2013-10-11, 16:45
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
2013-10-12, 16:05
I know you want to keep this skin "light", but would it be possible to add the "TV Show Next Aired" script please?
I love the skin! But I miss the next aired dates when viewing TV Shows...
2013-10-12, 17:38
(2013-10-10, 05:59)my95z34 Wrote: [ -> ]Any chance you could implement the "Intro Movie" feature into this skin? (http://forum.xbmc.org/showthread.php?tid=124124)
I've tried to do it myself but wherever I add the code to play the movie, the skin refuses to load after that and will just sit frozen with a "Loading" notification. If you need a log or anything, I'd be happy to post it.
Thanks in advance, also, thanks for the great performing skin for my RPi!
Just quoting this in case it got lost in the other posts.
2013-10-12, 17:48
(2013-10-12, 16:05)thewarm Wrote: [ -> ]I know you want to keep this skin "light", but would it be possible to add the "TV Show Next Aired" script please?
That has nothing to do with skin light. I'm not interested myself, though. Maybe space monkey or somebody else is?
(2013-10-12, 17:38)my95z34 Wrote: [ -> ](2013-10-10, 05:59)my95z34 Wrote: [ -> ]Any chance you could implement the "Intro Movie" feature into this skin? (http://forum.xbmc.org/showthread.php?tid=124124)
It is not lost but I don't have a clue what is needed and I don't have time to read the thread and experiment ATM. Where is your code that is not working for you? I can have a look.
2013-10-12, 18:20
can you put in Amber an Load Bar ?
2013-10-13, 00:40
I'm a long time user since early betas. I just bought a bigger LED panel upgrading from my old 720p one. Suddenly one question came to my mind. Is Amber 1080p?
2013-10-13, 09:42
(2013-10-09, 09:23)pecinko Wrote: [ -> ]I'll add it.
@Picinko: I just forked the skin on Github, because I always wanted to understand how XBMC skins work. So I changed the music visualization and added the star rating, also.
I removed the info panel flipping animation and made the fonts way better, similar to aeon.nox.
And since I like red, I changed all the labels to be red :-)
I still think the star rating should be in the original repository though, because you still can rate music, but it is not visually represented. So you might accidentally rate music up or down, without noticing.
Thanks for this great skin, I will now definitely use it and hope that future changes are easy enough for me to port back from your repo.
2013-10-13, 16:20
I wanted to thank you for this super clean skin!
I use the Icon View for my Movies and TV Shows, with the Big List for TV episodes. Simple... Clean...
3 thumbs up!
3 thumbs up!
2013-10-13, 20:36
I reinstalled raspbmc on the SD card and i want to reinstall the Amber skin. I thought it was used is this repo (for auto updates): http://forum.xbmc.org/showthread.php?tid=159372
Is this skins gone in the repo?
2013-10-13, 20:53
(2013-10-13, 20:36)Paulus Wrote: [ -> ]I reinstalled raspbmc on the SD card and i want to reinstall the Amber skin. I thought it was used is this repo (for auto updates): http://forum.xbmc.org/showthread.php?tid=159372
It is in XBMC main repository, along with other finished skins.
(2013-10-13, 16:20)thewarm Wrote: [ -> ]I wanted to thank you for this super clean skin!
3 thumbs up!
(2013-10-13, 00:40)baruchin Wrote: [ -> ]I'm a long time user since early betas. I just bought a bigger LED panel upgrading from my old 720p one. Suddenly one question came to my mind. Is Amber 1080p?
Yes.
2013-10-14, 21:13
Great skin.
In TV shows, DialogVideoInfo.xml reports total eps for the show on the season info screen (where it should report season eps?). Not sure if this is skin related or XBMC related. Checked Quartz and it does the same, so maybe it's a just the info label in XBMC doesn't do season eps.
2013-10-15, 08:17
(2013-10-14, 21:13)kristle Wrote: [ -> ]Great skin.
Not available per season IFAIK. Does not bother me personally, but I can hide it at season level?
2013-10-15, 12:49
(2013-10-07, 09:33)pecinko Wrote: [ -> ]Movable items, submenu customisations, etc:
I could probably add support for custom video nodes http://wiki.xbmc.org/index.php?title=Custom_video_nodes
That way you can customise your filters any way you want, including adding playlists. Thoughts?
Hi
Is this still in the pipeline Pecinko?
2013-10-16, 02:19
(2013-10-15, 12:49)rossglass Wrote: [ -> ](2013-10-07, 09:33)pecinko Wrote: [ -> ]Movable items, submenu customisations, etc:
Hi
Yup
2013-10-16, 17:23
Hi All
New to the skin so apologies for maybe the stupid question. I am wanting to use this skin on my raspberry pi but have a few configuration questions that I hope someone will be able to help with
1. In the Music Menu can I default it to Albums so that it always opens the albums and not the options to select albums? If possible where/how do I configure? BTW Make Default doesn't appear to work?
2. The sub menus on the main screen under music/video etc can this be edited?
3. in the movie menu can you default it to files as my movies are added by Genre hence the question?
If the above is not possible from within the GUI I'm happy to edit files if that will achieve the above
Thanks for the skin and the support
Cheers
Mark
Cheers
Mark
