10%26
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D20%26
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D21%26
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D30%26
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D60%26
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D61%26
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D62%26
03:48:54 T:152944640 NOTICE: 16988
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> found 62
03:48:54 T:152944640 NOTICE: Crunchyroll Takeout -> quality_find video_quality%3D80%26
03:48:54 T:152944640 NOTICE: 62
03:48:54 T:152944640 NOTICE: 106
03:48:54 T:152944640 NOTICE: CRUNCHYROLL: --> Playlist is: http://www.crunchyroll.com/xml/?req=RpcApiVideoPlayer_GetStandardConfig&media_id=594827&video_format=106&video_quality=62&auto_play=1&show_pop_out_controls=1
03:48:54 T:152944640 ERROR: Error Type: <type 'exceptions.AttributeError'>
03:48:54 T:152944640 ERROR: Error Contents: 'NoneType' object has no attribute 'string'
03:48:54 T:152944640 ERROR: Traceback (most recent call last):
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.crunchyroll-takeout/default.py", line 19, in <module>
crunchyrolltakeout.Main()
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_main.py", line 225, in __init__
self.checkMode()
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_main.py", line 242, in checkMode
UI().startVideo()
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_main.py", line 217, in startVideo
CrunchyPlayback().startPlayback(self.main.args.id, self.main.args.page_url, self.main.args.resolutions)
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_video.py", line 166, in startPlayback
player_url = soup.find('default:chromelessplayerurl').string
AttributeError: 'NoneType' object has no attribute 'string'
03:48:54 T:100712448 ERROR: GetDirectory - Error getting plugin://plugin.video.crunchyroll-takeout/?url=None&mode=episode&name=Space+Brothers+-+Episode+21%3A+A+Long-Awaited+Glimpse+of+the+Sky&id=594827&resolutions=12&page_url=http%3A%2F%2Fwww.crunchyroll.com%2Fspace-brothers%2Fepisode-21-a-long-awaited-glimpse-of-the-sky-594827&icon=http%3A%2F%2Fimg1.ak.crunchyroll.com%2Fi%2Fspire2-tmb%2Fdd80cf234295430ac321f74681588b411344545336_full.jpg&plot=With+the+third+exam+finally+over%2C+Furuya+takes+the+opportunity+to+visit+the+man+who+made+his+dream+possible.
03:48:54 T:100712448 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.crunchyroll-takeout/?url=None&mode=episode&name=Space+Brothers+-+Episode+21%3A+A+Long-Awaited+Glimpse+of+the+Sky&id=594827&resolutions=12&page_url=http%3A%2F%2Fwww.crunchyroll.com%2Fspace-brothers%2Fepisode-21-a-long-awaited-glimpse-of-the-sky-594827&icon=http%3A%2F%2Fimg1.ak.crunchyroll.com%2Fi%2Fspire2-tmb%2Fdd80cf234295430ac321f74681588b411344545336_full.jpg&plot=With+the+third+exam+finally+over%2C+Furuya+takes+the+opportunity+to+visit+the+man+who+made+his+dream+possible.) failed
2012-09-05, 19:10
I'm having the same issue Takeout stop working last night. It fails on all videos.
2012-09-07, 13:09
It looks like Crunchyroll has updated the website to block playback at this time.
I am looking into this issue.
Until this is fixed, the plugin is broken.
2012-09-07, 20:35
And I just installed a couple of days ago......................crap
2012-09-08, 05:57
I just pushed a fix so playback works again.
...but since I am faking the Android Plugin ALL playback is in SD.
If I can find a different URL/Header set this may be corrected.
Pre-release videos for Premium members still work.
2012-09-08, 07:17
(2012-09-07, 13:09)yoshiofthewire Wrote: [ -> ]It looks like Crunchyroll has updated the website to block playback at this time.
I found the fix:
When retrieving the config_url you need to retrieve it with a POST and set a variable "current_page" set to the URL of the main page.
Otherwise it replies with a dummy xml file that with a blocked message.
I'm not sure how to fix it in chrunchyroll takeout--but I was able to fix my copy of get-flv with a single line patch.
2012-09-08, 12:23
This change has been pushed in 0.6
Thanks Zehd for your help in resolving this issue the correct way.
All videos playback as before.
EVERYONE should force update the urlXL repo to get this update.
(Don't want to mess up ANOTHER week of SAO)
2012-09-08, 16:55
Incidentally, have you considered wrapping the points where you access Crunchyroll in exception handling that deletes the cache and cookie then tries again?
2012-09-30, 22:25
This seems to freeze my XBMC when trying to access my Queue or anything really. Any info on this? Using the latest builds.
2012-10-01, 11:17
Can you post your XBMC Log file?
I am unaware of any issue.
What build of XBMC are you using?
2012-10-01, 15:25
I actually figured out the problem. I had Sword Art Online in my queue but it wasn't finding it on the site properly. I was getting a 404 error from where crunchyroll was trying to find the anime from. I removed SAO and now it seems to be working ok.
XBMC 11.0 Eden
Not sure if you want me to try to reproduce the error again or not so you can attempt to fix it in case the site gives 404 error for other people. If you do lemme know and I'll see if I can get it to 404 on me again.
XBMC 11.0 Eden
2012-10-01, 16:26
I am unable to reproduce the error.
But there are many issues with shows not showing up in different parts of the app.
This is mainly to do with issues related to the site and how the app pulls show data.
The core of the app is reliant on boxee rss feeds that, if I am honest, I'm surprised haven't been shut down.
Whenever things are inconstant between the rss feeds and the site, things break.
Most notably that is why "I Can Play H" won't show up in the app.
The shows ID is missing from the rss feed.
2012-10-06, 12:45
I am using this plugin on Openelec.tv and all was working fine. Just this morning I updated to openelec 1.99.1 and now Cruncyhroll takeout crashes XBMC whenever it tries to start playback. I have a copy of the XBMC log: http://pastebin.com/HGxpFCmn
Could you look into this for me?
2012-10-07, 12:01
So, having poked around a bit and spoken with the OpenElec developers this issue will be fixed in OpenElec 2.0 RC2. It seems they switched from building the rtmp library against SSL to using GnuTLS instead. This change is reverted in RC2 and everything works again.
