(2021-04-26, 18:57)Atamans Wrote: [ -> ]I will check android and coreelec to rule out windows blame and let you know ..
in a private message I sent you what I use so that you can check more precisely ....
edit...
The problem does not occur on android..
It does not occur on Mac either. In settings do you have it set to prefer XMLTV for EPG logos?
EDIT: I think I found the issue. Try to enable catchup on the windows PC and see does it then work?
yes enabling this option helped, thanks!
I have one more question, is there any way to rename channels eg. "UHD" to "HD" or vice versa "::" to nothing
or maybe can apply regex in advancedsettings.xml?
Hello. Help me set up timeshift channels. I have a windows 7 kodi 19 matrix system. Catch up works great, but timeshift does not work, that is, the forward and backward scroll bar (blue and white) is there, but when pressed in live stream it freezes and the white scroll bar disappears and it turns completely blue. In the case of a catchup broadcast, when rewinding, a jump to the time to the specified place occurs and the time starts to move, but the image freezes. Can anyone help
(2021-06-25, 22:50)hnstr3 Wrote: [ -> ]Hello. Help me set up timeshift channels. I have a windows 7 kodi 19 matrix system. Catch up works great, but timeshift does not work, that is, the forward and backward scroll bar (blue and white) is there, but when pressed in live stream it freezes and the white scroll bar disappears and it turns completely blue. In the case of a catchup broadcast, when rewinding, a jump to the time to the specified place occurs and the time starts to move, but the image freezes. Can anyone help
Sounds like you may have the same issue raised at
https://github.com/kodi-pvr/pvr.iptvsimple/issues/524
(2021-06-26, 09:25)berkhornet Wrote: [ -> ] (2021-06-25, 22:50)hnstr3 Wrote: [ -> ]Hello. Help me set up timeshift channels. I have a windows 7 kodi 19 matrix system. Catch up works great, but timeshift does not work, that is, the forward and backward scroll bar (blue and white) is there, but when pressed in live stream it freezes and the white scroll bar disappears and it turns completely blue. In the case of a catchup broadcast, when rewinding, a jump to the time to the specified place occurs and the time starts to move, but the image freezes. Can anyone help
Sounds like you may have the same issue raised at https://github.com/kodi-pvr/pvr.iptvsimple/issues/524
Pause/play in live TV no working also
(2021-06-26, 10:32)hnstr3 Wrote: [ -> ] (2021-06-26, 09:25)berkhornet Wrote: [ -> ] (2021-06-25, 22:50)hnstr3 Wrote: [ -> ]Hello. Help me set up timeshift channels. I have a windows 7 kodi 19 matrix system. Catch up works great, but timeshift does not work, that is, the forward and backward scroll bar (blue and white) is there, but when pressed in live stream it freezes and the white scroll bar disappears and it turns completely blue. In the case of a catchup broadcast, when rewinding, a jump to the time to the specified place occurs and the time starts to move, but the image freezes. Can anyone help
If you revert to Inputstream.ffmpegdirect v 1.21.1 or the test build mentioned at
https://github.com/kodi-pvr/pvr.iptvsimple/issues/524, Pause/Play with live TV should work. Also FF in Catchup. Using one of these versions the only problem I have is Pause/Play in Catchup, which reverts to the start of the stream after pressing Play. My install is on Windows 10.
(2021-06-26, 12:04)berkhornet Wrote: [ -> ] (2021-06-26, 10:32)hnstr3 Wrote: [ -> ] (2021-06-26, 09:25)berkhornet Wrote: [ -> ]Sounds like you may have the same issue raised at https://github.com/kodi-pvr/pvr.iptvsimple/issues/524
If you revert to Inputstream.ffmpegdirect v 1.21.1 or the test build mentioned at https://github.com/kodi-pvr/pvr.iptvsimple/issues/524, Pause/Play with live TV should work. Also FF in Catchup. Using one of these versions the only problem I have is Pause/Play in Catchup, which reverts to the start of the stream after pressing Play. My install is on Windows 10.
Thank you. I'm trying
Please tell me how i can install Inputstream.ffmpegdirect v 1.21.1, where i can download it. Thanks
(2021-06-26, 19:16)berkhornet Wrote: [ -> ] (2021-06-26, 19:01)hnstr3 Wrote: [ -> ]Please tell me how i can install Inputstream.ffmpegdirect v 1.21.1, where i can download it. Thanks
https://mirrors.kodi.tv/addons/matrix/in...ws-x86_64/
If i trying to install version 1.21.1 writing: "failed to install file from zip due to invalid structure"
P.s. i dont uninstall version 1.21.3, maybe i need delete version 1.21.3.
Can u write step by step how me install another version ffmpeg direct (not 1.21.3). Now i have installed ffmpeg direct version 1.21.3. and simple client 7.6.5. Sorry for my bad english
(2021-06-26, 19:39)hnstr3 Wrote: [ -> ] (2021-06-26, 19:16)berkhornet Wrote: [ -> ] (2021-06-26, 19:01)hnstr3 Wrote: [ -> ]Please tell me how i can install Inputstream.ffmpegdirect v 1.21.1, where i can download it. Thanks
I just downloaded the zip file, and used the Kodi addon manager to install the zip file. I don't know why this would not work for you. Or you could try the download on github.
I think i can't install old version addon because kodi 19.1 support only version 1.21.3
(2021-06-26, 22:41)hnstr3 Wrote: [ -> ]I think i can't install old version addon because kodi 19.1 support only version 1.21.3
All I can say is I am running Kodi 19.1 and Inputstream.ffmpegdirect 1.21.1 successfully.
If I try install ffmpegdirect from
https://github.com/xbmc/inputstream.ffmp...t/releases version 1.21.2 in logfile write:
2021-06-27 07:43:27.682 T:8176 ERROR <general>: CAddonInfoBuilder::ADDON::CAddonInfoBuilder::Generate: Unable to load 'zip://C%3a%5cUsers%5cHnst%5cDesktop%5cinputstream.ffmpegdirect-1.21.2-Matrix%5cinputstream.ffmpegdirect-1.21.2-Matrix%5cinputstream.ffmpegdirect.zip/inputstream.ffmpegdirect/addon.xml', Line 0
Failed to open file
2021-06-27 07:43:27.709 T:7516 INFO <general>: CActiveAESink::OpenSink - initialize sink
