(2013-06-05, 15:43)ronie Wrote: [ -> ] (2013-06-05, 11:18)manekineko Wrote: [ -> ]Is there any way to get XBMC to display the lyrics over the top of the visualization instead of locked in a popup box that you have to manually launch? I'd love it if as soon as a song plays, it just starts scrolling the text in front of the visualization nice and big so you can see it clearly. I believe the native karaoke support does this, but I can't test it since my songs are mp3s with embedded lrc.
that's all up the the skin and not this addon.
skins can autorun the cu-lrc script whenever you switch to the visualization screen.
they also decide the font-size and all...
So there's no way to achieve that effect like a karaoke box where the lyrics take up the whole screen and display automatically on the stock skin is there? Do you know of any skin that can do this?
Any chance on making this add on also function as a visualization so that this could be done with any skin?
I was using Aeon MQ4 and this worked fine out ofthe box...I just switched to Aeon MQ3 as I like it better but the lyrics don't work..it just keep ssaying select another script
Any ideas?
(2013-06-06, 05:46)NewYears1978 Wrote: [ -> ]I was using Aeon MQ4 and this worked fine out ofthe box...I just switched to Aeon MQ3 as I like it better but the lyrics don't work..it just keep ssaying select another script
Any ideas?
i'm afraid i don't have any idea.
you may want to around in the aeon forum.
(2013-06-07, 10:08)smuto Wrote: [ -> ]looks like CU LRC Lyrics don't supports a radio
http://xbmclogs.com/show.php?id=25521
can i automatically close script when i'm listen a radio?
smuto
it will only work if the stream provides a artist name and songtitle.
there's no way to autoclose the addon.
(2013-06-07, 19:26)ronie Wrote: [ -> ] (2013-06-07, 10:08)smuto Wrote: [ -> ]looks like CU LRC Lyrics don't supports a radio
smuto
Change the script to not scrape lyrics while can't get artist name and songtitle?
[/quote]
yeah sure, that makes sense :-)
Quote:it will only work if the stream provides a artist name and songtitle.
i will try edit yours script for ICY StreamTitle
My fork
Mayby u find time to take a look
smuto
(2013-06-08, 03:00)taxigps Wrote: [ -> ] (2013-06-07, 19:26)ronie Wrote: [ -> ] (2013-06-07, 10:08)smuto Wrote: [ -> ]looks like CU LRC Lyrics don't supports a radio
smuto
This is a cool addon, but since it started getting used by more skins, i have been having a nightmare time using airplay with this addon which installs with various skins on windows.
Here was the latest as i tried to airplay music from a radio station on my iphone.
08:31:48 T:3368 ERROR: CLocalizeStrings::ClearBlock: Trying to clear non existent block C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.cu.lrclyrics
08:31:48 T:3360 NOTICE: Thread Jobworker start, auto delete: true
08:31:59 T:2680 ERROR: EXCEPTION: Non-Existent Control 605
08:31:59 T:2680 ERROR: EXCEPTION: Non-Existent Control 299
08:31:59 T:2680 ERROR: Failed to run the gc to clean up after running prior to shutting down the Interpreter C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.cu.lrclyrics\default.py
08:31:59 T:2680 WARNING: The python script "C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.cu.lrclyrics\default.py" has left several classes in memory that we couldn't clean up. The classes include: WindowXMLDialog,Window,Player
08:33:17 T:2292 NOTICE: Thread Jobworker start, auto delete: true
I should mention as soon as i disable the addon it works fine, but i like it, and hope it does not come to this, and it also seems to re-enable whenever my skin gets updated.
Seems to be working will have to check after a restart....noticed you mentioned in another thread regarding airplay and your addon.
"most of the lrc scraper should work i think?
only Alsong and GomAudio could cause issues i think."
Does the addon come with these two enabled? If so would you consider having the addon come with them disabled. As soon as i disabled them airplay seemed to work.
(2013-06-12, 06:24)Ghostdivision Wrote: [ -> ]Seems to be working will have to check after a restart....noticed you mentioned in another thread regarding airplay and your addon.
both are disabled by default.
One last question, I am not sure if this is skinner area or your area, but if your script cannot find lyrics is there anyway it could vanish. I often listen to songs without lyrics or not well known songs and it just sits on screen saying no lyrics found,.
I'm trying to set up a lyrics database for all music within my files... it appears the plugin only looks for lyrics of songs that are playing... how can i recurse through all files in one go and where are lyrics files stored for access remotely?
nevermind, on the second part of the question... i found the lyrics files in the options for the plugin... but nothing that lets me scan the entire library for lyrics all at once... any suggestions?
