(2017-05-27, 14:54)axlt2002 Wrote: [ -> ] (2017-04-10, 16:26)axlt2002 Wrote: [ -> ] (2017-04-10, 16:13)DanCooper Wrote: [ -> ]Yes, and also movie NFOs.
I've no idea. I don't know the default value for the "default" field (true or false). Maybe the XML parser in Kodi adds the "default=true" id on the first position in DB. Maybe the <id> has the hogher priority while adding the DB, maybe the <id> will be ignored if <uniqueid> is available. I think only a Kodi dev or a look into the source code can answer your question...
Yes, I will add that also to the next version. But atm I don't have run any tests with this.
Thanks! Good news!
P.S.: Honestly, about "default" (btw is present even in the ratings), I don't think is going to make any particular difference for me
EDIT:
I've just made a trial: the node that has default = true, is the one that will be used as <id> in the Kodi Library.
Hi Dan,
Just to know if the two formats for ids and votes will be part of the next release of EMM and when it will be available. I'm just asking because I have started to modify manually all my .nfo files to adapt to the new ids format...but such operation is going to make me crazy soon!!!!
UniqueID will be partially implemented in forthcoming version 1.5 Beta.
It's a write only implementation, import from NFO will be ignored. The nodes <id>, <imdb>, <tmdb> and <tvdb> will still be writed and readed.
Default uniqueid will be:
- imdb for movies
- tvdb for episodes and tv shows
New <ratings> node will be implemented in version 2.x
Just started using EMM for two instances of Kodi Interface for my living room and basement setup. Is there any good practices should know about when trying to manage both of them? Mainly for trying to get watch status? I see you can only set one in the get watched state but we watch different shows/movies.
During a scrape or update, does both kodi setups report watched states?
(2017-05-29, 16:39)AnthonyJS02 Wrote: [ -> ]Just started using EMM for two instances of Kodi Interface for my living room and basement setup. Is there any good practices should know about when trying to manage both of them? Mainly for trying to get watch status? I see you can only set one in the get watched state but we watch different shows/movies.
If both use the same source I don't think it's possible with Ember
But you can setup two accounts on Trakt and sync to each location, with Kodi add-on
(2017-05-29, 17:47)DanCooper Wrote: [ -> ] (2017-05-29, 16:39)AnthonyJS02 Wrote: [ -> ]Just started using EMM for two instances of Kodi Interface for my living room and basement setup. Is there any good practices should know about when trying to manage both of them? Mainly for trying to get watch status? I see you can only set one in the get watched state but we watch different shows/movies.
No MySQL setup for Kodi?
Havent ever looked into it, always just used trakt in past just wondering if there was another option.
(2017-05-29, 21:09)AnthonyJS02 Wrote: [ -> ] (2017-05-29, 17:47)DanCooper Wrote: [ -> ] (2017-05-29, 16:39)AnthonyJS02 Wrote: [ -> ]Just started using EMM for two instances of Kodi Interface for my living room and basement setup. Is there any good practices should know about when trying to manage both of them? Mainly for trying to get watch status? I see you can only set one in the get watched state but we watch different shows/movies.
If you use more than one Kodi client it's very usefull to use MySQL instead of two local databases. With MySQL both ore more clients use the same state. So it's not important which one you use with Ember or from wich one you get the watched state.... It's always the same data.
Just make sure you use exactly the same Kodi version so that you don't have problems with DB versions
Enviado do meu Nexus 4 através de Tapatalk
(2017-05-29, 21:14)DanCooper Wrote: [ -> ]It's always the same data.
And that's what OP says he don't want
He want different watch state on two installations of KODI and at least I don't understand how MySQL gonna help him or Ember for that matter.
If the watch state is in Embers DB and you sync, it will end up in KODI db also, whatever db you use
I can have misunderstood the question but what do I know
(2017-05-30, 01:23)T-bird_se Wrote: [ -> ] (2017-05-29, 21:14)DanCooper Wrote: [ -> ]It's always the same data.
Read this in opposite way as Dan, but you are correct.
He wants different watched status on different kodi instances so he has to have 2 different DBs.
(2017-05-30, 02:15)redglory Wrote: [ -> ] (2017-05-30, 01:23)T-bird_se Wrote: [ -> ] (2017-05-29, 21:14)DanCooper Wrote: [ -> ]It's always the same data.
Make no sense to use multiple databases with different watched states and then sync both states to Ember. The Kodi Interface do sync the state to all Kodi clients after getting the state if RealTimeSync is enabled. I think he used Trakt to sync both clients to ONE Trakt account to sync the watched state on both clients from time to time. But maybe I'm wrong...
(2017-05-17, 13:45)DanCooper Wrote: [ -> ] (2017-05-17, 13:18)Bjur Wrote: [ -> ]Okay thanks I will consider what to do. But are the BETA working absolutely fine and still have many of the same things as the alpha?
The 1.4.7.x Beta is WAYS back in development and no longer supported. I thought you wanted to use an older alpha version that worked for you.
I've to change our (crappy) version designations to help the users to understand which one is working or stable as possible.
Next release will be called 1.5.0 Beta (will be released in next 10-14 days).
That means all features are possible features has been implemented, so we have feature freezed state and I will only fix very bad issues they need to be fixed.
I'm already working on Ember v.2.0 that has been reworked at most of all core funktions, core code and modules/addons. A part of the features that I've promised for Alpha 24 will be only included in the first 2.x release. Sorry for that, but I did not expect it needs so many changes and optimizations.
It is absolutely nonsense to add new features and fix the same errors and problems on two versions.
At the moment, I'm just updating the bug tracker and adding all the steps to the milestones, so you have a little overview of the current state.
Cant wait for the release, checking every day
I just discovered Ember Media Manager two days ago, and I'm loving it so far, I been using Media Center Master for two years but Ember feels smarter when scrapping the movies, it needs less user interaction, the only thing that I still haven't figured out is how to add an additional poster image with the exact name as the movie file for other players and DLNA purposes. Does anyone know how?
(2017-05-31, 19:31)abescalamis Wrote: [ -> ]I just discovered Ember Media Manager two days ago, and I'm loving it so far, I been using Media Center Master for two years but Ember feels smarter when scrapping the movies, it needs less user interaction, the only thing that I still haven't figured out is how to add an additional poster image with the exact name as the movie file for other players and DLNA purposes. Does anyone know how?
You can add own file names under
Settings => Movies => Fiels and Sources => File Naming => Expert. Just add <filename>.jpg in the "Poster" field.
Hi Dan,
I'm having issues downloading a few TV thumbs.
Is this issue with TVDB or Ember or my internet connection?
Right click -> Rescrape Epsiode -> Right click thumb and click Select Image in popup window -> OK -> OK
2017-05-31 22:03:56.2305,EmberAPI.HTTP,EmberAPI.HTTP.DownloadImage,73,ERROR,DownloadImage <http://thetvdb.com/banners/episodes/194031/6043145.jpg>,"EXCEPTION OCCURRED:System.ArgumentException: Parameter is not valid.
at System.Drawing.Bitmap..ctor(Stream stream)
at EmberAPI.HTTP.DownloadImage()* at System.Drawing.Bitmap..ctor(Stream stream)
at EmberAPI.HTTP.DownloadImage()"
2017-05-31 22:03:56.4895,EmberAPI.HTTP,EmberAPI.HTTP.DownloadImage,26,ERROR,DownloadImage <http://thetvdb.com/banners/episodes/194031/6043145.jpg>,"EXCEPTION OCCURRED:System.ArgumentException: Parameter is not valid.
2017-05-31 22:03:57.9573,EmberAPI.HTTP,EmberAPI.HTTP.DownloadImage,53,ERROR,DownloadImage <http://thetvdb.com/banners/episodes/194031/6043145.jpg>,"EXCEPTION OCCURRED:System.ArgumentException: Parameter is not valid.
Right click -> Rescrape Selected Episodes -> any option -> All items
2017-05-31 22:01:18.9781,EmberAPI.HTTP,EmberAPI.HTTP.DownloadImage,20,ERROR,DownloadImage <http://thetvdb.com/banners/episodes/194031/6043145.jpg>,"EXCEPTION OCCURRED:System.ArgumentException: Parameter is not valid.
2017-05-31 22:01:19.6123,EmberAPI.HTTP,EmberAPI.HTTP.DownloadImage,73,ERROR,DownloadImage <http://thetvdb.com/banners/actors/239931.jpg>,"EXCEPTION OCCURRED:System.Net.WebException: The request was aborted: The request was canceled.
at System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.IO.Stream.InternalCopyTo(Stream destination, Int32 bufferSize)
at EmberAPI.HTTP.DownloadImage()* at System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
