two things you need to check:
1. in the cu lrclyrics addon settings, make sure 'Remove chinese/korean text from lyrics' is disabled
2. you'll need a skin that offers support for chinese characters.
in case you are using Estuary, go to 'Settings > Interface > Skin > Fonts' and select 'Arial based'
[font][font]è possibile aumentare il carattere del testo? [/font][font]troppo piccolo e difficile da leggere. [/font][font]in caso affermativo, come procedere? [/font][font]grazie e complimenti per l'addon.[/font][/font]
hello, on leia windows 10:
i have a trouble, when lcu lyric installed my navigation become jerky
there a fix ?
merci
(2020-07-21, 00:18)manfeed Wrote: [ -> ]...also I'm in Matrix nightly version, and the behavior is exactly the same... it's a pity to see such a computer with 10-12 fps in the GUI sometimes, just for using this addon. I know that you have already devoted a lot of time to this issue to no avail, and I'm not requesting you to do something more. It's just to keep you informed... For now I'll keep using dirty tricks in Aeon Tajo Matrix version to activate/disable the addon depending on the section the user is in each moment.
manfeed i have been doing some cleanup in the matrix version, and have removed some code that might (fingers crossed) have been the cause for the issue you've reported.
(i still can't reproduce the problem though, no matter what i try...)
if you could be so kind to test and report back:
script.cu.lrclyrics-6.3.0.zip
(2020-09-07, 23:36)ronie Wrote: [ -> ] (2020-07-21, 00:18)manfeed Wrote: [ -> ]...also I'm in Matrix nightly version, and the behavior is exactly the same... it's a pity to see such a computer with 10-12 fps in the GUI sometimes, just for using this addon. I know that you have already devoted a lot of time to this issue to no avail, and I'm not requesting you to do something more. It's just to keep you informed... For now I'll keep using dirty tricks in Aeon Tajo Matrix version to activate/disable the addon depending on the section the user is in each moment.
@manfeed i have been doing some cleanup in the matrix version, and have removed some code that might (fingers crossed) have been the cause for the issue you've reported.
I have been living for so long with this issue that I can't believe this is true, but in my tests the bug seems to have been fixed with this version... at least that is my first impression, since everything seems ok, even in situations where the bug would have appeared for sure with the former versions. I can't thank you enough!!!
(2020-09-07, 17:35)DonAnthony Wrote: [ -> ]hello, on leia windows 10:
there a fix ?
merci
could you try this version and let me know if that fixes it?
script.cu.lrclyrics-5.8.0.zip
Reinstalled Kodi, 1st 2 things I installed were the Aeon MQ8 skin and this add-on. I have a lot of lrc files from my previous Kodi install, so I copied them over to the new install.
Windows 10
Kodi 18.8
When I play a song, I get a CU LRC error and it tells me to check the log. This is what's in the log
2020-09-26 11:57:31.303 T:5300 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: No JSON object could be decoded
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\default.py", line 40, in <module>
culrc_run('service')
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\default.py", line 25, in culrc_run
gui.MAIN(mode=mode)
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\resources\lib\gui.py", line 28, in __init__
self.main_loop()
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\resources\lib\gui.py", line 71, in main_loop
self.myPlayerChanged()
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\resources\lib\gui.py", line 296, in myPlayerChanged
lyrics = self.get_lyrics(song)
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\resources\lib\gui.py", line 100, in get_lyrics
lyrics = self.find_lyrics(song)
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\resources\lib\gui.py", line 170, in find_lyrics
lyrics = scraper[1].get_lyrics(song)
File "C:\Kodi\portable_data\addons\script.cu.lrclyrics\resources\lib\culrcscrapers\lyricwiki\lyricsScraper.py", line 36, in get_lyrics
data = json.loads(response)
File "C:\Kodi\system\python\Lib\json\__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "C:\Kodi\system\python\Lib\json\decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Kodi\system\python\Lib\json\decoder.py", line 382, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
I tried uninstall and reinstalling Kodi, CU still isn't working. My old Kodi (18.4) it worked beautifully. Any ideas here would be great, thanks.
the LyricWiki website got shut down recently, which is causing this error.
i'll be sending an updated version of cu lrclyrics to the addon repo soon.
for now, you can disable the LyricWiki scraper in the addon settings:
I'm using KODI 19 for android, Cu LRC Lyrics gives an error in "Japanese song title"
*(English song titles are fine)
I want to fix it
Yukai thanx for the report, could you please follow the steps in the first post to create a
Debug Log?
posting just a snippet of the error is not providing the info i need.
sorry, but that's not a
Debug Log.
again please follow the instructions in the first post:
1 enable debug logging in kodi
2 enable debug logging in the cu lrclyrics addon settings
3 restart kodi
4 reproduce the issue
5 post the entire kodi.log file on
http://paste.ubuntu.com/
perfect, thx!
the crash will be fixed in the next version.
