2013-10-04, 13:59
film watching sounds like a plan :-), thats what im going to be doing this evening, with a nice cold beer! :-), cheers for your reply.
(2013-09-25, 19:12)henrava Wrote: [ -> ]Hi Pecinko, congratulations for how you have solved the lyrics screen, is very nice !
If possible, can you add a button in the bar to switch to lyrics directly ? (like the sub button for the movies)
1000 Thanks !
(2013-10-06, 17:16)pecinko Wrote: [ -> ]Add fast start option that skips waiting for skin widgets
(2013-09-29, 19:48)MilhouseVH Wrote: [ -> ]Would it be possible to add an option to hide the "Update Library" sub-menu below Movies/TV Shows/Music?
(2013-09-29, 23:00)MilhouseVH Wrote: [ -> ]I know you tried to fix this before, but the zeroes in the default font are still looking a little odd - see this screenshot image for an example (007). I guess it must be a fault with the skin font, as the "(2/2) Arial based" font displays correctly but isn't as attractive.
Also, what do you think about adding codec flags alongside the star ratings in this view? These codec flags seem to be present in some views (Big List, Panel, Big Panel) but not others, which is a shame.
(2013-09-30, 08:28)MilhouseVH Wrote: [ -> ]Did anyone find a solution for these SetFocus() messages when XBMC starts?
(2013-09-30, 21:45)danmedhurst Wrote: [ -> ]Am i missing something? When this skin was in the Dev section, there were posts saying what was new in the skin.. i've seen there is an update available, but i've no idea what's new... where should i be looking or is it just in the changelog on the skin itself?
(2013-10-01, 22:34)thewarm Wrote: [ -> ]Where can I edit the horizontal homescreen sub-menu items please?
I'd like to remove some unused items (like "tags" under movies)
(2013-10-03, 13:33)Outlaw Mantis Wrote: [ -> ]I was just about to ask the same question. It seems that only favourites can be added which are single films, etc. This is the one reason why I'd like to use Aeon Nox instead of Amber, but Amber is much more efficient. This feature to open a smart playlist on the menu would be fantastic.
Also, a slightly off-topic but also slightly relevant question if anybody could shed some light is that I'm using the Art Organiser plugin. However, when I select multi image in backgrounds with Amber I'm not sure where to look for the organised images. This is so I can have film image backgrounds under "Movies", etc. Although it would be nice if there was a way to only have images related to items in a smart playlist. So, if I create a menu item for Animations, it only shows backgrounds from those animations and not "live action" films, if you understand.
(2013-10-07, 09:53)MilhouseVH Wrote: [ -> ]That would be excellent, many thanks!
(2013-10-07, 09:33)pecinko Wrote: [ -> ]Movable items, submenu customisations, etc:
I could probably add support for custom video nodes http://wiki.xbmc.org/index.php?title=Custom_video_nodes
That way you can customise your filters any way you want, including adding playlists. Thoughts?
