2021-03-07, 15:05
2021-03-07, 15:12
2021-03-07, 15:23
2021-03-07, 16:43
(2021-03-07, 15:23)phunkyfish Wrote: [ -> ]Ok try this @giaur
https://jenkins.kodi.tv/blue/organizatio.../artifacts
It seems it works fine now. Also, I looked at log file and it says override is used:
OpenWithFFmpeg - IO handled by FFmpeg's AVFormat 2021-03-07 15:23:42.525 T:30215 INFO <general>: AddOnLog: inputstream.ffmpegdirect: ffmpeg[7EE19D50]: Input #0, hls, from 'http://ip/280/video-timeshift_rel-221.m3u8?token=secret':
So it looks fine. If no other bugs found, I think you can push update and I will wait for CoreElec to build it.
2021-03-09, 15:46
Hey guys, I need some help. I have an issue with the new PVR function - CatchUp. After a few minutes, the stream skips 2-3 seconds and that happens until the end of the program. I have a log from the last time - https://paste.kodi.tv/susireneya.kodi
Thank you in advance!
2021-03-09, 18:45
(2021-03-09, 15:46)zzlateff Wrote: [ -> ]Hey guys, I need some help. I have an issue with the new PVR function - CatchUp. After a few minutes, the stream skips 2-3 seconds and that happens until the end of the program. I have a log from the last time - https://paste.kodi.tv/susireneya.kodi
Do you an example M3U entry that you use?
2021-03-09, 20:49
(2021-03-09, 18:45)phunkyfish Wrote: [ -> ]I guess you mean if I have an example. Yes, I have, here it is:(2021-03-09, 15:46)zzlateff Wrote: [ -> ]Hey guys, I need some help. I have an issue with the new PVR function - CatchUp. After a few minutes, the stream skips 2-3 seconds and that happens until the end of the program. I have a log from the last time - https://paste.kodi.tv/susireneya.kodi
https://paste.kodi.tv/oyekuciwem
Thank you for getting back to me.
2021-03-09, 21:20
(2021-03-09, 20:49)zzlateff Wrote: [ -> ](2021-03-09, 18:45)phunkyfish Wrote: [ -> ]I guess you mean if I have an example. Yes, I have, here it is:(2021-03-09, 15:46)zzlateff Wrote: [ -> ]Hey guys, I need some help. I have an issue with the new PVR function - CatchUp. After a few minutes, the stream skips 2-3 seconds and that happens until the end of the program. I have a log from the last time - https://paste.kodi.tv/susireneya.kodi
When the stream skips 2-3 seconds does it then play again for a few minutes until it skips once more?
Did you play the currently playing programme or a programme that had already finished.
2021-03-09, 21:33
(2021-03-09, 21:20)phunkyfish Wrote: [ -> ]1. Yes, the stream skips 2-3 seconds and then goes back to normal and after approximately 1 minute it skips again.(2021-03-09, 20:49)zzlateff Wrote: [ -> ](2021-03-09, 18:45)phunkyfish Wrote: [ -> ]Do you an example M3U entry that you use?I guess you mean if I have an example. Yes, I have, here it is:
2. A programme that has already finished.
2021-03-09, 21:34
(2021-03-09, 21:33)zzlateff Wrote: [ -> ]The programme*(2021-03-09, 21:20)phunkyfish Wrote: [ -> ]1. Yes, the stream skips 2-3 seconds and then goes back to normal and after approximately 1 minute it skips again.(2021-03-09, 20:49)zzlateff Wrote: [ -> ]I guess you mean if I have an example. Yes, I have, here it is:
2021-03-10, 01:02
(2021-03-09, 21:34)zzlateff Wrote: [ -> ](2021-03-09, 21:33)zzlateff Wrote: [ -> ]The programme*(2021-03-09, 21:20)phunkyfish Wrote: [ -> ]When the stream skips 2-3 seconds does it then play again for a few minutes until it skips once more?1. Yes, the stream skips 2-3 seconds and then goes back to normal and after approximately 1 minute it skips again.
Then in this case I would try another provider. With a higher quality stream this should not happen.
2021-03-10, 09:02
@phunkyfish
When merge 7.5 vesion is planned? Not merged yet: https://github.com/kodi-pvr/pvr.iptvsimp...its/Matrix
2021-03-10, 09:31
(2021-03-10, 01:02)phunkyfish Wrote: [ -> ](2021-03-09, 21:34)zzlateff Wrote: [ -> ](2021-03-09, 21:33)zzlateff Wrote: [ -> ]1. Yes, the stream skips 2-3 seconds and then goes back to normal and after approximately 1 minute it skips again.The programme*
May I ask you what you mean by a higher quality stream? This is one of the main providers here and the Live TV works perfectly. Is there something wrong in the log file?
2021-03-10, 11:48
(2021-03-10, 09:02)giaur Wrote: [ -> ]@phunkyfish
Hopefully today.
2021-03-10, 11:57
(2021-03-10, 09:31)zzlateff Wrote: [ -> ](2021-03-10, 01:02)phunkyfish Wrote: [ -> ](2021-03-09, 21:34)zzlateff Wrote: [ -> ]The programme*
I meant to try an alternative provider to see if the same issue occurs. Sometimes providers send a lower quality stream for catchup which can be problematic for some connections.
Your log file is a regular log and not a full debug log. If you can supply a full debug log I can take a look. Instructions in my signature.
If you know what kind of video you have you can try setting a mime type in the addon settings. Although if it plays currently I’m not sure it would make a difference.
Are you able jump forward and back in the catchup stream ok?
