2009-04-05, 02:29
Nazgulled: If you want to try, nothing will prevent you from uninstalling msysGit whenever you want. But I think downloading a fresh zip is perfectly fine, also.
nekrosoft13 Wrote:what if you don't want to use those browsers. firefox is ok browser, but safari is far from decent.
seems like a bad place to host files
dedaluz Wrote:Nazgulled: If you want to try, nothing will prevent you from uninstalling msysGit whenever you want. But I think downloading a fresh zip is perfectly fine, also.That would defeat my purpose of not wanting to install additional software that I won't use or will use that much. The problem is not space or whatever, it's about "one more software installed" that I won't be using that much. I'm very pick in what I install on my system, uninstalling things never clears all the traces, that's why I don't like to install stuff I'm not going to use that much.
dedaluz Wrote:On windows, msysGit is perfectly usable in production.To me, is not as good as SVN and bear in mind that I'm only talking about Windows. But I don't really care if it's better or worse, I'm not going to use it until I have a mature developed client as I have for SVN (TortoiseSVN). There's no need to continue this discussion any further, you're not going to change my mind.
dedaluz Wrote:So I don't want to start a flame war, nor any kind of discussion, about this or about Opera USB vs. Firefox 3 . You don't want to use git, fine. But it's great to have Aeon versioned (with git, or whatever) at our disposal.I never said otherwise
Nazgulled Wrote:To me, is not as good as SVNMan, frankly, before speaking about maturity, advantages or which one is better, try them both and do a bit of research. I did, and my conclusion is that git is far better in quite a few relevant aspects. Then make your statements.
Nazgulled Wrote:I'm not going to use it until I have a mature developed client as I have for SVN (TortoiseSVN)For people with CMDA (Command-Line Allergy), you have http://code.google.com/p/tortoisegit/ . But again, you don't want to install msysGit for the command-line (minimal installation) but you don't have any problem with Tortoise, very logical.
Nazgulled Wrote:you're not going to change my mind.
Jiggles Wrote:the site doesn't even work on IE7Why don't you buy them a pony, too? Look, at the end, it's a matter of resilience to change. That's why IE6 and IE7 are so widely used. That's why Cobol continues with an inmense codebase. That's why people teach programming using Pascal, Modula-2 or Java. That's why a lot of people still use CVS for versioning(a pain in the ass). That's why... Ok, maybe it worked in the past, but we could do better. Why are you using Aeon, after all? or XBMC? They require an effort, too. But it's worth it. That's why.
...why don't you make it all a bit user friendly and just publish an installer?
djh_ Wrote:I personally don't have any problems with git but if it's more trouble for more people then there's little point in sticking with it.
dedaluz Wrote:Man, frankly, before speaking about maturity, advantages or which one is better, try them both and do a bit of research. I did, and my conclusion is that git is far better in quite a few relevant aspects. Then make your statements.What part of "I don't care about it" didn't you understand? I honestly don't understand why are you so offended and being defensive. Chill dude... I couldn't care less git is far better. To me it's not, I have my needs I have my reasons, end of discussion.
dedaluz Wrote:For people with CMDA (Command-Line Allergy), you have http://code.google.com/p/tortoisegit/ . But again, you don't want to install msysGit for the command-line (minimal installation) but you don't have any problem with Tortoise, very logical.Seriously, you must have a problem, or probably work for git/github, that's the only explanation... First of all, I never said I disliked command line apps. In fact, if you've read my posts carefully, you would see I asked if there a was a simple command line app I could download to use git but without having to install it. Second of all, I never said I had problems or didn't had problems with software X or Y, the software names came only from you. Who said I didn't have a problem with Tortoise? I don't if we are talking about TortoiseSVN, I do if it's TortoiseGit. Please try to read before you post. And third of all, I never said git it self, as a revision control software was not mature. The Windows clients to work with git, are not mature enough for me or need to be installed and I don't want to install them for the use I'm going to give them or I simply dislike them.
dedaluz Wrote:Nazgulled, I'm sick of this. What part of "if you haven't tried it yet, you can't say you like it or not, that it's better from x or not, that it's mature enough or not, etc." didn't you understand? It's pretty basic.You are the one that don't understand... I DON'T CARE!!!
dedaluz Wrote:I don't care about your opinion here at all, although I respect it. But, and this is what bothers me from your posts, please, don't discourage people from using or learning git on windows, specially without even trying it. Don't offer the impression git is unusable or inmature on win. PERIOD.Than you have a problem understanding people. TO ME (did you read that or you want big red letters to understand?) it's not mature, it's not usable (and I'm talking about MSysGit/TortoiseGit, not GIT itself). TO ME, TO ME, TO ME! MY OPINION! Geez...
Quote:This is definitely my last post on the subject.
