(2021-06-27, 06:58)hnstr3 Wrote: [ -> ]If I try install ffmpegdirect from https://github.com/xbmc/inputstream.ffmp...t/releases version 1.21.2 in logfile write:
2021-06-27 07:43:27.682 T:8176 ERROR <general>: CAddonInfoBuilder::ADDON::CAddonInfoBuilder::Generate: Unable to load 'zip://C%3a%5cUsers%5cHnst%5cDesktop%5cinputstream.ffmpegdirect-1.21.2-Matrix%5cinputstream.ffmpegdirect-1.21.2-Matrix%5cinputstream.ffmpegdirect.zip/inputstream.ffmpegdirect/addon.xml', Line 0
Failed to open file
2021-06-27 07:43:27.709 T:7516 INFO <general>: CActiveAESink::OpenSink - initialize sink
I don't think the zip files at that location are fully compiled and ready for installation.
Here is the testbuild (from issue 524 on Github) where @
phunkyfish reverted everything back to 1.20.1. It will still be called 1.21.3 so is a little confusing!
https://jenkins.kodi.tv/blue/organizatio.../artifacts - make sure you select the correct zip file for your system.
I have installed this build and everything seems to work except Pause/Play in Catchup mode, and gives the same results as the earlier 1.21.1 release
If i trying install phunkyfish's test version kodi write:
2021-06-27 13:01:13.599 T:6388 INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2021-06-27 13:01:16.768 T:6388 INFO <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2021-06-27 13:01:51.351 T:7856 INFO <general>: CActiveAESink::OpenSink - initialize sink
How are you trying to install it? Those errors are not related to the addon.
Quote:I have installed this build and everything seems to work except Pause/Play in Catchup mode, and gives the same results as the earlier 1.21.1 release
berkhornet is there any release where play pause is working?
(2021-06-27, 14:33)phunkyfish Wrote: [ -> ]Quote:I have installed this build and everything seems to work except Pause/Play in Catchup mode, and gives the same results as the earlier 1.21.1 release
@berkhornet is there any release where play pause is working?
phunkyfish I cannot get Pause/Play to work with Catch Up with any available release of inputstream.ffmpegdirect. For a live stream Pause/Play works in versions 1.21.1, 1.21.2 and your test build (1.20.1).
(2021-06-27, 14:30)phunkyfish Wrote: [ -> ]How are you trying to install it? Those errors are not related to the addon.
I have installed simple client 7.6.5. with ffmpegdirect 1.21.3. win 7 system and kodi 19.1 matrix. I install this addons through addons-install from zip method, and have this errors in logfile. If i install ffmpegdirect zip file (7,7 mb) i dont have error in logfile, but can't install this addon in kodi (because invalid structure), if i install ffmpeg from guthub
https://github.com/xbmc/inputstream.ffmp...t/releases i have error line 0 failed to open file
(2021-06-27, 17:59)hnstr3 Wrote: [ -> ] (2021-06-27, 14:30)phunkyfish Wrote: [ -> ]How are you trying to install it? Those errors are not related to the addon.
I have installed simple client 7.6.5. with ffmpegdirect 1.21.3. win 7 system and kodi 19.1 matrix. I install this addons through addons-install from zip method, and have this errors in logfile. If i install ffmpegdirect zip file (7,7 mb) i dont have error in logfile, but can't install this addon in kodi (because invalid structure), if i install ffmpeg from guthub https://github.com/xbmc/inputstream.ffmp...t/releases i have error line 0 failed to open file
Is your Windows system 32 bit or 64 bit?
I have old notebook with 2gb RAM and windows 7 (32bit).
Yesterday i without any errors installed elementum
(2021-06-28, 09:18)berkhornet Wrote: [ -> ] (2021-06-27, 17:59)hnstr3 Wrote: [ -> ] (2021-06-27, 14:30)phunkyfish Wrote: [ -> ]How are you trying to install it? Those errors are not related to the addon.
You have installed the 64 bit version of inputstream.ffmpegdirect.
(2021-06-28, 11:26)hnstr3 Wrote: [ -> ]Yesterday i without any errors installed elementum
What you should have done is read the
forum rules (wiki) and
piracy policy (wiki) right when you registered on this forum.
This forum will have nothing to do with add-ons facilitating video piracy.
Do not use or even mention them when you are looking for support for your Kodi device.
Also try to combine your texts into 1 post, we are not a telex office.
I installed ffmpegdirect from the official kodi repository. Is it for 64 bit windows? If possible, tell me where i can get ffmpegdirect for windows 7 32 bit
(2021-06-28, 11:49)hnstr3 Wrote: [ -> ]I installed ffmpegdirect from the official kodi repository. Is it for 64 bit windows? If possible, tell me where i can get ffmpegdirect for windows 7 32 bit
I think you are confused. In an earlier post you said you had installed inputstream.ffmpegdirect from the test build - not the Kodi repository. Unfortunately you installed the 64 bit version of the test build. So to get some of the functionality working you need to install the 32 bit version from the link I provided earlier.
If you are having trouble with this, it may be better for you to wait until there is a full fix available from the Kodi repository.
