hello bluray. dont take it bad
can you please create a new thread and copy paste
what you wrote here?
i'll help you there once thread created!
i just dont want this current thread i made flooded
with users builds questions,,,
ok, see you there
cider123 Wrote:Sounds nice. I will give W7 a try tonight.
Just use a GT430 and openELEC (which is a tiny tiny tiny Linux + XBMC) and you won't have to worry about anything.
eskro Wrote:hello bluray. dont take it bad
ok, see you there
Thanks...here is my new thread:
Zotac Zbox or ASRock E350M1 Zacate
I've looked over the HTPC recommendations and quite a few other forums and have concluded my build on paper. Let me know if this works and if it all seems compatible as it will be my first time building a pc.
http://forum.xbmc.org/showthread.php?p=8...post810519
Thanks for any and all help.
Just curious about the switch to a 520 instead of the cheaper 430, any reason for switching in particular?
Ah well that does make sense about the fanless, but it's $10 more than the 430.
How similar is the performance between the two of them?
hi braoru, as i said to many, again,
can you please create a new thread and copy paste what you wrote here?
i just dont want this current thread i made flooded with users builds questions,,,
ok, see you there
eskro Wrote:hi braoru, as i said to many, again,
ok, see you there
Done (sorry for the thread spam
http://forum.xbmc.org/showthread.php?p=8...post816885
I found a thread that someone mentions the 520 doesn't do well with deinterlacing video compared to the 430. Does anyone with experience know if this is true? Doesn't matter to me too much, I have a 430, but the fanless is appealing. The Asus I received does make a little bit of noise...
the Galaxy GT430 is
not Low Profile and has a fan, costs $43 after rebate
Asus GT430 is Low Profile but has a fan, costs $46 after rebate
the EVGA GT430 is also Low Profile but also has a fan, costs $48 after rebate
for $4 more then an ASUS GT430,
or for $2 more then an EVGA GT 430,
you can get your hands on this $50 ASUS GT520 which is Fanless & Low Profile too!!
http://ow.ly/1tt4cn
so i dont see where you get that --> GT520 costs $10 more then a GT430
if the GT520 has De-interlacing issues, and thats a if,
that can definitely be corrected by a futur Driver updates,,,,
i wouldnt worry at all,,,
