2023-03-24, 19:13
my mistake i thought i was on a community forum where ideas can and should be shared for the betterment of the community
i will not offer any further input to your project
(2023-03-24, 19:13)jepsizofye Wrote: [ -> ]my mistake i thought i was on a community forum where ideas can and should be shared for the betterment of the community
(2023-03-24, 18:25)beatmasterrs Wrote: [ -> ]The creative common license logo is optional, if the license text is shown. But if i dont include an image control with id 9905, no wiki infos are shown?
(2023-03-24, 18:25)beatmasterrs Wrote: [ -> ]I've tried to use another color for the wiki links. When i set a skin string (the code example from the tmdbhelper wiki) e.g.
xml:
<onload>Skin.SetString(TMDbHelper.Wikipedia.Format.Link,{})</onload>
(2023-03-24, 18:25)beatmasterrs Wrote: [ -> ]Do you already know when version 5 of your addon will be available in the official repo?
(2023-03-26, 03:49)jepsizofye Wrote: [ -> ]i get your reason @jurialmunkeyPlease get api keys for tmdb and fanart TV as those are what provides the metadata and will be hit 100s of times by your changes. Trakt is a single request for the list and isn't affected.
i have more than 10k items in my collection, at 83 items a page thats 125 pages. and next week there will be more.
no worries though ive worked out my own api key as suggested
$INFO[Window(Home).Property(TMDbHelper.ListItem.PROPERTY)]
return empty in MyVideoNav window?TMDbHelper.Service
method and all the properties are working fine in VideoInfo dialog and in Home window but not in video window.(2023-03-30, 01:12)jurialmunkey Wrote: [ -> ]Check that you aren't accidentally setting a widget container ID property.Yep... that was the issue, but i am curious... why this was preventing the info properties to show in MyVideoNav?.
(2023-03-30, 01:12)jurialmunkey Wrote: [ -> ]it's been a while since I used that methodWhat do you mean?. I thought the
TMDbHelper.Service
method was the best way to go. Or not?(2023-03-30, 06:30)nessus Wrote: [ -> ]Yep... that was the issue, but i am curious... why this was preventing the info properties to show in MyVideoNav?.
I thought the widget container ID property was required only for the widgets to work. Will i have a problem if I remove it?
(2023-03-30, 06:30)nessus Wrote: [ -> ]What do you mean?. I thought the TMDbHelper.Service
(2023-03-30, 06:30)nessus Wrote: [ -> ]Sorry for the repeatedly questions but like i said it's been a while and i am trying to keep up with things.
(2023-03-30, 16:50)gemini88 Wrote: [ -> ]or is this normal
SetProperty(TMDbHelper.WidgetContainer,WIDGET_ID,Home)
from Startup window, i will still get the info properties in my home widgets container... correct?. Or is there any other way using the TMDbHelper.Service
method to get the info properties in MyVideoNav and keep the TMDbHelper.WidgetContainer.ID
property?(2023-03-30, 13:48)jurialmunkey Wrote: [ -> ]If WidgetContainer is clear then TMDbHelper uses the container ID of the current viewtype as per <views>. =
If WidgetContainer is set but that ID doesn't exist then there's nothing to lookup so properties are cleared.
(2023-03-30, 13:48)jurialmunkey Wrote: [ -> ]In v5+ from my repo, there is now an additional setting you can toggle to make the property on a per window basis:
Skin.SetBool(TMDbHelper.UseLocalWidgetContainer)
(2023-03-30, 18:56)nessus Wrote: [ -> ]So, if understand correctly... if i completely remove theSetProperty(TMDbHelper.WidgetContainer,WIDGET_ID,Home)
from Startup window, i will still get the info properties in my home widgets container... correct?. Or is there any other way using theTMDbHelper.Service
method to get the info properties in MyVideoNav and keep theTMDbHelper.WidgetContainer.ID
property?
xml:
<onload>SetProperty(TMDbHelper.WidgetContainer,WIDGET_ID,Home)</onload>
<onunload>ClearProperty(TMDbHelper.WidgetContainer,Home)</onunload>
xml:
<control type="list" id="301">
<onfocus>SetProperty(TMDbHelper.WidgetContainer,301,Home)</onfocus>
</control>
<control type="list" id="302">
<onfocus>SetProperty(TMDbHelper.WidgetContainer,302,Home)</onfocus>
</control>
etc.
(2023-03-30, 18:56)nessus Wrote: [ -> ]Are you planning to submit v5+ to the official repo any time soon?
