(2014-05-23, 23:09)Mossy Wrote: [ -> ]Once you turn on debug logging it'll log debug information for everything you do to the XBMC log until you turn debug logging off again.
So, yeah, it works automagically for whatever you plugin you need it for.
Hi Mossy,
I did the debugging as you said and while I try to go into the plugin it keeps saying script failed. It's really frustrating is their anything else I can do?
Hi Mossy, ty for this great program.
All worked well when i was in europe but find that back in Ireland i cant get irishtv to run .
It allows me to select but just loads and nothing happens. in running on an ATV1200 Mygica. with Gotham. I've deleted all the files for Irish tv under android folder and re-install from xmbc.org. but no good. btw it working fine on my laptop with Frodo. could i be a Gotham issue?
any suggestion in what I might try . ?
Ronymc24 You need to read the first post regarding debug logs.
bluesweeper Wrote:any suggestion in what I might try . ?
Read the first post regarding debug logs.
Mossy, are you any closer to getting RTE player working again and anything I can do to speed up the process?
(2014-05-24, 15:52)Mossy Wrote: [ -> ]@Ronymc24 You need to read the first post regarding debug logs.
Hello,
I am attaching debug logs here ->
http://xbmclogs.com/show.php?id=215727
When I try to use the rte player to stream any program it tells me that another stream is running even though there is not.
This happens for any program that I try to watch and has been happening for the last fortnight.
Thanks,
G
hi mossy . heres the log files regarding gmcgrath problem
14:18:12 T:5216 ERROR: Closing connection: NetStream.Play.StreamNotFound
14:18:12 T:5216 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmpe://fmsod.rte.ie:1935/rtevod app=rtevod playpath=mp4:/2014/0601/20140601_rtetwo-thesundaygame-thesundayg_cl10288950_10288952_260_drm_/manifest/20140601_rtetwo-thesundaygame-thesundayg_cl10288950_10288952_260_drm_/manifest_512k.mp4 swfurl=http://www.rte.ie/player/assets/player_468.swf swfvfy=true]
14:18:12 T:5216 NOTICE: CDVDPlayer::OnExit()
14:18:12 T:5216 NOTICE: CDVDPlayer::OnExit() deleting input stream
14:18:12 T:5216 DEBUG: CApplication::OnPlayBackStopped : play state was 1, starting 1
14:18:12 T:5216 DEBUG: Thread DVDPlayer 5216 terminating
14:18:12 T:6988 DEBUG: CApplication::OnPlayBackStopped : play state was 3, starting 0
14:18:12 T:6988 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
14:18:12 T:6988 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
14:18:12 T:6988 ERROR: Playlist Player: skipping unplayable item: 0, path [rtmpe://fmsod.rte.ie:1935/rtevod app=rtevod playpath=mp4:/2014/0601/20140601_rtetwo-thesundaygame-thesundayg_cl10288950_10288952_260_drm_/manifest/20140601_rtetwo-thesundaygame-thesundayg_cl10288950_10288952_260_drm_/manifest_512k.mp4 swfurl=http://www.rte.ie/player/assets/player_468.swf swfvfy=true]
14:18:12 T:6988 DEBUG: Playlist Player: no more playable items... aborting playback
and heres my log files details regards my aer tv account without the premium channels .
14:17:50 T:7776 NOTICE: LogLoginInfo : 'is_paid_subscriber: 2'
14:17:50 T:7776 NOTICE: LogLoginInfo : 'login: True'
14:17:50 T:7776 NOTICE: LogLoginInfo : 'status: 3'
14:17:50 T:7776 NOTICE: LogLoginInfo : 'status: [
u'code': u'AERTV_PLUS',
u'desc': u'Aertv Plus',
u'package_id': u'6'
u'code': u'WEB_STD',
u'desc': u'Free Channel Pack',
u'package_id': u'1'
u'code': u'WEB_STD_ADDON',
u'desc': u'Aertv Platinum',
u'package_id': u'2'
let me know if that log report was incorrect and if you need anything else . donations etc. thanks
dexter The RTE player issue will some time to fix, don't expect it anytime soon.
Gmcgrath As you can see from recent posts the RTE part of the plugin is not working (except for RTE 1 and RTE 2 live). In any case the solution to your problem is to use the context menu and select "Force unlock resume file", but you still won't be able to play back the videos.
Matthew palmer There's no point in posting log extracts. There's a link in the first post that explains exactly how to generate and upload debug logs.
http://xbmclogs.com/show.php?id=215764
it says to upload the url . not very good with computers.
is there any way we can get the rte on demand back working . i donated 20 euro already and ill donate another 50 euro now and im sure others willl to . i know you are doing this add on for free and it it may be out of your hands but alot of people use it. also another 50 when you are done as i know it might take some time and work . and im sure others will too . thanks and keep up the good work
Thanks for the debug log. Please install
plugin.video.irishtv-2.1.2.zip from here:
linky, run the test again, and again upload the debug log.
The result will be the same but the resulting debug log will bring me closer to a solution.
Regarding RTE on demand see my response to dexter in my last post.
Matthew Palmer, Hi Matt, am sure you already know this but you could try your ipad/PC to watch RTE on demand. XBMC is not the only medium to watch RTE. Am aware you must be outside Ireland but there are many way to do this. Just read back a few of the posts on here if not sure.
Hi guys,
RTE Live
v.2.1.1. in Xbmc 13.0 is not working since last Monday.
v 2.1.2. in Xbmc 13.1 IS NOT WORKING too.
Any ideas?
Thanx.
yes, its not working.
We really need it here in Portugal.
Please help.
RTE live in frodo not working for me either so i dont think its a gotham thing but im no developer thats for sure
