Full Version: [WIP] HTPC-Manager Beta, Manage XBMC, Sabnzbd, SickBeard with one app
Still not working.
Could it be because my install directory is in /home/xbmc/HTPC-Manager?
The user name is xbmc that I ssh in under.
'sudo service htpc start' works fine if I ssh in.
depends if you logon as xbmc on boot, check you /var/log/syslog for messages.
Set permissions on your HTPC-manager directory to 777
also (forgot to mention) type
initctl reload-configuration
and reboot. should work
This still isn't autostarting.
'sudo service htpc start' works fine.
Two ideas....
Is my directory '/home/xbmc/HTPC-Manager/' a directory the startup script can't for some reason access?
Is it possible my script is running to early, before something necessary has started up?
not that complicated, as long as you placed the .conf file in /etc/init.
executed
and
sudo chmo -R 777 /home/xbmc/HTPC-Manager/
Check you /var/log/upstart folder. there should be a log file for each service started with upstart. in particular htpc.log (if you named your file htpc.conf)
...check your /var/log/boot.log for an entry of htpc service.
...check your upper and lower case with files names. I know if seems obvious, but it happens to me all the time. .
that should give you an idea of what is going on.
I'll note that it looks like it tries to start more then once, but each time this is the error I get.
Starting HTPC Manager on port 8099.
Start your browser and go to http://localhost:8099/
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Listening for SIGHUP.
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Listening for SIGTERM.
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Listening for SIGUSR1.
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Bus STARTING
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Started monitor thread '_TimeoutMonitor'.
2014-03-25 14:56:49 :: cherrypy.error :: ERROR :: [25/Mar/2014:14:56:49] ENGINE Error in HTTP server: shutting down
File "/home/xbmc/HTPC-Manager/libs/cherrypy/process/servers.py", line 187, in _start_http_thread
self.httpserver.start()
File "/home/xbmc/HTPC-Manager/libs/cherrypy/wsgiserver/wsgiserver2.py", line 1824, in start
raise socket.error(msg)
error: No socket could be created
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Bus STOPPING
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE HTTP Server cherrypy._cpwsgi_server.CPWSGIServer(('192.168.4.101', 8099)) already shut do
wn
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Stopped thread '_TimeoutMonitor'.
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Bus STOPPED
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Bus EXITING
2014-03-25 14:56:49 :: cherrypy.error :: INFO :: [25/Mar/2014:14:56:49] ENGINE Bus EXITED
Edit : Thought I had it working and it isn't. I'm out of ideas.
I tried various sleeps just for a test.
I tried 'start on started networking' and it was insufficient.
(2014-03-25, 10:37)Jeremy White Wrote: [ -> ]Edit : Thought I had it working and it isn't. I'm out of ideas.
At least you know the service is starting on reboot.
I see it is starting on a port that is not the default, is that port already being used by something else?
try adding the --port 8085 to the exec line.
maybe hellow or styxit can share their thoughts on the error you are receiving.
I'm afraid I can't assist you I know nothing about Linux, infact init and permissions is the main reason I stay away :p
(2014-03-25, 08:59)Jeremy White Wrote: [ -> ]2014-03-25 14:56:49 :: cherrypy.error :: ERROR :: [25/Mar/2014:14:56:49] ENGINE Error in HTTP server: shutting down
I lam leading to say the port is already in use. but hey i don't call my self and expert.
(2014-03-25, 19:33)ylafont Wrote: [ -> ]
(2014-03-25, 08:59)Jeremy White Wrote: [ -> ]error: No socket could be created
I would second that, saying no socket could be created is generally the case of the port being in use. BTW that has nothing to do with Linux and is a Python output.
It certainly has nothing to do with a port being in use.
Well, no port will work. It's like the network isn't there yet!?
(2014-03-29, 04:28)Jeremy White Wrote: [ -> ]It certainly has nothing to do with a port being in use.
i tested it and got the same error.- 99% sure it is the port in use.
try turning off the firewall. sudo ufw disable
Actually didn't have ufw installed.
I installed it, and then disabled it.
I also flushed -F the iptables.
No change.... still stuck. Any other ideas?
(2014-04-05, 10:38)Jeremy White Wrote: [ -> ]Actually didn't have ufw installed.
I got nothing else, maybe someone with more experience can assist.
You might try putting this in your init.d file:
# Should-Start:      $NetworkManager
# Should-Stop:       $NetworkManager
Can't say it will fix your problem, but it does sound to me like the system is trying to start your script before the network.
