Merc33
I honestly find it terribly hard to believe it takes near that long on a i5, can you post your settings.xml and settings2.xml for review?
Watch this video below, you can see from my end it doesn't take long to switch channels:
https://www.youtube.com/watch?v=xRXsiUZ_BDQ , look at video info for system specs. I have 13/15TB over samba share, all added to ptvl.
Also there are major difference between pseudotv and pseudotv live, if i had to guess less than 25% of it is old code at this point.
Major improvements have been made, but you can not assume its just like pseudotv and configure accordingly things have changed. Plus the original was designed for dharma, whereas the latest ptvl supports jarvis we are talking about six kodi version!! time for you to update!
One thing that's often misunderstood is the complexity involved with a script like this, there are so many variables outside the scope of ptvl that can greatly impact performance.
I strongly believe the heart of this issues is in the belief something is wrong with ptvl instead of debugging your end. I understand coming from the developer you want to take that information as bias, but I gain nothing from wasting my time developing software that doesn't work. The amount of time and effort I put into this project would be worthless if it worked as you claim.
BTW I run PTVL on 3boxes 24/7 in my household.
Intel core duo
Intel quad core 9550
raspberry pi b
all function great, speedy channel changes and building.
PS
It appears by your other posts you have an underlying issue :
http://forum.kodi.tv/showthread.php?tid=161298
PSS
Looking further into your problem, by your posts am I to assume you have 999 PseudoTV Live channels set to unlimited and your storage solution is usb 2.0 drives over your router's nas?
I don't see how even on the original pseudotv that would run smoothly.
