Hudson_Hawk04 Wrote:how does my location need to be set up if I want to use NOAA as my provider?
* HOW-TO-USE : addon's settings -> provider tab -> toggle on any location slot you want -> select a provider you want -> change location -> OK -> ENJOY!
brightsr Wrote:[UPDATED] v.2.2.4
- Fixed : Sunrise and Sunset Time Bug of Weather.com
Awesome-fixed. Thanks brightsr!
Rygrath Wrote:Man, Weather.com is biased against us High Desert people
In seriousness though, I just spent the last 20minutes trying out different cities in the US. Almost every one of them caused a script failed error except New York and Arlington West Virginia. Denver, Dallas, Orlando, Los Angeles, Knoxville, etc caused script errors.
Then I tried outside the US and all of them worked just fine, from London, Hong Kong, Sydney, Calgary, etc. I'd post a log, but it's generally the same error messages that I posted before.
I'll keep messing with it, but thought I'd share what I've run into.
I think there's a problem with fetching a url of local forecast video.
I'll keep figuring out and try to fix it.
@ Rygarth
When you tried the various cities did you have the large map pack installed? Also atm I am unable to view radar and maps, I will post logs here in a bit.
Hudson_Hawk04 Wrote:@ Rygarth
Aye, I do have the large map pack installed. I can try without it later when I get back home.
And brightsr much appreciated once again you looking into this
Rygrath Wrote:Aye, I do have the large map pack installed. I can try without it later when I get back home.
I fixed it, I'll upload soon.
[UPDATED] v.2.2.6
- Fixed : US Local Forecast Video from Weather.com
brightsr Wrote:I fixed it, I'll upload soon.
[UPDATED] v.2.2.6
So awesome it works again! Thanks a million!
Darn a couple of problems on ATV2 confluence skin, 10.09
1) No weekend forecast - Fetching forecast and just sits there
2) No Maps and Video, just black box
Can anyone help, here is the log
http://pastebin.com/QeDgeJUV
thanks all
dallasnights Wrote:Darn a couple of problems on ATV2 confluence skin, 10.09
thanks all
[Weather Plus] Area code = en-us/us/tx/plano
The area code above is only for Accuweather.com not NOAA.
Which means you need to re-select location for NOAA.
And if you're using other providers rather than Weather.com, you can't see maps and video, which is totally normal as for now.
[UPDATED] v.2.2.7
- Added : "Area Code Error" Dialog ( It'll let you know if you don't re-select a location after changing a provider. )
- Fixed : 10 day Wind Bug of NOAA
I have updated to the latest version of weather plus and for some reason I am not getting the option to watch video. I tried both regional and local and nothing................
brightsr Wrote:Please post your log.
Thanks. this is the first time I have posted a log, so please let me know if you need something more. I basically turned debugging on and then messed around in the weather app.
http://pastebin.com/0i1yDmru Here is it
patm95 Wrote:Thanks. this is the first time I have posted a log, so please let me know if you need something more. I basically turned debugging on and then messed around in the weather app. http://pastebin.com/0i1yDmru Here is it
It's not including any logs of Weather Plus.
Please post your whole log file.
brightsr Wrote:It's not including any logs of Weather Plus.
Sorry about that. Here is my 2nd try:
http://pastebin.com/qFx69FJx
