Full Version: Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread
(2016-08-30, 10:10)DanCooper Wrote: [ -> ]
(2016-08-30, 02:41)ss4johnny Wrote: [ -> ]This is probably more of a UI issue than a bug (so maybe more a question of taste). Suppose I sort movies by watched. Then, I mark one of the movies as watched. It moves the cursor down to where the film marked as watched is. I have to then scroll back up to the top to see the unwatched stuff. This behavior is not obvious when sorted by title, but any other sorting can be a little annoying if you mark stuff as watched and then have to go back to where you were.
Yes, that's true. Maybe I can fix that, but I'm not shure. Please create e new enhancement on our bug tracker: http://bugs.embermediamanager.org
Done
http://embermediamanager.thebuggenie.com...ues/EMM-18
Under tools I have multiple separating lines - one too much.
PS: If you resize the boxes in "TV Shows", it will not be saved (Series, Season, Episode lists).
(2016-08-31, 14:08)archiv Wrote: [ -> ]Image
I will check that issue with double lines.
But the splitters will be safed if you close Ember properly (X oder File => Exit), if Ember isn't minimized.
Dan,
can you also add two bugs to your not fix list which i posted way back in this thread
or do i need to add to bugtracker myself?
Bug1 - context menu bug
http://forum.kodi.tv/showthread.php?tid=...pid2387333
Bug2 - renamer bug (critical bug)
http://forum.kodi.tv/showthread.php?tid=...pid2366365
(2016-09-01, 00:24)madmax2 Wrote: [ -> ]Dan,
Links are broken...
(2016-09-01, 09:00)DanCooper Wrote: [ -> ]
Links are broken...
Hmm not sure what happened there but i was trying to link to my comment
Anyway here is the page
http://forum.kodi.tv/showthread.php?tid=259449&page=35
there seems to be a bug in Renamer module in Alpha release.
It is not renaming the files correctly.
Despite using this setting for TV show renamer
-$Z - $W2_S?2E?{ - $T}
-Automatically rename after single and multiscraping
My files is getting rename to this..
ShowTitle - S01E01 - ShowTitle S01E01.mkv
OR sometimes to this, if I do an update library or rescrape
ShowTitle - S01E01E01 - Title - Title.mkv
There's a possibility it is cause by the custom scrape button.
Mine is set to ALL (automatic) , All Items
(2016-09-01, 09:56)madmax2 Wrote: [ -> ]
Links are broken...
That was the bug if you add a new tv show with episodes without any NFO?
I think the renamer bug has something to do with the scraping bug or existing NFOs:
Ember set the cleaned up episode file name as title if the episode can not be scraped while update the database (tv show is not scraped or no unique ID is known). If you scrape now the tv show and an episode can't be scraped (or with the other bug episode scraping is disabled), then Ember save the temp. title "ShowTitle - S01E01" as "proper" titel to NFO and the renamer change the filename to "ShowTitle - S01E01 - ShowTitle - S01E01.mkv". If you now remove the tv show from Ember and re-add it to database, Ember recognize the episode as multi-episode (ShowTitle - S01E01 - ShowTitle - S01E01.mkv) and chance the filename to something like "ShowTitle - S01E01E01 - Title - Title.mkv".
The only way to fix that if you change the file names, delete the NFOs and do a proper rescrape. Or chance the episodes manually in Ember via contextmenu => change episode.
(2016-08-31, 14:08)archiv Wrote: [ -> ]PS: If you resize the boxes in "TV Shows", it will not be saved (Series, Season, Episode lists).
Same here! Always closing correctly the program and next session it has default size. I guess its a bug because in movies section it works as expected.
Hi Dan,
Since the last 2 updates (Alpha) when i scan multiple or single video files the metadata is empty, only in a few cases it picks up HEVC.
Any idea how i can fix that.
I have been using for a while now without changing any settings and before it was ok
Thanks in advance for any possible help !!!
(2016-09-02, 02:15)FonziQ Wrote: [ -> ]Hi Dan,
Last change of MediaInfo class was in may and that was only a transfer of a container in another class.
Is it only not displayed in Ember or also missing in NFO? You can try the standalone version of MediaInfo and check if your file can be read. We also use MediaInfo to read all metadata.
Thanks for early response Smile
MediaInfo works fine with all sorts of video files, not sure why Ember and NFO come out blank.
<streamdetails>
<audio>
<channels>0</channels>
</audio>
<video>
<durationinseconds>0</durationinseconds>
<width>0</width>
</video>
</streamdetails>
</fileinfo>
</movie>
The only diferent thing i have done this time with alpha 22
is that i bought two 5TB hard drives and rescanned new movies and that happened. Previous scan with alpha 20 did add metadata.
If i delete a few NFO files and re-scan how would i be able to post a log so you can check out whats wrong, if possible of course.
Cheers!
Time to say good by for the next 10 days! You can catch me here if you want: sunandbass.net Big Grin
enjoy Sun&Bass Dan Smile
One for you when you get back: actor scraping doesn't work for Judgement Night (1993)
https://www.themoviedb.org/movie/6-judgment-night
2016-09-05 00:30:38.0613,EmberAPI.HTTP,EmberAPI.HTTP.DownloadFile,6,ERROR,DownloadFile    <>,"EXCEPTION OCCURRED:System.UriFormatException: Invalid URI: The URI is empty.
   at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
   at System.Uri..ctor(String uriString)
   at System.Net.WebRequest.Create(String requestUriString)
   at EmberAPI.HTTP.DownloadFile(String URL, String LocalFile, Boolean ReportUpdate, String Type, String WebURL)*   at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
   at EmberAPI.HTTP.DownloadFile(String URL, String LocalFile, Boolean ReportUpdate, String Type, String WebURL)"
2016-09-05 00:30:38.0613,EmberAPI.Themes,EmberAPI.Themes.LoadFromWeb,6,WARN,Theme NOT downloaded: ,
2016-09-05 00:30:38.1188,EmberAPI.HTTP,EmberAPI.HTTP.DownloadFile,6,ERROR,DownloadFile    <>,"EXCEPTION OCCURRED:System.UriFormatException: Invalid URI: The URI is empty.
2016-09-05 00:30:38.1188,EmberAPI.Trailers,EmberAPI.Trailers.LoadFromWeb,6,WARN,Trailer NOT downloaded: ,
2016-09-05 00:30:38.2428,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,6,TRACE,[ModulesManager] [RunGeneric] [Start] <Sync_Movie>,
2016-09-05 00:30:38.2428,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,6,TRACE,[ModulesManager] [RunGeneric] Run generic module <Kodi>,
2016-09-05 00:30:38.2428,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,6,TRACE,[Movie Scraper] [Done] Scraping Judgment Night (1993),
2016-09-05 00:30:38.2428,Ember_Media_Manager.frmMain,Ember_Media_Manager.frmMain.bwMovieScraper_DoWork,6,TRACE,[Movie Scraper] [Done] Scraping,
2016-09-05 00:30:38.3269,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_33_UpdateInfo_Movie.MoveNext,7,TRACE,"[APIKodi] [server2] UpdateInfo_Movie: ""Judgment Night"" | Start syncing process...",
2016-09-05 00:30:38.5280,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_27_SearchMovie.MoveNext,39,TRACE,"[APIKodi] [server2] [SearchMovie] ""\\NAS\movies\720p\Judgment Night (1993)\Judgment Night (1993) 720p.h264.ac3.hdtv.mkv"" | OK, found in host database! [ID:11767]",
2016-09-05 00:30:39.6128,generic.Interface.Kodi.Kodi.APIKodi,generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_33_UpdateInfo_Movie.MoveNext,46,TRACE,"[APIKodi] [server2] UpdateInfo_Movie: ""Judgment Night"" | Updated on host",
2016-09-05 00:30:39.6318,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,46,TRACE,[ModulesManager] [RunGeneric] [Start] <Notification>,
2016-09-05 00:30:39.6318,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,46,WARN,[ModulesManager] [RunGeneric] No generic modules defined <Notification>,
2016-09-05 00:30:40.0381,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,TRACE,[ModulesManager] [RunGeneric] [Start] <Notification>,
2016-09-05 00:30:40.0381,EmberAPI.ModulesManager,EmberAPI.ModulesManager.RunGeneric,1,WARN,[ModulesManager] [RunGeneric] No generic modules defined <Notification>,
Hi Dan,
Hope you had a good time bouncing to the music on your time away!
There is a bug where the Command-Line scraper doesn't do the Audio Codec mapping for Dolby Digital Plus. I added the mapping a_eac3 --> DolbyDigitalPlus but the command-line scraper sets the metadata to A_EAC3. If i re-scrape the metadata in the GUI it works fine.
My command-line is:
"Ember Media Manager.exe" -updatemovies -scrapemovies newauto all -profile English
New 1.4.8.0 Alpha 23 is online!
Now it's also available as x64 version (and yes, you can install the x64 version over your old x86 installation).
I'm still working an the fix to solve the multipart issues, also will fix all reported bugs on your bug tracker for alpha 24.
