2012-02-11, 00:02
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
2012-02-11, 00:02
README.txt(english) and LISEZMOI.txt (french) are provided in the ZIP file.
EDIT : Martijn is the faster
2012-02-11, 00:06
Sorry, should have downloaded it and checked first.
Thanks anyway.
Thanks anyway.
2012-02-11, 18:04
Little problem when running script with Last parameter.
Request does not return movie in date ordre but in alphabetical ordrer, even if I put a sort order on date in JSONRPC request.
2012-02-12, 13:00
great initiative, testing it as we speak. just a heads up if this goes to official repo; you should rename the addon to all lowercase, don't think it's allowed to have uppercase in the addon foldername.
2012-02-12, 22:10
I'm not getting any trailer info with this script, is it just me or is it the script?
2012-02-12, 23:28
Getting some error key error. Probably when it is returning nothing as a result
http://paste.ubuntu.com/839679/
http://paste.ubuntu.com/839681/
It's best to catch these. If you want a full log let me know
2012-02-13, 00:05
No info trailer (not sure about that)
2012-02-13, 10:06
Properties raised by the script are :
Playlist<method>Movie<menu>.Count
Playlist<method>Movie<menu>.<# of movie>.Title
Playlist<method>Movie<menu>.<# of movie>.Rating
Playlist<method>Movie<menu>.<# of movie>.Year
Playlist<method>Movie<menu>.<# of movie>.Plot
Playlist<method>Movie<menu>.<# of movie>.RunningTime
Playlist<method>Movie<menu>.<# of movie>.Path
Playlist<method>Movie<menu>.<# of movie>.Trailer
Playlist<method>Movie<menu>.<# of movie>.Fanart
Playlist<method>Movie<menu>.<# of movie>.Thumb
See README.txt in the ZIP file.
But I can add this info if needed.
2012-02-13, 10:16
The actual version did not handle properly "Recently added movies".
List is return in alphabetical ordre.
But Montellese give me a tip.
I will add to 2 options :
* "Watched" to display only unwatched movies (Random or Last)
* "Resume" to display movies started to watch and not finished
Stay tuned
Stay tuned
2012-02-13, 10:18
Martijn Wrote:Getting some error key error. Probably when it is returning nothing as a resultThanks for your logs.
Errors are due to movie sets returned in movie list.
New version will handle this case.
2012-02-13, 14:31
Version 1.0.2 is available for test :
http://passion-xbmc.org/addons/Download....-1.0.2.zip
I will put the script in the repository if you don't found any bugs on this version.
Last added movies is now OK and sorted by alphabetical order.
2 new options :
UNWATCHED =
True : Return only unwatched movies (playcount = 0)
False : Return all movies (watched and unwatched)
RESUME =
True : Return only movies partially watched
For partilly watch movies, test is based on resume.position propertie :
'resume': {'position': 0, 'total': 0},
Si if position = 0 then movie is not partially unwatch.
I think that I should take the ratio between position of the resume and the total length of the movie. If ratio between 5% (to avoid movies played for few seconds and stopped) and 95% (when you stop the movie before credits) then movie is partially unwatch.
Do you think is a good idea ?
2 new options :
UNWATCHED =
RESUME =
2012-02-13, 16:48
mikebzh44 Wrote:Properties raised by the script are :
I meant that Playlist<method>Movie<menu>.<# of movie>.Trailer is always returning empty for me.
2012-02-13, 16:59
New version 1.0.3 :
http://passion-xbmc.org/addons/Download....-1.0.3.zip
Propertie Trailer is now OK.
2012-02-13, 19:37
Im having problems with the script loading my playlist. The playlist is there in xbmc & working perfectly.
Im using a hidden button to run:
"<onfocus>XBMC.RunScript(script.RandomAndLastItems,limit=10,method='Last',playlist='special://profile/playlists/video/1234.xsp','menu=Menu1')</onfocus>"
But I just get an error
Debug gives me:
"WARNING: CUtil::GetMatchingSource... no matching source found for ['special://profile/playlists/video/1234.xsp']"
"WARNING: XFILE::CFactoryDirectory::Create - Unsupported protocol('special) in 'special://profile/playlists/video/1234.xsp'"
Am i doing something stupidly wrong?
Debug gives me:
