2017-08-05, 19:15
For whatever reason I have a copy of a crappy movie called Albion: The Enchanted Stallion (http://www.imdb.com/title/tt4518260/).
The imdb rating scrapper is not picking up the imdb ratings. For now I just put it in manually, but I wanted to highlight the issue for you in case others have problems with other movies.
I was able to confirm this with the following procedure: when I scrape the imdb rating with the latest current alpha of Ember, it says 7.0 with 6 votes. However, when I look at the imdb page, it says 5.1 with 460 votes. The 7 seems more like the moviedb rating. I was able to confirm this by removing the rating, disabling the imdb rating scraper and leaving the moviedb and the 7 with 6 votes is the result. Removing the rating, disabling the moviedb scraper, and leaving only the imdb scraper does not result in anything being scrapped.
In the log I see some exceptions like (like whenever I tried to rescrape it):
2017-08-05 13:11:58.6396,EmberAPI.HTTP,EmberAPI.HTTP.DownloadFile,5,ERROR,DownloadFile <>,"EXCEPTION OCCURRED:System.UriFormatException: Invalid URI: The URI is empty.
at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
at System.Net.WebRequest.Create(String requestUriString)
at EmberAPI.HTTP.DownloadFile(String URL, String LocalFile, Boolean ReportUpdate, String Type, String WebURL)* at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
at EmberAPI.HTTP.DownloadFile(String URL, String LocalFile, Boolean ReportUpdate, String Type, String WebURL)"
