Full Version: [DOWNLOAD/CHANGELOG] Aeon (via github)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
Ok I understtod this, but for the fonts? How I download via terminal and unpack in the correct directory?
Please add this quote in the first post it will more easy to find.
Regards
daveisadork Wrote:You have just made things so incredibly easy for those of us on Linux, thank you!
If anybody is using Linux, and not sure what to do here, make sure you have git installed ("sudo apt-get install git-core" if you're on Ubuntu) and then just do the following at a terminal (don't forget to remove your existing Aeon installation first!):
cd ~/.xbmc/skin
git clone git://github.com/djh/aeon.git
And then, when you want to update to the latest build, just do the following in a terminal:
cd ~/.xbmc/skin/aeon
git pull
That's it!
