I have disabled the auto-start of CU LRC Lyrics when playing music in Kodi.
So, how do I manually open and close CU LRC Lyrics as needed?
Hello,
Version info: Kodi 19. Alpha1
Git: 20200209-9940d952fa
My beloved Lyrics Add-On stopped working. I uninstalled it (as well as all dependencies) and installed the latest 6.3.4
During the installation it tells me "CU LRC Lyrics error, Check the log for more information"
Where can I find that log file? I have enabled log debugging.
Thank you for any help.
Cheers
Caesar
PS: When I turn on Kodi, it gives me following error message: "Version Check error, Check the log for more information"
(2020-10-15, 23:02)ronie Wrote: [ -> ]see the wiki: Debug Log
Thank you kindly.
Here is the log file: https:paste.kodi.tv/juvudedebu
I hope no personal info are in the file? Could you please kindly check the log file and let me know what is wrong?
Cheers
Caesar
ah, that's an easy one, your kodi install is too old (alpha 1). please update kodi to alpha2 and the errors will be gone.
(2020-10-15, 23:21)ronie Wrote: [ -> ]ah, that's an easy one, your kodi install is too old (alpha 1). please update kodi to alpha2 and the errors will be gone.
No, unfortunately that is not an easy one since the version I have is the latest version for my QNAP NAS. :-(
Here is the latest download link:
https://nascompares.com/2020/04/07/how-t...-qnap-nas/
It worked before but not anymore. Any other idea?
Thanks again.
(2020-10-15, 11:41)ronie Wrote: [ -> ]in the estuary skin, there's a button on the music osd to start cu lrclyrics.
see: https://kodi.wiki/view/Music_navigation#...g_Controls
I don't have any of those buttons.
And I don't have the album art background.
And after a few seconds, I get a blank background.
(2020-10-16, 01:37)Dypsis Wrote: [ -> ] (2020-10-15, 11:41)ronie Wrote: [ -> ]in the estuary skin, there's a button on the music osd to start cu lrclyrics.
I guess that background is Fanart. I have it enabled, but it is not working. Just a blank screen.
But what is worse is when it goes completely blank after a few seconds. Even if I could disable the few seconds timeout, it would be better than going blank.
Hello ronie, I just dusted off an old music addon after a couple of years that I was previously working on and noticed that you've recently removed support to grab lyrics manually. Would the below from your readme be a replacement? If so, do you know of or have any example code that I could look at to try and figure out how to implement? Thanks.
"music addons can add lyrics to their items this way:
https://codedocs.xyz/xbmc/xbmc/group__py...titem.html
listitem.setInfo('music', {'lyrics': 'lyrics here'})
listitem.setProperty('culrc.source', 'addon name here')"
nope, it's not a replacement. i'm afraid there is none.
cu lrc will only fetch lyrics for the song that is currently playing.
the code from the readme allows addons to add lyrics to a listitem themselves.
(which is a standard kodi feature and not really specific to the cu lrc addon)
