Full Version: [RELEASE] Flix2Kodi - Just another Netflix-Addon
Not sure if this is a plugin or chrome thing. I used to have xetflixbmc. I have ubuntu / Xtool / Chrome installed.
SInce then, I deleted the plugin and started from scratch. When I launch flix2kodi it works fine, gets to chrome starts playing.
The remote i have works in chrome for everything except the "continue watching" prompt.
Is there a way to map my remote to continue playing or click an XY co-ordinate. I have forgotten how it was all setup.
(2016-01-24, 02:31)thekow Wrote: [ -> ]Not sure if this is a plugin or chrome thing. I used to have xetflixbmc. I have ubuntu / Xtool / Chrome installed.
if you're using the chromium remote addon you can press 'info' on your remote to enter mouse mode
(2016-01-24, 02:53)tree_and_kite Wrote: [ -> ]if you're using the chromium remote addon you can press 'info' on your remote to enter mouse mode
I don't think i am using any add-on. But maybe i should check it out.
(2016-01-23, 06:37)sirhcjw Wrote: [ -> ]Just curious but what happens if you try to play a Netflix video directly from your web browser as apposed from the this Kodi addon?
In IE, chrome, ffox it works flawlessly. I want to use IE though for 1080p playback. As far as I know Chrome and Ffox doesn't support 1080.
(2016-01-20, 21:33)CountBor Wrote: [ -> ][quote='mhoogenbosch' pid='2218320' dateline='1453103381']
[quote='knives of ice' pid='2218161' dateline='1453081918']
does anyone have instructions they can write to make this work with OpenElec?
* Copy widevine from the Chrome distro for AMD64 Debian as described in Step #2 of thread
Note: I recall having difficulty finding the right folder to copy to but forgot to write it down. Can look it up if needed.
Where did you get the widevine file as when I click on link on instructions, it just takes me the chrome download page in German?
Thank You
(2016-01-24, 12:30)calisto Wrote: [ -> ]
Thank You
Select the link to download for other platforms (probably depends on what OS you are using, in my case Windows but you need the Linux distro).
Select Linux, and in the popup select 64bit Debian. This downloads a file google-chrome-stable_current_amd64.tar which you can unpack using e.g. 7zip.
In google-chrome-stable_current_amd64\opt\google\chrome you will find libwidevinecdm.so , copy that one to your OpenElec.
I did it like this: copy it to the SMB share Downloads that OpenElec has, then in a Putty session copy the file from there (~/downloads) to ~/.kodi/addons/browser.chromium/bin
Word of warning: my install stopped working yesterday, complaining that it cannot load this library. I found out Chromium auto updated to 7.0. Not sure that one can work but I decided to uninstall, install 6.0.4 again as per the instructions, copied the lib again, and things work again. Disabled Chromium auto updating for now.
Here is the error from the log re: updating playcount:
20:39:36 T:4260   ERROR: [plugin.video.flix2kodi] Traceback (most recent call last):
                                              File "C:\Users\saans\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\play.py", line 106, in playInternal
                                                self.update_playcount(video_id)
                                              File "C:\Users\saans\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\play.py", line 114, in update_playcount
                                                library.update_playcounts()
                                              File "C:\Users\saans\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\library.py", line 107, in update_playcounts
                                                playback_infos = get.video_playback_info(video_ids)
                                              File "C:\Users\saans\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\get.py", line 304, in video_playback_info
                                                content = connect.load_netflix_site(generic_utility.evaluator(), post=post_data)
                                              File "C:\Users\saans\AppData\Roaming\Kodi\addons\plugin.video.flix2kodi\resources\connect.py", line 130, in load_netflix_site
                                                raise ValueError('!HTTP-ERROR2!: '+str(status_code)+' loading: "'+url+'", post: "'+ str(post)+'"')
                                            ValueError: !HTTP-ERROR2!: 504 loading: "https://www.netflix.com/api/shakti/3f8e19be/pathEvaluator?materialize=true&model=harris", post: "{"paths": [["videos",["70143468","70143469","70143470","70143471","70143472","70143473","70143474","70143475","70143476","70143477","70143478","70143479","70143480","70143482","70143483","70143484","70143485","70143486","70143487","70143488","70143489","70143490","70143491","70143492","70143493","70143494","70143495","70143496","70143497","70143498","70143499","70143500","70143502","70143503","70143504","70143505","70143506","70143507","70143508","70143509","70143510","70143511","70143512","70143513","70143514","70143515","70143516","70143517","70143519","70143533","70143520","70143518","70143521","70143522","70143523","70143524","70143525","70143526","70143527","70143528","70143529","70143530","70143531","70143532","70143534","70143535","70143536","70143537","70143538","70143539","70143540","70143541","70143542","70143543","70143544","70143545","70143546","70143547","70176632","70176633","70176634","70176635","70176636","70176637","70176638","70176639","70176640","70176641","70176642","70176643","70176644","70176645","70176646","70176647","70176648","70176649","70233187","70233188","70233189","70233190","70233191","70233192","70233193","70233194","70233195","70233196","70233197","70233198","70233199","70233200","70233201","70233202","70233203","70233204","70233205","70272646","70272647","70272648","70272649","70272650","70272651","70272652","70272653","70272654","70272655","70272656","70272657","70272658","70272659","70272660","70272661","70272662","70272663","70305301","70305302","70305303","70305304","70305305","70305306","70305307","70305308","70305309","70305310","70305311","70305312","70305313","70305314","70305315","70305316","70305317","70305318","70305319","80045446","80045447","80045448","80045449","80045450","80045451","80045452","80045453","80045454","80045455","80045456","80045457","80045458","80045459","80045460","80045461","80045462","80045463","80045464","80045465","70138593","70138594","70138596","70138595","70138597","70138598","70138599","70138600","70138601","70138602","70225764","70225765","70225766","70225767","70225768","70225769","70225770","70225771","70225772","70225773","70225774","70225776","70225778","70251198","70251199","70251200","70251202","70251203","70251204","70251205","70251201","70251207","70251206","70251208","70251209","70251210","70272488","70272489","70272490","70272491","70272492","70272493","70272494","70272495","70272496","70272497","70272498","70272499","70272500","70301372","70301373","70301374","70301375","70301376","70301377","70301378","70301379","70301380","70301381","70301382","70301383","70301384","80046146","80046147","80046148","80046149","80046150","80046151","80046152","80046153","80046154","80046155","80046156","80046157","80046158","70133673","70133674","70133675","70133677","70133678","70133676","70133679","70133680","70133681","70133682","70133683","70133684","70133685","70133686","70133687","70133689","70133690","70133688","70133691","70133692","70133693","70133694","70133695","70133696","70133697","70133698","70133699","70133700","70133701","70133702","70133703","70133704","70133705","70133706","70133707","70133708","70133711","70133709","70133710","70133712","70133713","70133714","70133715","70133716","70133717","70133718","70133720","70133719","70133721","70133722","70133723","70133724","70133725","70258267","70258269","70258271","70258268","70258273","70258270","70258274","70258272","70270313","70258276","70260130","70258275","70258278","70258277","70258279","80010745","80010746","80010747","80010748","80010749","80010750","80010751","80010752","80010753","80010754","80010755","80010756","80010757","70225461","70225462","70225463","70225464","70225465","70225466","70225467","70225468","70293523","70293524","70293525","70293526","70293527","70293528","70293529","70293530","70293531","70293532","70196252","70196253","70196254","70196255","70196256","70196257","70196258","70196259","70196260","70196261","70196262","70196263","70196264","70196265","70196266","70196267","70196268","70196269","70196270","70196271","70196272","70196273","70196274","70196275","70196276","70196277","70196278","70196279","70196280","70196281","70196282","70196283","70196284","70236035","70236036","70236037","70236038","70236039","70236040","70236041","70236042","70236043","70236044","70236045","70236046","70236047","70236412","70236413","70236414","70236415","70236416","70236417","70236418","70236419","70236421","70236422","70236423","70236424","70236425","70236426","70236427","70236428","70133726","70133727","70133728","70133729","70133730","70133731","70133732","70133733","70133734","70133735","70133736","70133737","70133738","70133739","70133740","70133741","70133742","70133743","70133744","70133745","70133746","70133747","70133748","70133749","70133751","70133752","70133753","70133754","70133755","70133757","70133758","70133759","70133760","70133761","70133762","70133763","70133764","70133765","70133766","70133767","70133768","70133769","70133770","70133771","70133772","70133773","70133774","70133775","70133776","70133777","70133778","70133779","70133780","70133781","70133782","70133783","70133784","70133785","70133786","70133787","70133788","70133789","70133790","70133791","70133792","70133793","70133794","70133795","70133796","70133797","70133798","70133799","70133800","70133801","70133802","70133803","70133804","70133805","70133806","70133807","70133808","70133809","70133810","70133811","70133812","70133813","70133814","70133815","70133816","70133817","70133818","70133819","70133820","70133821","70133822","70133823","70133824","70133825","70133826","70133827","70133828","70133829","70133830","70133831","70133832","70133833","70133834","70133835","70133836","70133837","70133838","70133839","70133840","70133841","70133842","70133843","70133844","70133845","70133846","70133847","70133848","70133849","70133850","70133851","70133852","70135780","70135781","70133853","70133854","70133855","70133856","70133857","70133858","70133859","70133860","70133861","70133862","70133863","70133864","70133865","70133866","70133867","70133868","70133869","80007951","80007950","80007948","80007947","80007946","80007949","70145806","70145807","70145808","70145809","70145810","70145811","70145812","70145813","70145814","70145815","70145816","70145817","70145818","70145819","70145820","70145821","70145822","70145823","70145824","70145825","70145826","70145827","70145828","70145829","70145830","70145832","70145834","70145833","70145835","70145836","70145837","70145838","70145839","70145841","70145840","70145853","70145842","70145843","70145845","70145844","70145846","70145847","70145848","70145849","70145850","70145851","70145852","70145854","70145855","70251220","70251221","70251222","70251223","70251224","70251225","70251226","70251227","70251228","70251229","70251230","70251231","70251232","70251233","70251234","70251235","70251236","70251237","70251238","70251239","70251240","70251241","70279008","70279010","70279011","70279009","70279012","70279015","70279013","70279014","70279020","70279016","70279017","70279019","70279018","80028647","80028648","80028649","80028650","80028651","80028652","80039022","80028733","80028734","80028735","80028736","80028737","80028738","80028739","70258471","70258477","70258478","70258479","70258480","70258481","70258482","70305584","70305585","70305586","70305587","70305588","70305589","80038437","70085714","70085715","70085716","70085717","70085718","70085719","70085720","70085721","70085722","70085723","70085724","70085725","70077035","70119583","70119584","70119585","70119586","70119587","70119588","70119589","70119590","70119591","70119592","70119593","70206691","70206692","70206693","70206694","70206695","70206696","70206697","70206698","70206699","70206700","70206701","70206702","70126613","70213516","70213517","70213518","70213519","70213520","70213521","70213522","70213523","70213524","70213525","70213526","70249844","70249845","70249846","70249847","70249848","70249849","70249850","70249851","70249852","70249853","70249854","70249855","70250623","70250624","70250625","70250626","70250627","70250628","70250629","70250630","70250631","70250632","70250633","70250634","70261662","70261663","70261664","70261665","70261666","70261667","70261668","70261669","70261670","70261671","70261672","70261673","70282442","70282443","70282444","70282445","70282446","70282447","70282448","70282449","70282450","70282451","70282452","70282453","70263213","70263214","70263215","70263216","70263217","70263218","70263219","70263220","70263221","80011645","80011646","80011647","80011648","80011649","80011650","80011651","80011652","80011653","70287352","70287353","70287354","70287355","70287356","70287357","70287358","70287359","70287360","70287365","70287366","70287367","70287368","70287369","70287370","70287371","70294099","70294100","70294101","70294102","70294103","70294104","70294105","70294106","70294107","70140563","70140564","70140565","70140566","70140567","70140568","70140569","70276722","70276723","70276724","70276725","70276726","70276727","70276728","70276729","70276730","70276731","70276732","70276733","70276734","70276735","70276736","70276737","70276738","70276739","70276740","70276741","70276742","70276743","70276744","70286757","70286758","70286759","70286760","70286761","70286762","70286763","70286764","70286765","70286766","70286767","70286768","70286769","70286770","70286771","70286772","70286773","70286774","70286775","70286776","70286777","70286778","70286779","80018562","80018563","80018564","80018565","80018566","80018567","80018568","80018569","80018570","80018571","80018572","80018573","80018582","80018574","80018575","80018576","80018577","80018578","80018579","80018580","80018581","70140570","70140571","70140572","70140573","70140574","70140575","70140576","70140577","70140578","70140579","70140580","70140581","70140582","70140583","70140584","70140585","70140586","70140587","70140588","70140589","70140590","70140591","70140592","70140593","70140594","70140595","70140596","70140597","70140598","70140599","70140600","70140601","70140602","70140603","70140604","70140605","70140606","70140607","70140608","70140609","70140610","70140611","70140612","70140613","70140614","70140615","70140616","70140617","70140618","70140619","70140620","70140621","70140622","70140623","70140624","70140625","70140626","70140627","70140628","70140629","70140630","70140631","70140632","70140633","70140634","70140635","70140636","70140637","70140638","70140639","70140640","70140641","70140642","70140643","70140644","70140645","70140646","70140647","70140648","70140649","70140650","70140651","70140652","70140653","70140654","70140655","70140656","70140657","70140658","70140659","70140660","70140661","70140663","70140664","70140665","70140666","70140667","70140668","70140669","70140670","70140671","70140672","70140673","70140674","70140675","70140676","70140677","70140678","70140679","70140680","70140681","70140682","70140683","70140684","70140685","70140686","70140687","70140688","70140689","70140690","70226296","70226297","70226298","70226299","70226300","70226301","70226302","70226303","70226304","70226305","70226306","70226307","70226308","70226309","70226310","70226311","70226312","70226313","70226314","70251729","70251730","70251731","70251732","70251733","70251734","70251735","70251736","70251737","70251738","70251739","70251740","70251741","70251742","70251743","70251744","70251745","70251746","70251747","70251748","70125664","70125666","70125668","70125667","70125670","70125669","70125665","70125671","70125672","70125673","70125674","70125676","70125675","70125677","70125678","70125679","70125680","70125681","70125682","70125683","70125684","70125685","70125687","70125688","70125689","70125690","70125692","70125691","70125693","70125686","70125694","70125698","70125695","70125696","70125697","70125699","70125700","70125701","70125702","70125703","70125704","70125705","70125706","70125707","70125708","70125709","70125710","70125711","70125712","70125713","70125714","70125715","70125716","70125717","70125718","70125719","70125720","70125721","70125722","70125723","70125724","70125725","70125726","70125727","70125728","70125729","70160401","70160402","70160403","70160404","70160405","70160406","70160407","70160408","70160409","70160410","70160411","70160412","70160413","70160414","70160415","70160416","70160417","70160418","70160419","70160420","70160421","70160422","70133870","70133871","70133872","70133873","70133874","70133875","70133876","70133877","70133878","70133879","70133882","70133883","70133880","70133881","70253712","70253713","70253714","70253715","70253716","70253717","70253718","70253719","70253720","70253721","70253722","70253723","70253724","70253725","70253726","70253727","70253728","70253729","70244971","70244972","70244973","70244974","70244975","70244976","70244977","70244978","70244979","70244980","70271487","70271488","70271489","70271490","70271491","70271492","70271493","70271494","70271495","70271496","70288841","70288842","70288843","70288844","70288845","70288846","70288847","70288848","70288849","70288850","80010544","80010545","80010546","80010547","80010548","80010549","80010550","80010551","80010552","80010553","80010554","80010555","80010556","70080178","70080179","70080180","70080181","70080182","70080183","70080184","70080185","70080186","70080187","70080188","70080189","70080190","70080191","70080192","70080193","70080194","70080195","70080196","70080197","70080198","70080199","70080200","70080201","70080202","70080203","70080204","70080205","70080206","70080207","70080208","70080209","70080210","70080211","70107636","70107637","70107638","70107639","70108325","70108326","70108327","70108328","70108329","70108330","70108331","70108332","70111773","70111774","70111775","70111776","70111777","70111778","70111779","70111780","70111781","70111782","70111783","70111784","70115378","70125812","70125813","70125814","70125815","70125816","70125817","70125818","70125819","70125820","70125821","70125822","70125823","70125824","70125825","70125826","70125827","70125828","70125829","70241855","70241856","70241857","70241858","70241859","70241860","70241861","70241862","70241863","70241864","70241865","70241866","70279811","70279812","70279813","70279814","70279815","70279816","70279817","70279818","70279819","70279820","70279821","70279822","70307943","70307944","70307945","70307946","70307947","70307948","70307949","70307950","70307951","70307952","70307953","70307954","70248289","70248290","70248291","70248292","70248293","70248294","70248295","70248296","70248297","70248298","70248299","70248300","70248301","70293579","70293580","70293581","70293582","70293583","70293584","70293585","70293586","70293587","70293588","70293589","70293590","70293591","80017461","80017462","80017463","80017464","80017465","80017466","80017467","80017468","80017469","80017470","80017471","80017472","80017473","70107773","70107774","70107775","70107776","70107777","70107778","70107779","70107780","70107781","70107782","70107783","70107785","70107786","70107787","70107788","70107789","70107790","70107791","70107792","70107793","70107794","70107795","70107796","70107797","70107798","70107799","70107800","70107801","70107802","70207871","70207872","70207873","70207874","70207875","70207876","70207877","70207878","70207879","70207880","70222562","70222563","70222564","70222565","70222566","70222567","70222568","70222569","70293570","70293571","70293572","70293573","70293574","70293575","70293576","70293577","80017332","80017333","80017334","80017335","80017336","80017337","80017338","80017339","70122768","70122769","70122770","70122771","70122772","70122773","70122774","70122775","70122776","70122777","70122778","70122779","70122780","70122781","70122782","70122783","70122784","70122785","70122786","70122787","70122788","70122789","70122790","70122791","70122792","70122793","70122794","70122795","70122796","70122797","70122798","70122799","70122800","70122801","70122802","70122803","70122804","70122805","70122806","70122807","70122808","70122809","70122810","70122811","70122812","70122813","70122815","70122816","70122817","70122818","70122819","70122820","70122821","70122822","70122823","70122824","70122825","70122826","70122827","70122828","70122829","70122830","70122831","70122832","70122833","70122834","70122835","70122836","70122837","70122838","70122839","70122840","70122841","70122842","70122843","70122844","70122845","70122846","70122847","70122848","70122849","70122850","70122851","70122852","70122853","70122854","70123451","70123452","70123453","70123454","70123455","70123456","70123457","70123458","70123459","70123460","70123461","70123462","70123463","70123464","70123465","70123466","70123467","70158375","70158376","70158377","70158378","70158379","70158380","70158381","70158382","70158383","70158384","70158385","70158386","70158387","70158388","70158389","70158390","70158391","70143379","70143380","70143381","70143382","70143383","70143384","70143385","70143386","70143387","70143388","70143389","70143390","70143391","70143392","70143393","70143394","70143395","70143396","70143397","70143398","70143400","70143399","70143401","70143402","70143403","70143404","70143405","70143406","70143407","70143408","70143409","70143410","70143411","70143412","70143413","70143414","70143415","70143416","70143417","70143419","70143420","70143421","70143422","70143423","70143424","70143425","70143426","70143427","70143428","70143429","70143430","70143431","70273597","70234807","70234808","70234809","70234810","70234811","70234812","70234813","70234814","70234815","70234816","70234817","70283567","70283568","70283569","70283570","70283571","70283572","70283573","70283574","70283575","70283576","70283577","70283578","80000771","80000772","80000773","80000774","80000775","80000776","80000777","80000778","80075830","80075831","70286478","70286479","70286480","70286481","70286482","70286483","70286484","70286485","70286486","70286487","80065723","80065724","80065725","80065730","80065726","80065727","80065728","80065729","80065731","80065732","70223239","70223240","70223241","70223242","70223243","70223244","70223246","70223247","70223248","70223249","70223250","70223251","70223252","70231827","70231828","70231829","70231830","70231831","70231832","70231833","70243087","70281330","70281331","70281332","70281333","70281334","70281335","70281336","70281337","70300892","70300893","70300894","70300895","70300896","70300897","70300898","70300899","80025313","80025314","80025315","80025316","80025317","80025318","80025319","80025320","80025321","80025322","70259443","70259444","70259445","70259446","70259447","70259448","70259449","70259450","70259451","70259452","70259453","70259454","70259455","70296528","70296529","70296530","70296531","70296532","70296533","70296534","70296535","70296536","70296537","70296538","70296539","70296540","80017448","80017449","80017450","80017451","80017452","80017453","80017454","80017455","80017456","80017457","80017458","80017459","80017460","70207859","70207860","70207861","70207862","70207863","70207864","70207865","70207866","70207867","70207868","70207869","70222162","70222163","70222164","70222165","70222166","70222167","70236270","70236271","70236272","70236273","70236274","70236275","70236276","70236277","70236278","70236279","70253124","70270327","70236291","70236281","70236282","70236283","70236284","70236285","70236286","70236287","70236288","70236289","70236290","70152101","70152102","70152103","70152104","70152105","70152106","70152107","70152108","70152109","70152110","70152111","70152112","70152113","70152114","70152115","70152116","70152117","70152118","70152119","70152120","70152121","70152122","70152123","70152124","70152125","70152126","70152127","70152128","70152129","70152130","70152131","70152132","70152133","70152134","70152135","70152136","70152137","70152138","70152139","70152140","70152141","70152142","70152143","70152144","70152145","70152146","70152147","70152148","70152149","70152150","70152151","70152152","70152153","70152154","70152155","70152156","70152157","70152158","70152159","70152160","70152161","70152162","70152163","70152164","70152165","70152166","70152167","70152168","70152169","70152170","70152171","70152172","70152173","70152174","70152175","70152176","70152177","70152178","70152179","70241738","70241739","70241740","70241741","70241742","70241743","70241744","70241745","70241746","70241747","70241748","70241749","70241750","70241751","70241752","70241753","70306731","70306732","70306733","70306734","70306735","70306736","70306737","70306738","70306739","70306740","70306741","70306742","70306743","70306744","70306745","70307750","70307751","70307752","70307753","70307754","70307755","70307756","70307757","70307758","70307759","70274259","70274260","70274261","70274262","70274263","70274264","80002845","80002846","80002847","80002848","80002849","80002850","80002851","80002852","80002853","80002854","80047617","80047618","80047619","80047620","80047621","80047622","70284246","70284247","70284248","70284249","70284250","70284251","70284252","70284253","80022705","80022706","80022707","80022708","80022709","80022710","80022711","80022712","80046988","80046989","80046990","80046991","80046992","80046993","80046994","80046995","70160061","70160062","70160063","70160064","70160065","70160066","70160067","70160068","70160069","70160070","70160071","70160072","70160073","70160074","70160075","70160076","70160077","70160078","70160079","70160080","70160081","70160082","70160083","70160084","70160085","70160086","70160087","70160088","70160089","70160090","70160091","70160092","70160093","70160094","70160095","70160096","70160097","70160098","70160099","70160100","70160101","70160102","70160103","70160104","70160105","70160106","70160107","70160108","70160109","70160110","70160111","70160112","70160113","70160114","70160115","70160116","70160117","70160118","70160119","70160120","70160121","70160122","70160123","70160124","70160125","70160126","70160127","70160128","70160129","70160130","70160131","70160132","70160133","70160134","70160135","70160136","70160137","70160138","70160139","70160140","70160141","70160143","70160142","70160144","70160145","70160146","70160147","70160148","70160149","70160150","70160151","70160152","70160153","70160154","70160155","70160156","70160157","70160158","70160159","70160160","70160161","70160162","70160163","70160164","70160165","70160166","70160167","70160168","70160169","70160170","70160171","70160172","70160173","70160174","70160175","70160176","70160177","70160178","70160179","70160180","70160181","70160182","70160183","70160184","70160185","70160186","70160187","70160188","70160189","70160190","70160191","70160192","70160193","70160194","70160195","70160196","70160197","70160198","70160199","70160200","70160201","70160202","70160203","70160204","70160205","70160206","70160207","70160208","70160209","70160210","70160211","70160212","70160213","70160214","70160215","70160216","70160217","70160218","70160219","70160220","70160221","70160222","70160223","70160224","70160225","70160226","70160227","70160228","70160229","70160230","70160231","70160232","70160233","70160234","70160235","70160236","70160237","70160238","70160239","70160240","70160241","70160242","80025745","80025746","80025747","80025748","80025749","80025750","80025751","80025752","80025753","80025754","80025755","80025756","70174779","70174780","70174781","70229981","70229982","70229983","70297465","70297466","70297467","70306404","70306405","70306406","70279363","70279364","70279365","70279366","70279367","70279368","70279370","70279371","70279372","70279373","70279374","70279375","70300910","70300911","70300912","70300913","70300914","70300915","70177863","70177865","70177866","70177867","70177868","70177869","70177870","70177871","70177872","70177873","70177874","70177875","70177876","70177877","70177878","70177879","70177880","70177881","70177882","70177883","70177884","70177885","70177886","70177887","70177888","70177889","70177890","70177891","70177892","70177893","70177894","70177895","70177896","70177897","70177898","70177899","70177900","70177901","70177902","70177903","70177904","70177905","70177906","70177907","70177908","70177909","70177910","70177911","70177912","70177913","70177914","70177915","70177916","70177917","70177918","70177919","70177920","70177921","70177922","70177923","70177924","70177925","70177926","70177927","70177928","70177929","70177930","70177931","70177932","70177933","70177934","70177935","70177936","70177937","70177938","70177939","70177940","70177941","70177942","70177943","70177944","70177945","70177946","70177947","70177948","70177949","70177950","70177951","70177952","70177953","70177954","70177955","70177956","70177957","70177958","70177959","70177960","70177961","70177962","70177963","70177964","70177965","70177966","70177967","70177968","70177969","70177970","70177971","70177972","70177973","70177974","70177975","70177976","70177977","70177978","70177979","70177980","70177981","70177982","70177983","70177984","70177985","70177986","70177987","70177988","70177989","70177990","70177991","70177992","70177993","70177994","70177995","70177996","70177997","70177998","70177999","70178000","70178001","70178002","70178003","70178004","70178005","70178006","70178007","70178008","70178009","70178010","70178011","70178012","70178013","70178014","70178015","70178016","70178017","70178018","70178019","70178020","70178021","70178022","70178023","70178024","70178025","70178026","70178027","70178028","70178029","70178030","70178031","70178032","70178033","70178034","70178035","70178036","70178037","70178038","70178039","70178041","80052652","80052653","80052654","80052655","80052656","80052657","80052658","80052659","80052660","80052661","80052662","80052663","80052664","70283145","70283146","70283147","70283148","70283149","70283150","70283151","70283152","70283153","70283154","70283155","70283156","70283157","70283158","70283159","70283160","70283161","70283162","70283163","70283164","70283165","70291038","70291039","70291040","70291041","70291042","70291043","70291044","70291045","70291046","70291047","70291048","70291049","70291050","70291051","70291052","70291053","80011594","80011595","80011596","80011597","80011598","80011599","80011800","80011801","80011802","80011803","70223016","70223017","70223018","70223019","70223020","70223021","70223022","70223023","70223024","70223025","70223026","70223027","70223028","70223029","70223030","70223031","70223032","70223033","70223034","70223035","70223036","70223037","80061133","80061134","80061135","80061136","80061137","80061138","80061139","80061140","80061141","80061142","80061143","80061144","80061145","80061146","80061147","80061148","80061149","80061150","80061151","80061152","80061153","80061154","80061155","70223052","70223053","70223054","70223055","70223056","70223057","70223058","70223059","70223060","70223061","70223062","70223063","70223064","70223065","70223066","70223067","70223068","70223069","70223070","70223071","70223072","70223073","70223074","70223075","70223076","70223077","70223078","70223079","70223080","70223081","70223082","70223083","70223084","70223085","70223086","70223087","70223088","70223089","70223090","70223091","70223092","70223093","70223094","70223095","70223096","70223097","70223098","70223099","70223100","70223101","70223102","70223103","70223104","70223105","70223106","70223107","70223108","70223109","70223110","70223111","70223112","70223113","70223114","70223115","70223116","70223117","70223118","70223119","70223120","70223121","70223122","70223123","70223124","70223125","70223126","70223127","70223128","70223129","70223130","70223131","70223132","70223133","70223134","70223135","70223136","70223137","70223138","70223139","70223140","70223141","70223142","70223143","70223144","70223145","70223146","70223147","70223148","70223149","70223150","70223151","70223152","70223153","70223154","70223155","70245740","70245741","70245742","70245743","70245744","70245745","70245746","70245747","70245748","70245749","70245750","70245751","70245752","70245753","70245754","70245755","70245756","70245757","70245758","70245759","70245760","70245761","70245762","70283544","70283545","70283546","70283547","70283548","70283549","70283550","70283551","70283552","70283553","70283554","70283555","70283556","70283557","70283558","70283559","70283560","70283561","70283562","70283563","70283564","70283565","70283566","80004183","80004184","80004185","80004186","80004187","80004188","80004189","80004190","80004191","80004192","80004193","80004194","80004195","80004196","80004197","80004198","80004199","80004500","80004501","80004502","80004503","80004504","80004505","80033033","80033034","80033035","80033036","80033037","80033038","80033039","80033040","80033041","80033042","80033043","80033044","70218475","70218476","70218477","70218478","70218479","70218480","70228367","70228368","70228369","70228370","70228371","70228372","70116817","70116818","70116819","70116820","70116821","70116822","70120048","70120049","70120050","70120051","70120052","70120053","70124256","70124257","70124258","70124259","70124260","70124261","70159086","70159087","70159088","70159089","70159090","70159091","70229124","70229125","70229126","70229127","70229128","70229129","70229130","70229131","70229132","70229133","70229134","70229135","70229136","70243497","70243498","70243499","70243500","70243501","70243502","70243503","70243504","70243505","70243506","70243507","70243508","70243509","70273540","70273541","70273542","70273543","70273544","70273545","70273546","70273547","70273548","70273549","70306002","70306003","70306004","70306005","70306006","70306007","70210887","70210888","70210889","70210890","70210891","70210892","70248461","70248462","70248463","70248464","70248465","70248466","70248467","70248468","70248469","70248470","70248471","70248472","70248473","70260047","70260048","70260049","70260050","70260051","70260052","70260053","70260054","70260055","70260056","70260057","70260058","70260059","70260060","70260061","70260062","70297524","70297525","70297526","70297527","70297528","70297529","70297530","70297531","70297532","70297533","70297534","70297535","70297536","70297537","70297538","70297539","80010527","80010528","80010529","80010530","80010531","80010532","80010533","80010534","80010535","80010536","80010537","80010538","80010539","80010540","80010541","80010542","70134159","70134160","70134161","70134162","70134163","70134164","70134165","70134166","70134167","70134168","70134169","70134170","70134171","70134172","70134173","70134174","70134175","70134176","70134177","70134178","70134179","70134180","70134181","70134182","70134183","70134184","70134185","70134186","70134187","70134188","70134189","70134190","70134191","70134192","70134193","70134194","70134195","70134196","70134197","70134198","70134199","70134200","70134201","70134202","70134203","70134204","70134205","70134206","70134207","70134208","70134209","70134210","70134211","70134212","70134213","70134214","70134215","70134216","70134217","70134218","70134219","70134220","70134221","70134222","70134223","70134224","70134225","70134226","70134227","70134228","70134229","70134230","70134231","70134232","70134234","70134235","70134233","70134236","70134237","70134238","70134240","70134241","70134239","70134242","70134245","70134244","70134246","70134243","70134247","70134248","70134249","70134250","70134251","70134252","70134253","70134254","70134255","70134257","70134258","70134256","70134259","70134261","70134260","70134262","70134263","70134264","70134265","70134266","70134267","70134268","70134269","70134270","70134271","70134272","70134273","70134274","70134275","70178575","70134276","70134277","70134278","70134279","70134280","70134283","70134281","70134282","70134285","70134284","70134286","70134287","70134289","70134290","70134288","70134291","70134292","70134293","70134295","70134294","70134296","70134297","70134300","70134301","70134298","70134302","70134303","70134299","70134304","70134305","70134306","70134307","70134308","70134309","70134310","70134311","70134312","70134313","70134314","70134316","70134315","70134317","70134318","70134319","70134320","70134321","70134323","70134324","70134325","70134322","70134326","70134328","70134329","70134331","70134330","70134332","70134327","70134333","70134334","70134337","70134336","70134335","70134338","70134339","70134340","70134341","70134342","70134343","70134345","70134346","70134348","70134347","70134344","70134350","70134351","70134353","70134349","70134354","70134352","70134355","70134357","70134356","70134358","70134359","70143633","70143634","70143635","70143636","70143637","70143638","70143639","70143640","70143641","70143642","70143643","70143644","70143645","70143646","70143647","70143648","70143649","70143650","70143651","70143652","70143653","70143654","70143655","70143656","70143657","70143658","70143659","70143660","70143661","70143662","70143663","70143664","70143665","70143666","70143667","70143668","70143669","70143670","70143671","70171781","70171782","70171783","70171784","70171785","70171786","70171787","70171788","70171789","70171790","70171791","70171792","70171793","70171794","70171795","70171796","70304165","70304166","70304167","70304168","70304169","70304170","70304171","70304172","70304173","70304174","70304176","70304177","70304178","70304179","70304180","70304181","70304182","70304183","70304184","70304185","80028212","80028213","80028214","80028215","80028216","80028217","80028218","80028219","80028220","80028221","80028222","80028223","80028224","80033369","80033370","80033371","80033372","80033373","80033374","80033375","80033376","80033377","80033378","80033379","80033380","80033381","80033382","80033383","80033384","80033385","80033386","80033387","80033388","80033389","80033390","80033391","80033392","80033393","80032846","80032847","80032848","80032849","80032850","80032851","80032852","80032853","80032854","80032855","80032856","80032857","80032858","80032859","80032860","80032861","80032862","80032863","80032864","80032865","80032866","80032867","80032868","80032869","70094483","70094484","70094485","70094486","70094487","70094488","70094489","70094490","70094491","70094492","70094493","70094494","70094495","70094496","70094497","70094498","70094499","70094500","70094501","70094502","70094503","70094504","70131917","70131918","70131919","70131920","70131921","70131922","70131923","70131924","70131925","70131926","70131927","70131928","70131929","70131930","70131931","70131932","70131933","70131934","70131935","70131936","70131937","70131938","70131939","70131940","70131941","70131942","70131943","70131944","70120009","70131946","70131947","70131948","70131949","70131950","70131951","70131952","70131953","70131954","70131955","70131956","70131957","70141597","70155087","70155088","70155089","70155090","70155091","70155092","70155093","70155094","70155095","70155096","70155097","70155098","70227035","70227036","70227037","70227038","70227039","70227040","70227041","70227042","70227043","70227044","70227045","70227046","70227047","80013050","80013051","80013052","80013053","80013054","80013055","80013056","80013057","80013058","80013059","80013060","80013061","80013062","80013063","80013064","80013065","80013066","80013067","80013068","80013069","80013070","80013071","80049747","80049748","80049749","80049750","80049751","80049752","80049753","80049754","80049755","80049756","80049757","80049758","17672318","70175439","70004548","80000643","70301281","70230640","80023689","28369403","70305893","70278933","70083111","80013870","60022606","70295189","60023071","70024111","70127225","70046290","60022689","60011152","60011663","60011153","70295915","60021795","11819086","1084379","70266676","70099111"],["bookmarkPosition","runtime","summary"]]],"authURL":"1453584903376.Gt6K0kcp67SYJ0JJI/hkeNR9rco="}"
20:39:36 T:5252  NOTICE: Thread BackgroundLoader start, auto delete: false
20:39:36 T:2704  NOTICE: Previous line repeats 1 times.
20:39:36 T:2704  NOTICE: Thread LanguageInvoker start, auto delete: false
20:39:37 T:2704  NOTICE: -->Python Interpreter Initialized<--[/code]
I'm having a strange problem with my newest Kodi setup on Win10+IE11.
When I start a video via flix2kodi IE opens and the video starts, the problem is when I press space or enter playback doesn't pause instead the netflix overlay opens up the season window and all netflix shortcuts won't work.
This happens only with Win10+IE11 or Edge even if I open it direct in the browser without flix2kodi. With Chrome and FF it works but they cannot deliver 1080p and I actually wanted to use this benefit of IE on Win10.
Anyone experienced similar problems on Win10?
Edit: I figured out when I Alt-Tab to another Window and back to IE the shortcuts then work, pretty strange...
(2016-01-24, 13:45)CountBor Wrote: [ -> ]
Thank You
Afraid to say does not work on my Win 7 machine, click on the link for 64 bit Linux & all it does is goes to internet & then installs Google chrome, tried in Firefox, IE 10 & Chrome with the same results.
Excellent work on this add-on. I am running Jarvis on Windows 10. While I was unable to get the videos to play on Chrome (never-ending widevinecdm problems no matter how many times I uninstall, clear out registry entries, delete folders, etc.), they do play well on Edge (despite there not being a default fullscreen option at present).
My real problem is trying to add items through the add-on to my Kodi Library. I created a "library" folder in the flix2kodi directory with two sub-folders, "tv" and "movies". I then added those as video sources in Kodi. Unfortunately, nothing really seems to happen when I add Netflix items to my library via flix2kodi. Was I supposed to do something differently? Any advice/direction would be greatly appreciated.
Never mind. I had set my library in the wrong location...all is working now.
Has there been any progress on getting full screen for edge?
Hi, just uploaded a new version.
Please check changelog. I think the most problems of the last pages (sorry, could not read all) should be fixed.
If there are other flix2kodi-related problems, please provide a LOGFILE and the best would be to open an issue on github (1. post).
@horstepipe saw your issues, thx. but time is a real problem ;-)
@Fullscreen: don't know what to do, also have no windows 10 and no edge. perhaps someone could find a solution. I could send keystrokes to browser or pass parameters. If someone want to support check edge.cmd and sendkeys.vbs and try to find the right way.
@TheIrreverend: sometimes I get this error too, but at next try it works for me.
(2016-01-27, 00:06)logi85 Wrote: [ -> ]Hi, just uploaded a new version.
Hi!
EDIT: I saw in github code that you added lirc toogle to the addon, THANKS Wink
In the other hand, I translated all the addon to spanish, can you add to git repo?
Thanks again for this amazing addon Wink
(2016-01-27, 19:12)tocinillo Wrote: [ -> ]
Hi!
Cool! For sure! Please crate a pull request or if you don't know how just upload the spanish strings.po file.
I have an Nvidia Shield Android TV with Chrome and Netflix installed.
When opening "http://www.netflix.com/WiPlayer?movieid=70134159" or "http://www.netflix.com/watch/70134159" in Chrome (on my Nvidoa Shield Android TV), the Neflix app (com.netflix.mediaclient, not com.netflix.ninja) opens automatically and starts playing the first episode of X-Files (=movieID=70134159).
Is it possible to add Android as one of the options for Flix2Kodi, so that Flix2Kodi opens the movie url in the Chrome Android App? Chrome will then automatically open the movie/tvshow in the Neflix app if installed / sideloaded. This is what I found about opening urls in the chrome app:
String url = "http://www.netflix.com/watch/70134159";
    Intent i = new Intent();
    i.setPackage("com.android.chrome");
    i.setAction(Intent.ACTION_VIEW);
    i.setData(Uri.parse(url));
    startActivity(i);
An alternative would be to bypass Chrome, and open the movie directly in the Netflix app right from this addon. The following code opens the first episode of X-Files (=movieID=70134159) in the Neflix app from other Android apps:
String netFlixId = "70134159";
String watchUrl = "http://www.netflix.com/watch/"+netFlixId;
try {
        Intent intent = new Intent(Intent.ACTION_VIEW);
        intent.setClassName("com.netflix.mediaclient", "com.netflix.mediaclient.ui.launch.UIWebViewActivity");
        intent.setData(Uri.parse(watchUrl));
        startActivity(intent);
Can this be accomplished from inside kodi? With this addon?
