Seeing my post in quotes makes me realise i use a lot of words to explain what i want. sorry about that.
@dammedhurst: Thanks for your reply ! that is a nice suggestion and offers me a 4th option. I do use musicvideos, but not as much as i like the kids section, so i might go for that. I hope the musicvideo scraper can be turned off or changed else it will screw things up maybe. nfo's shouldn't be a problem. Thanks !
(2013-12-16, 20:45)Sunfel Wrote: [ -> ]Seeing my post in quotes makes me realise i use a lot of words to explain what i want. sorry about that.
Have you considered profiles?
Oh do you mean profiles make a different library for every profile ?
Haven't thought of that at all...just thought profiles was a way to easily hide configuration options/menu's for normal use.
I'll give that a go, but that sounds perfect. a Kids profile will definately do the trick if that works !
thanks pecinko !
[EDIT]: now i just need to find the profile option in Amber haha.... I can find it in default skin, but it is only helpful ofcourse if there is a way to easily switch profiles ;-)
(2013-12-16, 21:02)Sunfel Wrote: [ -> ]Oh do you mean profiles make a different library for every profile ?
thanks pecinko !
Yup. You can hide unneeded stuff, you can use normal scraper and not file mode and shelf will work for both adults and kids.
thanks pecinko !
how did you add a new menu item?
(2013-12-16, 21:02)Sunfel Wrote: [ -> ][EDIT]: now i just need to find the profile option in Amber haha.... I can find it in default skin, but it is only helpful ofcourse if there is a way to easily switch profiles ;-)
Set Quit menu button to log off?
@pecinko: found to profile manager ... this seems to be exactly what i have been looking for...
[edit:] yup, thanks i just thought the same thing....easy way to switch users !! it's all there.... as i said....great skin ! ;-)
@isitmeor: in setup --> home menu you can add up to 9 custom menu's ....or hide default ones
(2013-12-16, 21:09)Sunfel Wrote: [ -> ]@pecinko: found to profile manager ... this seems to be exactly what i have been looking for...
I found that part but is teher a simple way to add a menu item or do I have to set a action
(2013-12-10, 17:30)isitmeor Wrote: [ -> ] (2013-12-10, 17:28)pecinko Wrote: [ -> ]I may add it in the next update.
can you elaborate on that?
It is on Git, and I have request skin update. HOWEVER, this is not working for me as it should. Playback starts but you need to press a button in order for main menu to appear. I have no clue why this happens as it shouldn't. For this reason, code is there but is commented out. I can give a hint what to do if you are not afraid to fiddle with skin code.
(2013-12-16, 21:11)isitmeor Wrote: [ -> ] (2013-12-16, 21:09)Sunfel Wrote: [ -> ]@pecinko: found to profile manager ... this seems to be exactly what i have been looking for...
Depends on what you need to link to. File manager?
(2013-12-16, 21:11)pecinko Wrote: [ -> ] (2013-12-10, 17:30)isitmeor Wrote: [ -> ] (2013-12-10, 17:28)pecinko Wrote: [ -> ]I may add it in the next update.
File manager or a favourite would be nice
just something to get me going
(2013-12-16, 21:16)isitmeor Wrote: [ -> ]File manager or a favourite would be nice
You can assign item from a favorite to an empty slot in main menu. Take a look at skin settings.
(2013-12-12, 13:45)virgism Wrote: [ -> ]Thank you pecinko for this wonderful skin ! It's a best skin for RPi or ARM based device - fast and clean.
I have one question regarding PVR support - i want to show this information when switching channels:
Which file i need to edit or replace to achieve such thing ? As i understand , now PVR is showing DialogSeekBar.xml ?
I'll try to add it.
My first try :
http://www.ambernet.lt/down/DialogSeekBar.xml
My biggest problem now - DialogSeekBar window opens, when i close channel list, EPG window, volume, Home, etc. I need to show this window only when switching channel. What will be correct <visible> tag ?
Hello!
I wonder if it is possible to change the appearance of the certification in the interface. I'm french and I record it in the mpaa tag as:
"french:X" (note that some sites use "france" instead of "french")
with the value of X:
U, -10, -12, -16 or -18
This information therefore appears to me as "french:-10" for example. Is it possible to use a small logo or change the text for a better integration?
Thanks to you!
(2013-12-17, 13:12)Levi59 Wrote: [ -> ]Hello!
Thanks to you!
Post a screenshot with your problem, please.
how can i create a screenshot? XBMC is on Xbian (raspberry pi)...
