v 2.1.1.
RTE Live is not working since yesterday.
Dialog box saying:
Stream already playing / Unable to open stream
- To continue stop all other streams (try pressing u'x')
- If you are sure there are no other streams.
Ok
Then it fails.
I tested previous versions and it happens the same.
Any ideas?
Thanx.
Hi Mossy,
I can't get the irish tv addon working it keeps saying script failed. I am currently living in Canada would that be a reason for it being like that. I am running the xbmc of the mx2 g-box. Can you please help me fix this problem thanks.
(2014-05-09, 18:29)h18a51xbmcfreak Wrote: [ -> ]v 2.1.1.
Dialog box saying:
Ok
Then it fails.
Any ideas?
Thanx.
Can also confirm RTE Live is not working.
Let me know if I can supply any debug information.
h18a51xbmcfreak / denartha RTE One and RTE Two live are working for me, so a debug log would be helpful.
Ronymc24 There's a link to the wiki in the first post that explains the options for people abroad. I think most end up using a VPN or a DNS forwarder like Overplay's SmartDNS.
Umm no doubt I'll be totally ignored but the download function in Gotham ain't working. I tried it on Frodo and it was fine.
When I posted my last thread was the 9/05/2014. My machine's running 12.3 Xbmc. I found out this morning that the current stable release is Gotham 13.0. So I'll test Irish TV 2.1.1 on Xbmc 13.0 and I will share with ya the results. Hail !
VanZan A debug log would be useful
RTE Live:
Hi guys, I tested twice Irish TV 2.1.1 on Gotham 13.0. First time did not work. Second time working OK.
Hope that can help you guys...
I'll report any other issues if they arise.
Hail and Kill !!!
(2014-05-10, 14:51)Ronymc24 Wrote: [ -> ]Hi Mossy,
Hi, as Mossy said in his reply, you need to use either a VPN or DNS masking service. I live in Asia and use a DNS service, that works very well. The two best options are Overplay or UnoTelly. Just Google them and you will find their web sites.
I also use the MX box and it is easy to change your DNS settings on it, have posted the instructions, on here previously so scroll back a few pages. However, if you have any difficulties let me know and I will try to help.
Good luck ..
hi mossy .great job with the irish tv player . its great . alot of users esp for the soaps.
iv signed up wit aer tv and magnet to get the premium channels . do these channels automatically add on to the xbmc add on as i don't seem to be able to get them . it may be a mistake on their end also .
(2014-05-12, 15:42)VanZan Wrote: [ -> ]the download function in Gotham ain't working. I tried it on Frodo and it was fine.
Same for me. Running OpenElec 4.0 (previously 3.2), Irish TV v2.1.1, on a Raspberry Pi.
Log from download attempt:
21:21:09 T:2707420240 NOTICE: _Cache_CreateKey : 'url: http://feeds.rasset.ie/rteavgen/player/playlist/?type=iptv&format=json&showId=10281165'
21:22:28 T:2707420240 NOTICE: Download : 'Starting download: /usr/bin/rtmpdump --rtmp "rtmpe://fmsod.rte.ie:1935/rtevod" -o "/storage/.xbmc/The Zoo_10281165.flv" --app "rtevod" --playpath "mp4:/2014/0508/20140508_rteone-thezoo_cl10281165_10281177_260_drm_/manifest/20140508_rteone-thezoo_cl10281165_10281177_260_drm_/manifest_512k.mp4" --swfVfy "http://www.rte.ie/player/assets/player_468.swf"'
21:22:28 T:2707420240 NOTICE: Download : '"/usr/bin/rtmpdump" --rtmp "rtmpe://fmsod.rte.ie:1935/rtevod" -o "/storage/.xbmc/The Zoo_10281165.flv" --app "rtevod" --playpath "mp4:/2014/0508/20140508_rteone-thezoo_cl10281165_10281177_260_drm_/manifest/20140508_rteone-thezoo_cl10281165_10281177_260_drm_/manifest_512k.mp4" --swfVfy "http://www.rte.ie/player/assets/player_468.swf"'
The file "/storage/.xbmc/The Zoo_10281165.flv" is created, and running "ps" shows me that rtmp is running (and taking up 30-50% CPU), but "ls" reports that the flv file stays at 0 bytes, no matter how long I leave it running.
I'm also getting the RTE catch up failing at 50% as others have mentioned. All other streams / sources appear to work as normal.
Log file indicates an issue with rtmp header & codec parameters. Maybe RTE have changes their cofiguration for this.
V2.1.1 on Raspbmc through SmartDNS
20:25:03 T:2546959424 NOTICE: ParseCommand : 'urlRoot: http://www.rte.ie, page: /player/ie/most-popular/'
20:25:15 T:2546959424 NOTICE: _Cache_GetFromFlag : '_Cache_GetFromFlag() - gotFromCache = False'
20:25:15 T:2724197440 NOTICE: Thread Background Loader start, auto delete: false
20:25:15 T:2652894272 NOTICE: Thread Jobworker start, auto delete: true
20:25:53 T:2652894272 NOTICE: Previous line repeats 1 times.
20:25:53 T:2652894272 NOTICE: Thread XBPyThread start, auto delete: false
20:25:53 T:2652894272 NOTICE: -->Python Interpreter Initialized<--
20:25:58 T:2652894272 NOTICE: <module> : 'Loading cookies from :u'/home/pi/.xbmc/userdata/addon_data/plugin.video.irishtv/cookiejar.txt''
20:25:58 T:2652894272 NOTICE: setGetFromCache : 'self: <httpmanager.HttpManager instance at 0x2be10f8>'
20:25:58 T:2652894272 NOTICE: setGetFromCache : 'setGetFromCache(True)'
20:25:58 T:2652894272 NOTICE: InitialiseHTTP : 'proxy_method: 0'
20:26:10 T:3040317440 NOTICE: COMXPlayer: Opening: rtmpe://fmsod.rte.ie:1935/rtevod app=rtevod playpath=mp4:/2014/0514/20140514_rteone-homeandaway-homeandawa_cl10282995_10282996_260_drm_/manifest/20140514_rteone-homeandaway-homeandawa_cl10282995_10282996_260_drm_/manifest_512k.mp4 swfurl=http://www.rte.ie/player/assets/player_468.swf swfvfy=true
20:26:10 T:3040317440 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:26:10 T:2546959424 NOTICE: Thread COMXPlayer start, auto delete: false
20:26:10 T:2546959424 NOTICE: Creating InputStream
20:26:10 T:2546959424 NOTICE: Creating Demuxer
20:26:42 T:2546959424 ERROR: RTMP_ReadPacket, failed to read RTMP packet header
20:26:43 T:2546959424 WARNING: could not find codec parameters for rtmpe://fmsod.rte.ie:1935/rtevod app=rtevod playpath=mp4:/2014/0514/20140514_rteone-homeandaway-homeandawa_cl10282995_10282996_260_drm_/manifest/20140514_rteone-homeandaway-homeandawa_cl10282995_10282996_260_drm_/manifest_512k.mp4 swfurl=http://www.rte.ie/player/assets/player_468.swf swfvfy=true
20:26:43 T:2546959424 ERROR: OpenDemuxStream - Error creating demuxer
20:26:43 T:2546959424 NOTICE: COMXPlayer::OnExit()
20:26:43 T:2546959424 NOTICE: COMXPlayer::OnExit() deleting input stream
20:26:43 T:3040317440 ERROR: Playlist Player: skipping unplayable item: 0, path [rtmpe://fmsod.rte.ie:1935/rtevod app=rtevod playpath=mp4:/2014/0514/20140514_rteone-homeandaway-homeandawa_cl10282995_10282996_260_drm_/manifest/20140514_rteone-homeandaway-homeandawa_cl10282995_10282996_260_drm_/manifest_512k.mp4 swfurl=http://www.rte.ie/player/assets/player_468.swf swfvfy=true]
20:26:43 T:3040317440 NOTICE: COMXPlayer::CloseFile
20:26:43 T:3040317440 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:26:43 T:3040317440 NOTICE: COMXPlayer: waiting for threads to exit
20:26:43 T:3040317440 NOTICE: COMXPlayer: finished waiting
Hello Guys,
I was watching RTE News this morning and and one of the bulletining read as follows"RTE has anounced a new live and Vod service for people living outside Ireland.The service is called GAAGO. I don't know what it stand for. Maybe you can check this GAAGO out.
(2014-05-15, 05:09)oilbag Wrote: [ -> ]Hello Guys,
€110 for GAA games only.
http://www.rte.ie/sport/gaa/2014/0514/61...a-and-rte/
As someone has already pointed out in the comments section(wonder how long that one will stay there), better to stick with VPN service & get all RTE content
