Hi whjsdk!
Like i asked many users by now,
could you please create a new thread completely about your build?
you'll have better support from users if u do,,
eskro Wrote:something like this http://forum.xbmc.org/showthread.php?tid=93846
Eskro,
You proposed the above to be able to handle:
1080P XBMC
Web Browsing
YouTube, Netflix
Sabnzbd, Sickbeard, Couchpotato - DL and unpack files, then move to a directory on a USB connected Drive
Looking for the quietest, most power efficient and cool-running solution, will Zacate solution (
http://forum.xbmc.org/showthread.php?p=7...post727463) have trouble running these tasks?
Specifically, there may be an instance where a 1080p movie is being played while a Sabnzbd download is running and may subsequently be extracted.
Honestly, i think i recall PoofHairGuy saying he's running those apps on his HTPC,,,
or at least, one of them,,,,
Maybe he could jump in here and tell us which CPU power he suggest for those tasks...
But, to my experience, the more u wanna do with your PC,
its always better to get 'more' powerful CPU...
So for multi-tasking, AMD Quad-Cores are great
and on the INTEL's side, i think you should be fine with a G620 CPU,,,,
Hey Eskro,
Are the AMD's APU's as powerfull as the Sandy Bridge Intel's? And you have any idea if XBMC has the same (DXVA) issues with the APU's onboard GPU's?
I'm currently looking into the Sandy Bridge processors. The raw processor speed really has me thinking, especially since I will be doing a lot of emulation in my HTPC. However, if I instal a seperate video card like an NVIDIA G-FORCE, i will not have the typical intel trouble in XBMC, I hope? Is that correct?
thanks,
Grave
eskro Wrote:Q. Out of those builds, which one can Bitstream DOLBY TRUE-HD & DTS-HD MASTER audio?
A. Except the mini-ITX Zacate build, none of them till you add one of these 2 GPU Cards:
ASUS HD5450 512MB DDR3 64-Bit Fanless Low Profile ($36 + $0) (Windows OS only)
ASUS GT430 1GB DDR3 128-bit Low Profile ($66 + $0)
(Note that as of today, XBMC can't natively Bitstream HD-Audio)
I'm a bit confused by the comment that XBMC can't natively bitstream HD audio. Does this mean this is only possible via an external player? Or in windows is this possible using the DSplayer in XBMC?
Also will the new audio engine make this native to XBMC?
In your Q&A section you say:
Quote:Q. Out of those builds, which one can play 3D 1080P movies?
A. None of them till you add this GPU Card:
ASUS GeForce GT430 1GB DDR3 128-bit Low Profile
Is this with the use of XBMC or do you mean in general?
Since in
this review they do play a 3D blu-ray.
Albeit that's not with XBMC hence my question
I've gotten almost no help from the thread I created, so I figured I might get some more help here.
My 12 year old Pentium 3 HTPC has finally kicked the bucket, so I'm looking for recommendations on a new build. I'm fine with AMD or Intel, I've built systems using both. I have an 8400GS PCI card from the old box that I could use as long as I keep it mini-ITX. I'd like it to satisfy the following:
- Very small, the smaller the better
- Efficient
- 2D 1080P high bitrate Rips
- Game Emulators (SNES, N64)
- I'd prefer a power brick instead of an internal PSU, but I wouldn't be against one.
I do have a Microcenter 30 minutes away if it helps. I wish I got in on the Antec ISK-300 for $35 a few weeks ago, I would've just used that.
Lexicon44 Wrote:Eskro,
1080P XBMC
Web Browsing
YouTube, Netflix
Looking for the quietest, most power efficient and cool-running solution, will Zacate solution (http://forum.xbmc.org/showthread.php?p=7...post727463) have trouble running these tasks?
Sab does not take a lot of processor power. I ran it for while on Acer Revo in the background. Two things I would say to eliminate performance interference with XBMC.
1. Set SAB to pause downloading while unpacking (which is in config settings). Greatly reduces processor impact. As soon as its done unpacking most recent download it picks back up on the remaining ones. Really does not slow you down much.
2. Cap the download rate if you ever use XBMC with streaming plug-ins to give yourself just enough bandwidth so downloads don't interfere with video streams. Kind of obvious I know but the one time I noticed downloads was trying to watch icefilms while downloading on my Ion 330 Revo. Capping download rate in SAB settings made all the difference.
Superorb Wrote:Sorry about that, I should've included a budget. I have read that the Zacate boards (AMD 350) do not work well with XBMC Live or with game emulators. I'd love to get an integrated solution, but I'm not sure if it will run an n64 Emu.
I've read that the PSU in that MI-008 case isn't very good, plus it gets in the way. Would it be possible to use a PicoPSU and fill in the hole in the back?
check this-
Tested with AMD Zacate E-350:. i haven't had any issue with apec psu, and i never turn off my htpc either. it's easier for my wife, sons and daughters to operate it!
bluray Wrote:check this- Tested with AMD Zacate E-350:. i haven't had any issue with apec psu, and i never turn off my htpc either. it's easier for my wife, sons and daughters to operate it!
How about the E350 in XBMC Live and with 1080p high bitrate?
I keep reading that the E350 platform should only be used with Windows, and I refuse to buy a Win7 license just to run XBMC.
