(2016-01-28, 15:49)Lunatixz Wrote: [ -> ] (2016-01-28, 15:27)bry- Wrote: [ -> ] (2016-01-28, 15:08)Lunatixz Wrote: [ -> ]Can you tell me the full name for the hgtv plugin? Ex. plugin.video.?
plugin.video.hgtv
plugin.video.hgtv.canada (which works in the us btw)
Which one was causing the above issues?
For me it was the plugin.video.hgtv
(2016-01-28, 20:26)schurricaneinfo Wrote: [ -> ] (2016-01-28, 15:49)Lunatixz Wrote: [ -> ] (2016-01-28, 15:27)bry- Wrote: [ -> ]plugin.video.hgtv
Next update will feature a debugging option that will allow users to select plugins to exclude from "seeking". Meaning... plugins that feature sources that don't play well to player seeking can be disabled and content will start from the beginning.
(2016-01-28, 20:37)Lunatixz Wrote: [ -> ] (2016-01-28, 20:26)schurricaneinfo Wrote: [ -> ] (2016-01-28, 15:49)Lunatixz Wrote: [ -> ]Which one was causing the above issues?
Do you think that will solve the problems with PlayOn streams some of us have been having?
(2016-01-28, 20:38)jctennis Wrote: [ -> ] (2016-01-28, 20:37)Lunatixz Wrote: [ -> ] (2016-01-28, 20:26)schurricaneinfo Wrote: [ -> ]For me it was the plugin.video.hgtv
last build I disabled playon seeking thru chtype 16 aka Direct UPNP channel... if u r using playonbrowser then yes.
(2016-01-28, 20:44)Lunatixz Wrote: [ -> ] (2016-01-28, 20:38)jctennis Wrote: [ -> ] (2016-01-28, 20:37)Lunatixz Wrote: [ -> ]Next update will feature a debugging option that will allow users to select plugins to exclude from "seeking". Meaning... plugins that feature sources that don't play well to player seeking can be disabled and content will start from the beginning.
You are completely awesome! I've been ripping my hair out (figuratively speaking) trying to figure that out for an article.
(2016-01-28, 20:45)jctennis Wrote: [ -> ] (2016-01-28, 20:44)Lunatixz Wrote: [ -> ] (2016-01-28, 20:38)jctennis Wrote: [ -> ]Do you think that will solve the problems with PlayOn streams some of us have been having?
Playon 4 broke something? because playon 3 had great seek support (from what I remember)... I've noticed in 4 a screen that says Video isn't ready or something to that effect...
(2016-01-28, 20:48)Lunatixz Wrote: [ -> ] (2016-01-28, 20:45)jctennis Wrote: [ -> ] (2016-01-28, 20:44)Lunatixz Wrote: [ -> ]last build I disabled playon seeking thru chtype 16 aka Direct UPNP channel... if u r using playonbrowser then yes.
Well it might be dirty but I'll take it.
Ok so far this newbie has been able to load my HD home run channels,google ones that load which are quite a few and finally now tried the basic USTV channels as well. It seems after loading the USTV basic ones I lost the google ones I had and cannot seem to get them to reload anymore even with the USTV ones. I dumped all the saved files as well as the backup ones too.I have the number of channels set to 1000.
I also forgot to ask if there is a way to get the other ones that are not accessible on the page to load channel groups by being a paid member.
I still despite reading the faq have not found a solution to the continuous channel rebooting to a different channel
Thank you again
(2016-01-28, 23:22)nb2a Wrote: [ -> ]Ok so far this newbie has been able to load my HD home run channels,google ones that load which are quite a few and finally now tried the basic USTV channels as well. It seems after loading the USTV basic ones I lost the google ones I had and cannot seem to get them to reload anymore even with the USTV ones. I dumped all the saved files as well as the backup ones too.I have the number of channels set to 1000.
Thank you again
What google ones? USTVnow will be built into the next update to reduce user setup issues.
Sorry meant to say you tube. I have google on my mind!
(2016-01-29, 00:26)nb2a Wrote: [ -> ]Sorry meant to say you tube. I have google on my mind!
np, a lot of your answers can be found in the FAQ, channels don't just disappear for no reason
If you feel there is a bug, please submit a log... Thanks
It seems in the progress window I see more channels including the youtube ones loading on startup but they do not seem visible finalized in the EPG as before after add on opens up.Could there be a setting in the EPG I am missing? I also do not see any way to get to top task bar in EPG either. Is that not accessible via keyboard or mouse?
Thank you again
(2016-01-28, 06:04)nb2a Wrote: [ -> ]Live TV and google channels working great. Just keep having channels changing randomly often.
Glad, channel changing also in faq
Please let me know if the info fixes your problems
[/quote]
Still no luck to see in faq why my youtube channels are not appearing in guide like before.I see them loading on initial start but no where to be found. I also am having trouble uploading a log.
(2016-01-29, 03:59)nb2a Wrote: [ -> ]It seems in the progress window I see more channels including the youtube ones loading on startup but they do not seem visible finalized in the EPG as before after add on opens up.Could there be a setting in the EPG I am missing? I also do not see any way to get to top task bar in EPG either. Is that not accessible via keyboard or mouse?
Thank you again
[/quote]
Since I cannot seem to load as many channels on youtube as I previously did can a channel like Twit TV on youtube be added without much of an issue? Is there any link to provide that info?
Thanks again
