First off let me say Weather+ is a great add-on, especially since Weather.com is now not working.
Note: using 10.0 Confluence (dharma) - hard disk install from Livecd
from post #1 ---- Quote ----
[How to Use]
1) First of all, it needs a compatible skin
2-a) Install "Weather.com+ for Dharama" from Nuka's Repo. :
http://xbmc-addons.googlecode.com/sv...bmc-addons.zip
2-b) Or download this zip file and install it :
http://xbmc-addons.googlecode.com/fi...plus_2.3.1.zip (v.2.3.1)
Step 2-b: if the file is down loaded (tried twice and got the same md5 each time) it will not unzip. Used cli on Ubuntu 10.04 desktop "unzip weather.weatherplus_2.3.1.zip" following is the response. (This file also gives an error when I tried to install the add-on from the zip file in XBMC)
Archive: weather.weatherplus_2.3.1.zip
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of weather.weatherplus_2.3.1.zip or
weather.weatherplus_2.3.1.zip.zip, and cannot find weather.weatherplus_2.3.1.zip.ZIP, period.
The file from step 2-a does/does unzip.
[Compatible Skin]
The list below is based on my knowledge.
If you know another skin, feel free to let me know.
1) Transparency! :
http://forum.xbmc.org/forumdisplay.php?fid=115
2) Confluence (dharma): extract and overwrite this zip file into skin folder (
http://xbmc-addons.googlecode.com/fi...eather_mod.zip) (Updated 09-21-2011)
The file in step 2 above (Confluence (dharma)) does/does unzip.
Using the file from step 2-a and the the Confluence (dharma)(Updated 09-21-2011) file the result is GREAT and everything appears to be functional EXCEPT:
Current Conditions shows no:
-- present temperature, feels like, dew point, humidity UV index or wind
Even in its present form it is great. Any idea on the missing information from the Current Conditions.
Thanks a lot for all the work done to date on this add-in.
