OK, then modify the crunchy_json.py with that diff.
The problem I have no package manager as I use OpenElec and apt-get is disabled. I'll take a look to KODI version.
please add a "start from begining" in settings, so i dont get the do you want to start form the beginning everytime i want to re-watch something
I have a very minor gripe and that is that the images (fanart, poster, thumb) don't all seem to have the proper type. Sometimes fanart is displayed instead of the episode thumbnail and other instances the thumbnail is used instead of the poster. I haven't figured out the specifics, as most skins have different names for the images depending upon the view (icons, cards, etc.) I think following a tv show template would be best.
Hi guys,
First time posting on this forum. Since the latest update, I have not been able to view the Queue by "Episodes". Kodi will simply state there is an error with Crunchyroll and to refer to the logs. How can this be fixed as series view does not attach ticks next to the watched episodes.
Cheers.
Hi!
Im absolutely new in this world. Yesterday i installed the Crunchyroll add-on on my Raspberry Pi 3 (Recalbox with Kodi) everything works nice until i try to play any video. I get the error "ERROR: OpenDemuxStream - Error creating demuxer"
I tried to reproduce that videos with my android, pc, etc... and works, but not in my Raspberry. Any suggestion or idea of what's going on?
Regards!
Hello,
When I try to access my Queue though the Crunchyroll addon, it errors out and throws this error into Kodi.log file.
"11:09:32.301 T:7980 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('playhead',)
File "C:\Users\Tan\AppData\Roaming\Kodi\addons\plugin.video.crunchyroll-takeout\default.py", line 38, in <module>
crunchy_main.main()
File "C:\Users\Tan\AppData\Roaming\Kodi\addons\plugin.video.crunchyroll-takeout\resources\lib\crunchy_main.py", line 367, in main
check_mode(args)
File "C:\Users\Tan\AppData\Roaming\Kodi\addons\plugin.video.crunchyroll-takeout\resources\lib\crunchy_main.py", line 342, in check_mode
crj.queue(args)
File "C:\Users\Tan\AppData\Roaming\Kodi\addons\plugin.video.crunchyroll-takeout\resources\lib\crunchy_json.py", line 865, in queue
'fanart')
File "C:\Users\Tan\AppData\Roaming\Kodi\addons\plugin.video.crunchyroll-takeout\resources\lib\crunchy_json.py", line 752, in list_media_items
else str(media['playhead']))
KeyError: ('playhead',)
-->End of Python script error report<--"
I have verified this across 2 devices. Are there any known fixes for this?
same here. already tried in different OS / devices. thanks to yoshi for the awesome job btw!!!
Can u pls add a "search" feature. Thanks.
Sent from my iPhone
(2017-08-19, 20:20)Haymish Wrote: [ -> ]Hello,
crunchy_main.main()
check_mode(args)
crj.queue(args)
'fanart')
I am having the same exact problem.
Hi All,
I've updated my system ( Archlinux ) and now I've this problem. I'm not sure the problem is related to the update becasue I didn't use Crunchyroll for a long time. Basically as soon as I try to run the add on it fails to start. In the log I've this error :
19:11:44.988 T:140484342900480 NOTICE: CR: Valid auth token was detected. Restarting session.
19:11:44.988 T:140484342900480 NOTICE: CR: makeAPIRequest: get JSON
19:11:44.989 T:140484342900480 NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/start_session.0.json
19:11:44.989 T:140484342900480 NOTICE: CR: makeAPIRequest: options = access_token=QWjz212GspMHH9h&version=2313.8&device_type=com.crunchyroll.iphone&locale=enUS&auth=F4nzEgNwxj%2BG4Q7DfDFOTSWhTcltzct2fQDCb%2Bo4vXyjEsGrlOH1jfDox62SH0w1xqilCje9RPDzNdAV4KIq0SHtwLq8Ruu1s7v5hV67UPY%3D%3APBPRMIUUmlhznVHvrfzRzw%3D%3D&device_id=FFFFofd2-KODI-XS4L-N5WJ-NLB9S56bKCDW
19:11:45.723 T:140484342900480 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'read'
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/default.py", line 38, in <module>
crunchy_main.main()
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_main.py", line 359, in main
if crj.load_pickle(args) is False:
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_json.py", line 188, in load_pickle
current_datetime):
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_json.py", line 316, in _restart_session
args.user_data['auth_expires'] = dateutil.parser.parse(request['data']['expires'])
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/dateutil/parser.py", line 697, in parse
return DEFAULTPARSER.parse(timestr, **kwargs)
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/dateutil/parser.py", line 301, in parse
res = self._parse(timestr, **kwargs)
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/dateutil/parser.py", line 349, in _parse
l = _timelex.split(timestr)
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/dateutil/parser.py", line 143, in split
return list(cls(s))
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/dateutil/parser.py", line 137, in next
token = self.get_token()
File "/var/lib/kodi/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/dateutil/parser.py", line 68, in get_token
nextchar = self.instream.read(1)
AttributeError: 'NoneType' object has no attribute 'read'
19:11:45.777 T:140486248400960 ERROR: GetDirectory - Error getting plugin://plugin.video.crunchyroll-takeout/
19:11:45.778 T:140486248400960 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.crunchyroll-takeout/) failed
Any idea ?
EDIT: I've fixed. I had to remove a file in the addon data area ( .kodi/userdata/addon_data/plugin.video.crunchyroll-takeout ). The file I removed is :
- cruchyPickle
After I removed everything work fine.
Cheers,
Stefano.
How do you guys watch show that starts from letter x, y or z since there's no search capability?[emoji28]
Sent from my iPhone
I am also getting the issue when trying to access to Queue. This is the error log when I try to access the my queue:
23:34:37.836 T:2669265904 NOTICE: CR: makeAPIRequest: get JSON
23:34:37.871 T:2669265904 NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/queue.0.json
23:34:37.874 T:2669265904 NOTICE: CR: makeAPIRequest: options = locale=enUS&media_types=anime%7Cdrama&version=2313.8&session_id=swxxvrdlcokh3hmsrxodecc6mzj1g3u6&fields=media.episode_number%2Cmedia.name%2Cmedia.description%2Cmedia.media_type%2Cmedia.series_name%2Cmedia.available%2Cmedia.available_time%2Cmedia.free_available%2Cmedia.free_available_time%2Cmedia.duration%2Cmedia.url%2Cmedia.screenshot_image%2Cimage.fwide_url%2Cimage.fwidestar_url%2Cseries.landscape_image%2Cimage.full_url
23:34:42.920 T:2669265904 NOTICE: CR: A valid session was detected. Using existing session ID: swxxvrdlcokh3hmsrxodecc6mzj1g3u6
23:34:42.925 T:2669265904 NOTICE: CR: User is a premium anime|drama|manga member
23:34:42.947 T:2669265904 NOTICE: CR: Queue: queue type is 0
23:34:42.951 T:2669265904 NOTICE: CR: makeAPIRequest: get JSON
23:34:42.970 T:2669265904 NOTICE: CR: makeAPIRequest: url = https://api.crunchyroll.com/queue.0.json
23:34:42.973 T:2669265904 NOTICE: CR: makeAPIRequest: options = locale=enUS&media_types=anime%7Cdrama&version=2313.8&session_id=swxxvrdlcokh3hmsrxodecc6mzj1g3u6&fields=media.episode_number%2Cmedia.name%2Cmedia.description%2Cmedia.media_type%2Cmedia.series_name%2Cmedia.available%2Cmedia.available_time%2Cmedia.free_available%2Cmedia.free_available_time%2Cmedia.duration%2Cmedia.playhead%2Cmedia.url%2Cmedia.screenshot_image%2Cimage.fwide_url%2Cimage.fwidestar_url%2Cseries.landscape_image%2Cseries.series_id%2Cimage.full_url
23:34:47.718 T:2669265904 NOTICE: CR: Queue: request['error'] = False
23:34:47.720 T:2669265904 NOTICE: CR: Queue: has 77 series
23:34:47.894 T:2669265904 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "/home/osmc/.kodi/addons/plugin.video.crunchyroll-takeout/default.py", line 38, in <module>
crunchy_main.main()
File "/home/osmc/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_main.py", line 367, in main
check_mode(args)
File "/home/osmc/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_main.py", line 342, in check_mode
crj.queue(args)
File "/home/osmc/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_json.py", line 865, in queue
'fanart')
File "/home/osmc/.kodi/addons/plugin.video.crunchyroll-takeout/resources/lib/crunchy_json.py", line 752, in list_media_items
23:34:48.144 T:3025743872 ERROR: GetDirectory - Error getting plugin://plugin.video.crunchyroll-takeout/?complete=True&count=0&duration=0&episode=0&fanart=%2fhome%2fosmc%2f.kodi%2faddons%2fplugin.video.crunchyroll-takeout%2ffanart.jpg&filterx=None&icon=None&id=None&media_type=None&mode=queue&name=Queue&offset=0&playhead=0&plot=None%2520&season=1&series_id=None&url=None&year=0
23:34:48.385 T:3025743872 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.crunchyroll-takeout/?complete=True&count=0&duration=0&episode=0&fanart=%2fhome%2fosmc%2f.kodi%2faddons%2fplugin.video.crunchyroll-takeout%2ffanart.jpg&filterx=None&icon=None&id=None&media_type=None&mode=queue&name=Queue&offset=0&playhead=0&plot=None%2520&season=1&series_id=None&url=None&year=0) failed
Any ideas?
I did another merge this morning that is supposed to resolve an issue with crashing when no video is present.
Since I don't subscribe anymore, can someone please test and make sure the tree isn't burned.
If it is reported working I will push this to the main repo ... like I should have done more than a year ago
