(2020-10-04, 19:28)ronie Wrote: [ -> ]perfect, thx!
the crash will be fixed in the next version.
add Japanese translation...Pls..
"ja_JP"
thanx much!
i'll add them.
Correction of a typographical error
msgctxt "#32101"
Correct: msgid "Search for and save lyrics in separate lyrics folder"
msgctxt "#32113"
Correct: msgid "Search for and save lyrics in song folder"
thanx again, i'll fix that.
I use a RP4 libreelec 9.2.5 . Often the script breaks and is restored only after rebooting kodi, I apply a log ->
log
(2020-10-07, 22:24)zypy Wrote: [ -> ]I use a RP4 libreelec 9.2.5 . Often the script breaks and is restored only after rebooting kodi
Please removed any video piracy add-ons (elementum in your case) before asking for support next time.
Read our
forum rules (wiki) in case you accidentally forgot.
ronie
I'm using version 6.3.1 for Matrix, and I have noticed that when I bring up the context menu while playing a song and choose a different version of lyrics, the new lyrics gets stuck in that sentence... even if I bring up again the context menu and choose the former lyrics, the lyrics engine keeps stuck in that sentence until the next song. Thanks in advance for having a look at it!
Thanks! That issue seems to have been fixed, but I hate to say that when testing, I came across another one... When a song has several lyrics to choose from, but the next song has only one, you can still bring up the context menu when listening to the latter and you are offered the same several lyrics from the former one, and if you choose one of them, the correct lyrics of the current song gets replaced. This issue doesn't happen if the songs involved have all of them several lyrics to choose from, in that case everything is correct. Thanks again.
Thanks! The issue seems fixed now and, in addition, I would say that the script works somewhat smoother now, but it could well be just my impression...
(2020-10-10, 18:37)manfeed Wrote: [ -> ]I would say that the script works somewhat smoother now
that was certainly the intent, i went through all of the code and removed/optimized/refactored quite a few bits and pieces
(2020-10-10, 14:34)ronie Wrote: [ -> ]great, thanx for testing and your feedback :-)
this one should fix that problem as well:
script.cu.lrclyrics-6.3.3.zip
Japanese Songtitle *.txt Lyrics
Success
Log 1
Error
Log2
*.lrc and 5.6.x for Leia is Everything OK
Hmm...
