2023-09-28, 22:40
(2023-09-28, 05:46)fbagnato Wrote: [ -> ]Hi all,
I have the Red Bull TV addon that is showing up as Catchup enabled (has the Green dot against the programmes in the EPG).
It is the only channel showing up as Catchup enabled.
I cannot get Catchup to work on it.
My Catchup settings are as follows:
Catchup:
Enable catchup = On
- Query format screen = &utc={utc}&lutc={lutc}
- Catchup windows = 5 days
Channels support catchup using mode = Default
- Include channels = with catchup mode
Catchup correction = 0.0 hours
Watch From EPG:
Play from EPG in Live mode (using timeshift) = On
- Buffer before program start = 5 min (setting greyed out)
- Buffer after program end = 15 min (setting greyed out)
Catchup only available on finished programmes = Off
The playlist.m3u8 entry for Red Bull TV is as follows:
#EXTINF:-1 catchup="vod" group-title="Red Bull TV" tvg-chno="88" tvg-id="redbulltv" tvg-logo="C:\Users\Flavio\AppData\Roaming\Kodi\addons\plugin.video.redbull.tv\resources\media\icon.png" tvg-name="Red Bull TV" , Red Bull TV
plugin://plugin.video.redbull.tv/iptv/play
I noticed it has catchup="vod" in the entry but cannot find any posts in this thread that reference catchup="vod".
Is there a way to make Catchup work with the Red Bull TV channel?
What settings do I need to make it work?
Or, is catchup="vod" not supported in IPTV Simple?
Regards,
fbagnato
It definitely is, in fact it’s the only place it’s supported. It’s was implemented specially for plug-in URLs.
What do you mean by get it to work? Does the programme play at all? Or what happens?
You might not be able to play it as live TV, try setting that option off.
