Can you please provide the link.
Don't worry, I think I found it.
Wow, that looks complex. I think I'll just wait for the next release. Thanks anyway
(2017-06-11, 00:31)DanCooper Wrote: [ -> ] (2017-06-11, 00:15)shwetkprabhat Wrote: [ -> ] (2017-06-10, 14:33)komplex Wrote: [ -> ]You can build from his github if you can't wait
I see it has all the alpha branches, https://github.com/DanCooper/Ember-MM-Newscraper, does master is on the latest beta? Or I should look somewhere else...
Master branch will be the next 1.5 Beta. I still have to fix some small bugs and rewrite the resolution definition, but it works so far.
Ok - thats what I was wondering, thanks for the clarification.
(2017-06-11, 23:08)komplex Wrote: [ -> ] (2017-06-11, 21:38)JanM201 Wrote: [ -> ]Wow, that looks complex. I think I'll just wait for the next release. Thanks anyway
Here you go https://mega.nz/#!cM9VWCZD!VOLkZlOpQDxaY...ZvEPUjx0RA Built off the latest commit on github
Don't forget to reload all codec mappings and video source defaults in
Settings => Misc. to get the new HD-audio and video metadata.
Wow,
Thank you komplex, that's wonderful
Also, thanks Dan for the reminder about the codec mappings & all the hard work you do.
It's really appreciated.
(2017-06-12, 00:33)DanCooper Wrote: [ -> ] (2017-06-11, 23:08)komplex Wrote: [ -> ] (2017-06-11, 21:38)JanM201 Wrote: [ -> ]Wow, that looks complex. I think I'll just wait for the next release. Thanks anyway
Don't forget to reload all codec mappings and video source defaults in Settings => Misc. to get the new HD-audio and video metadata.
Can someone please explain to me how to reload all codec mappings & video sources (with pictures please)
See picture below:
This is a x265 movie. Does this look correct?
See next picture:
This is a x265 tv episode. This doesn't look correct.
Also, how do you map a 4K movie or tv episode?
Sorry for all the questions but I'm pretty new to this mapping thing.
(2017-06-12, 16:29)JanM201 Wrote: [ -> ] (2017-06-12, 00:33)DanCooper Wrote: [ -> ] (2017-06-11, 23:08)komplex Wrote: [ -> ]Here you go https://mega.nz/#!cM9VWCZD!VOLkZlOpQDxaY...ZvEPUjx0RA Built off the latest commit on github
See picture below:
See next picture:
New mapping will be added if you rescan/rescrape metadata of a file. You can use the "Refresh" button in the metadata frame or via contextmenu.
What is saved as codec of video stream 1?
EDIT: As I mentioned earlier, the determination of resolution is not yet finished. It is possible that the resolution icon does not show.
Ok Thanks.
(2017-06-12, 00:33)DanCooper Wrote: [ -> ]Don't forget to reload all codec mappings and video source defaults in Settings => Misc. to get the new HD-audio and video metadata.
Can you please explain how I do the above.
Howdy
I am having some problems getting all of my movie sets to show up in kodi
I am using SQL DB also for libary syncs
At this point only about half of the indicated sets in Ember are visible in Kodi
(2017-06-12, 21:28)snuffy47 Wrote: [ -> ]Howdy
Kodi shows only sets with more than one movie.
(2017-06-12, 19:15)komplex Wrote: [ -> ] (2017-06-12, 18:14)JanM201 Wrote: [ -> ]Can you please explain how I do the above.
I think he means these
Yes, that's exactly what I mean. What do I need to do here? I see there's "Defaults", "Add" & "Remove" buttons, but I don't know what they do?
Thanks for any help.
(2017-06-12, 22:50)JanM201 Wrote: [ -> ] (2017-06-12, 19:15)komplex Wrote: [ -> ] (2017-06-12, 18:14)JanM201 Wrote: [ -> ]Can you please explain how I do the above.
Load defaults.... Default button...? I mean I'm not Columbo, but...
Thanks. When would you use the other 2 buttons - Add & Remove?
