2014-10-24, 02:05
Thanks mate! That was super fast and super effective, as the problem is now gone and I am a happy guy again.
Thank you very, very much.
(2014-10-24, 02:05)Starbuck1991 Wrote: [ -> ]Thanks mate! That was super fast and super effective, as the problem is now gone and I am a happy guy again.
(2014-10-29, 21:21)SilRe Wrote: [ -> ]Hi.
The download link is unavailable.
(2014-10-31, 15:14)lexa2575 Wrote: [ -> ]Good day.
I XBMCLauncher works fine but every time you start showing Warning is hotkeys.
"Note: The hotkey #E:: will not be active becouse it does not exist in the current keyboard layout"
and
"Note: The hotkey #S:: will not be active becouse it does not exist in the current keyboard layout"
What to do? what's my problem?
P.S. how to insert a picture in my post?
(2014-09-05, 22:57)richardb70 Wrote: [ -> ]Hi, many thanks to the OP for the excellent work, and also for getting me into AHK scripting which has been a massive saviour. I'm running loads of emulators and PC games and AHK has been a real life saver with key remaps and using a 360 controller to terminate programs etc.
Anyway, I posted earlier about running out of the 4 slots for external players. Ran through the code (very nice job, BTW) and made a few changes for ease of accommodating additional .exes. Thought I'd share if anyone else is interested.
Code:global ExternalPlayerRunning = 0
global ExternalPlayer1 := GetSettings("ExternalPlayer1_Path", "")
global ExternalPlayer2 := GetSettings("ExternalPlayer2_Path", "")
global ExternalPlayer3 := GetSettings("ExternalPlayer3_Path", "")
global ExternalPlayer4 := GetSettings("ExternalPlayer4_Path", "")
global ExternalPlayerName = ""
global FocusExternalPlayer := GetSettings("FocusExternalPlayer", 0)
global OtherExternalPlayers := "Hello4.exe,Hello5.exe" ; EDIT HERE TO ADD NEW .EXE FILES
global ExternalPlayerArray := LoadUpArray()
The last two lines are mine. If you run out of slots, you want the OtherExternalPlayers variable to hold a comma-separated list of the .exes - not the full file paths, this is important.
Add the LoadUpArray function down below in the function area:
Code:LoadUpArray()
ExternalPlayerArray := Object()
Loop, 4
if (ExternalPlayer%A_Index% != "")
SplitPath, ExternalPlayer%A_Index%, filnam
; MsgBox Load: The filename is %filnam%
ExternalPlayerArray.Insert(filnam)
StringSplit, tempArray, OtherExternalPlayers, `,
Loop, %tempArray0%
filnam := tempArray%A_index%
return ExternalPlayerArray
This takes values from the GUI slots as well as the comma-separated variable and puts all of them into an array.
Now tweak DisableFocusOnExternalPlayer so that you have:
Code:DisableFocusOnExternalPlayer()
for index, playername in ExternalPlayerArray
; MsgBox Use: the playername is %playername%
Process, exist, %playername%
If (ErrorLevel >= 1)
ExternalPlayerRunning = 1
ExternalPlayerName = %playername%
break
Up to you if you do like me and surgically remove the rest of it. I'm only using the External Players and not the Prevent Focus Apps, so this will do me. At the very least you want to comment out (or remove) the blocks with ExternalPlayer1 - 4 in them as these are already taken care of.
It's slightly more efficient in that the paths are already stripped out so no need to call SplitPath every iteration of the timer, and also it will terminate after a running process is found rather than continuing to check other processes.
Anyway, there you go, feedback welcome and many thanks again to baijuxavior.
(2014-11-02, 04:47)baijuxavior Wrote: [ -> ]I will add this feature in the final release of KodiLauncher.
(2014-11-01, 19:48)bgmordred Wrote: [ -> ]Can you make it easier for us (not a programmer)... We want to add more "prevent focus" apps...
(2014-11-10, 07:14)TheFonz Wrote: [ -> ]Great app and have been using it successfully for some time now. My only suggestion or feature I'd like to see - and this may only apply to me - is to add an option to stop the content before exiting xbmc.
I've found when watching live tv if I power the HTPC down without first stopping the live tv feed xbmc will crash and stop the HTPC from going to sleep.
An option to simply send the stop command before exiting xbmc would solve this.
Cheers
_Fonz
