(2012-12-27, 14:42)mikebzh44 Wrote: [ -> ] (2012-12-27, 14:00)Martijn Wrote: [ -> ]hmm i see "property" somehow got uppercase in the code. Will fix that.
Did change to correct spelling though
propertie=HomePlayListSeven -> property=HomePlayListSeven
Yes, sorry for my english
One property, two properties
Nice job Martijn.
I think I can migrate from Eden / Aeon Nox 3.6.1 to Frodo / Aeon Nox 4.0 now
Non native languages can be be difficult sometimes
Mudislander
Change (for testing)
PHP Code:
PROPERTY = param.replace('PROPERTY=', '')
to
PHP Code:
PROPERTY = param.replace('property=', '')
Martijn
Okay changed the code in the script & and the label "propertie" in the skin. According to the debug log the script runs, takes upto 3 secs for a big playlist, with no erros. However I'm not able to display the results.
Would it be possible to get a script that spams the log with what it's found in the playlist (even if only for Movies) - or could you tell me how to change the script to spam the log?.
I did see you've enabled the .Art( * ) labels.
Cheers
Exampl
PHP Code:
for _movie in _result:
if xbmc.abortRequested or _count == LIMIT:
break
log(_movie)
_count += 1
This will print all data for each movie that would be added to the list.
also works. Same principle counts for all others.
Martijn - I'll have time to check the script thoroughly tomorrow but ATM it looks like the script option "property=SomeMenuItemName" (used to be - "propertie=*****") Is not functioning as it used to.
if I use the option "menu=******" I can get results to show up in the skin, however forcing the name with "property=*****" returns no results under the correct menu item name.
Two things I personally need from the script is the ability to force the menu name eg:property=HomePlayListOne and also the script being able to report back that the playlist used was for Movies,Episodes or Albums.
Cheers hey.
Edit By running
PHP Code:
XBMC.RunScript(script.randomandlastitems,limit=10,method=Random,playlist=special://profile/playlists/video/Unwatched Movies.xsp,property=Menu1)
I need to enter
PHP Code:
$INFO[Window(home).Property(PlaylistRandomMovieMenu1.8.Title)]
To get results but I need $INFO[Window(home).Property(Menu1.8.Title)]
Just tested now version 2.0.0
- movies method=Last working perfectly
to call the script for episodes i use method=Last too, is this still avaiable ? because i get a script error when calling episodes.
I was playing with the script in Aeon Nox 4.0 and I wasn't able to display widgets for smart playlists.
Don't know if it's normal but AE set UNWATCHED parameter to blank and not to false by default.
I have add a test (line 594) :
elif 'unwatched=' in param:
UNWATCHED = param.replace('unwatched=', '')
if UNWATCHED == '':
UNWATCHED = 'False'
(2012-12-28, 22:54)Mudislander Wrote: [ -> ]@Martijn - I'll have time to check the script thoroughly tomorrow but ATM it looks like the script option "property=SomeMenuItemName" (used to be - "propertie=*****") Is not functioning as it used to.
Cheers hey.
Edit By running
PHP Code:
I need to enter
PHP Code:
I have do the same with Aeon Nox 4.0 :
In skin :
RunScript(script.randomandlastitems, type=Movie, playlist=special://profile/playlists/video/Parents.xsp, method=Latest, limit=10, unwatched=False, resume=False, property=SmartPlaylist1)
In script, I have change line 590/591 :
elif 'property=' in param:
Just to be sure, I have put some debug in log file :
if PROPERTY == "":
PROPERTY = "Playlist%s%s%s" % ( METHOD, TYPE, MENU )
print("##### PROPERTY SET TO DEFAULT", PROPERTY)
else:
print("##### PROPERTY SET TO ", PROPERTY)
And property is OK :
16:52:51 T:4416 NOTICE: ('##### PROPERTY SET TO ', 'SmartPlaylist7')
16:52:51 T:4916 NOTICE: ('##### PROPERTY SET TO ', 'SmartPlaylist1')
mikebzh44 Thanks - That gets movie playlists working.
Now I need to redo TVShow & music librararies on test machine to check them
mike
Could you pastebin.com your changes so I could see where I screwed up?
I'll add it to github too
Real welcoming message on github - "Nothing to see here yet. Move along."
Martijn.
Aeon Nox 4.0 will be available soon on official repository and Phil call script this way :
RunScript(script.randomandlastitems, type=Movie, playlist=special://profile/playlists/video/Parents.xsp, method=Latest, limit=10, unwatched=False, resume=False, PROPERTY=SmartPlaylist1)
But if script now require property= parameter, widgets skin will be broken :S
Is there a smart way to handle this case in python ( uppercase ? lowercase ? double test ?) ?
(2013-01-02, 10:49)mikebzh44 Wrote: [ -> ]Martijn.
fixed that, ronie will pull with fix included.
Updated in repo and put code on github.
@ mikebzh44
You have full rights so you can maintain it too
