2014-01-16, 21:12
2014-01-17, 11:32
(2014-01-16, 21:12)Mossy Wrote: [ -> ]Thanks for posting the logs. However, you have not enabled debug logging, see the first post in this thread.
OOpps Sorry new to al but thank for all your help i have tryed again as it just locks up at 35% ?
Your debug xbmc.log: http://xbmclogs.com/show.php?id=111688
Your XBMC crashlog: http://xbmclogs.com/show.php?id=111689
Hope this is better. Cheers once again
2014-01-17, 16:35
OK, debug logging is enabled, now you need to create a log whilst recreating the problem. The log you posted shows you running several plugins, none of which are Irish TV.
Try this:
1) Make sure that debug logging is enabled
2) Restart XBMC
3) Recreate the problem
4) Upload the log (do not restart XBMC before this step)
Try this:
2) Restart XBMC
2014-01-17, 21:14
(2014-01-17, 16:35)Mossy Wrote: [ -> ]OK, debug logging is enabled, now you need to create a log whilst recreating the problem. The log you posted shows you running several plugins, none of which are Irish TV.
Try this:
2) Restart XBMC
Thank for that but the problem is its locking up on 35% so a restart it needed?
Try this:
2) Restart XBMC
2014-01-17, 23:22
You can either post this file, before restarting: C:\Users\paul\AppData\Roaming\XBMC\xbmc.log
or you can restart and then post xbmc.old.log
When you start XBMC the xbmc.log from the last session is renamed to xbmc.old.log and a new xbmc.log is created. So if you recreate the problem, then restart XBMC and then post xbmc.log, the log will only show what happened after you restarted XBMC.
2014-01-18, 00:27
2014-01-18, 02:32
I get a "502 Bad Gateway" with that link - you're not having much luck.
Probably a one time glitch on the xbmclogs website, please try again.
2014-01-19, 13:51
ha nothing new they then lol
Here it its again fingers crossed
Your debug xbmc.log: http://xbmclogs.com/show.php?id=112677
Your debug xbmc.old.log: http://xbmclogs.com/show.php?id=112678
Your XBMC crashlog: http://xbmclogs.com/show.php?id=112679
2014-01-19, 18:24
The xbmc.log is posted OK, but xbmc.old.log still doesn't work. If you click on the link you posted you can see for yourself.
Let's take another tack. Reproduce the problem, and without restarting XBMC, open the following file in a text editor (e.g. Notepad)
Select All in Notepad (Ctrl + A) and copy (Ctrl + C).
Now go to http://pastebin.com in a web browser, and paste (Ctrl + V) into the "New Paste" section. Click "Submit" and post the URL they give you here.
2014-01-22, 12:38
(2014-01-10, 01:45)Mossy Wrote: [ -> ]I'll work on getting the AerTV login working in the plugin. You might want to wait until I have that completed before pulling the trigger on the subscription.
@aimcn If you post a debug log I can have a look. See first post in this thread, for a debug log "howto" link.
Here is the debug log
URL:http://xbmcloogs.com.show.php?id=14200
hope that helps
2014-01-22, 14:24
Thanks for posting the the log, but your link doesn't work. Try it yourself to see what I mean.
2014-01-22, 14:37
Hi Mossy, great addon - well done.
AerTV is working for me fine but none of the other channels are - I'm assuming they should all work as there's no known issues? If not then I'll get some logs tonight...
Thanks,
Kohhal
Thanks,
Kohhal
2014-01-22, 14:51
(2014-01-22, 14:24)Mossy Wrote: [ -> ]Thanks for posting the the log, but your link doesn't work. Try it yourself to see what I mean.
Sorry Mossy the link is
http://xbmclogs.com/show.php?id=114223
this worked for me
thanks
2014-01-22, 15:50
@aicmn You're not the first to have problems with TV3 on Android.
It works for me though, using a very recent XBMC Gotham nightly build for Android (specifically the version from 20 Jan, but the latest should work just as well). Can you install a nightly build and try again?
You can find the nightly builds here: http://mirrors.xbmc.org/nightlies/android/arm/
