(2013-11-19, 12:49)baijuxavior Wrote: [ -> ]Just an update - there is no error now with the latest build, except that the last added 2d movie is not displayed on the widget, even though the smartplaylist shows this movie. I will try to add new movies and see if the problem exists.
If you browse your smart playlist : Videos > Playlists it's OK ?
(2013-11-19, 14:17)butchabay Wrote: [ -> ] (2013-11-19, 00:23)mikebzh44 Wrote: [ -> ]Yes, will have a look but, from what I understand from Martijn post, it should work so may be the issue come from Gotham, not from the skin.
Will do some tests and ask to Montelesse if it's a JSON RPC issue.
Thanx mate.
I think it's a JSON RPC issue :
http://forum.xbmc.org/showthread.php?tid...pid1554858
I'm using the Xperience1080 skin which uses this script but it has never worked for me. Turning on logging I see the following two bugs/issues (I'll add the log in a few hours)
1. The script doesn't like spaces in filenames on SMB shares and causes an error
2. There's a JSON RPC issue that shows up after removing the space in the filename which causes the script to fail anyway
The smart playlists work fine when accessed directly.
Using Frodo 12.2 on both RaspberryPI and Win7 (same issues)
Hi Mike, just wanna let you know the script is working with today's nightly (30.11.2013) ... thanx for forwarding my problem.
Cheers
(2013-11-30, 23:07)butchabay Wrote: [ -> ]Hi Mike, just wanna let you know the script is working with today's nightly (30.11.2013) ... thanx for forwarding my problem.
Cheers
butchabay - so is calling a playlist from the skin folder working for you? Not for me, can only use playlists from userdata folder.
(2013-12-29, 23:39)Mudislander Wrote: [ -> ] (2013-11-30, 23:07)butchabay Wrote: [ -> ]Hi Mike, just wanna let you know the script is working with today's nightly (30.11.2013) ... thanx for forwarding my problem.
Cheers
@butchabay - so is calling a playlist from the skin folder working for you? Not for me, can only use playlists from userdata folder.
Yes it works, even i'm getting a script error and i don't know why
Ok, I have never got this script working on neither RPI (Openelec) nor Win7 under the Xperience1080 skin. Can anyone shed any light on how to get this working or what is wrong?
I tried now on my win7 pc using both a mysql database and afterwards just scanning some files directly into the library (removing advancedsettings.xml and thus just using defaults), movies, but made no difference. Tried also playlists on both local drive and a share. Tried using Frodo 12.2/3. Have also tried updating to the 2.1.9 version on github..
See here for the two logs (close to the tail of the logs there's json rpc errors, parse error) and nothing is displayed in the skin.
http://www.xbmclogs.com/show.php?id=103680 (using mysql database)
One playlist looks like this:
<?xml version="1.0"?>
<smartplaylist type="movies">
<name>Barnefilmer</name>
<match>all</match>
<rule field="path" operator="contains">Filmer - Barn</rule>
<order direction="descending">title</order>
</smartplaylist>
(2013-12-30, 21:05)Martijn Wrote: [ -> ]debug log
Yeah Martijn i know ...
I try to post a log tomorrow, now let's watch a movie first !
Martijn
Well mate, nothing's wrong with the script, was my fault.
I called a playlist with the wrong .xsp name
Cheers
(2014-01-06, 20:21)butchabay Wrote: [ -> ]@Martijn
Cheers
Oh hehe just remembered that I needed to look. Maybe fail graceful instead of error
Can you still give me a log?
Hi Mudislander.
Cannot access pastebin from my office (thanks to the firewall
Could you paste you logs to xbmclogs.com ?
Sure
Playlist in skin folder
Playlist in userdata folder
Just out of interest one (and only one) playlist in the skins folder has just worked - usually means my error. So I'll tear everything down to recheck how the script is run. If you could check the log for me to see if you can see anything , I'd be grateful
