Which skin are you using ? Because I think this script is a little bit deprecated and all major skin use built-in Kodi function to work with smart playlist.
(2016-07-28, 18:24)mikebzh44 Wrote: [ -> ]Which skin are you using ? Because I think this script is a little bit deprecated and all major skin use built-in Kodi function to work with smart playlist.
I use estuary
do you mean it exist built in functions to count titles in a smartlist for example?
Yes. Look into Aeon Nox 5 for example.
I guess you are modding Estuary.
Envoyé de mon Nexus 5X en utilisant Tapatalk
(2016-07-28, 19:37)mikebzh44 Wrote: [ -> ]Yes. Look into Aeon Nox 5 for example.
yes im modding estuary.
thanks alot, im struggling to find that though
Is somebody updating this addons voor V19?
Kind Regards
All features from this script can be coded directly into skins now. So it's not really needed anymore.
I just removed support in Rapier for Kodi Matrix.
