Continuation (not sure what else they could be) - Kodi master has now branched, with Jarvis for Kodi 16, and master continuing on as Kodi 17. With the new version comes API bumps, some add-ons may need updating.
If you were happy with the Kodi 16 builds you should be happy with these.
Just been through this API incompatibility issue when compiling OE for the WeTek Core.
Any Kodi version after Jarvis Beta3 will need all pvr.clients compiled from their respective updated master GitHub Repos.
Changing the source works ,but switching off-/on my Samsung TV and then there is no connection to the PI2. Solution: Yatse + input, and then there is a connection. Same Problem with hdmi_edid_file=1 and hdmi_force_hotplug=1.
debug log :
http://pastebin.com/V8MhuVVY
(2015-12-14, 02:57)J_E_F_F Wrote: [ -> ]I am running #1128 Jarvis nightly on a rPi2 with no addons. There seems to be quite a few problems with addons in these 17/k builds. Is this a continuation of the nightlies from the 16/j series, or a completely new 17/k build? IE, if I was mostly happy with the 16 nightlies for the past few months with the occasional nightly hiccup, can I expect the same from these early stage 17/k builds on a stock rPi2?
A few weeks back the kodi 16 builds were late beta builds, so there had been no recent new features or API changes and so the chances or skin/add-on breakage were limited.
Now kodi 17 is in early alpha stage. New features are API changes are being merged regularly so breakage is more likely.
(2015-12-14, 13:58)Kougami Wrote: [ -> ]Changing the source works ,but switching off-/on my Samsung TV and then there is no connection to the PI2. Solution: Yatse + input, and then there is a connection. Same Problem with hdmi_edid_file=1 and hdmi_force_hotplug=1.
First thing we need to know is if you are reporting a regression.
Did an earlier Milhouse build behave better? Does the official OE 6.0 build behave better?
(2015-12-14, 14:01)popcornmix Wrote: [ -> ] (2015-12-14, 13:58)Kougami Wrote: [ -> ]Changing the source works ,but switching off-/on my Samsung TV and then there is no connection to the PI2. Solution: Yatse + input, and then there is a connection. Same Problem with hdmi_edid_file=1 and hdmi_force_hotplug=1.
Only with OE 5 works. I have the problem since OE 6+.
(2015-12-14, 14:18)Kougami Wrote: [ -> ]Only with OE 5 works. I have the problem since OE 6+.
I'd suggest reporting it, with a debug log with CEC component specific debugging enabled, in both the working OE 5 and non-working OE 6 case here:
https://github.com/Pulse-Eight/libcec/issues
Use OE stable builds, not experimental builds for the logs as it is easier to track the versions of libcec is use.
On 2015-08-28 16:25 Milhouse wrote
(2015-08-28, 16:25)Milhouse Wrote: [ -> ]Unfortunately scrolling text is a known performance issue - the simplest solution is to highlight a shorter label that won't cause scrolling.
Perhaps it's possible to stop text from scrolling when a player is active on single-core platforms such as the Pi1 that are more sensitive to GUI updates.
(2015-08-28, 16:16)MrNice Wrote: [ -> ]Isengard 5.945.4
CPU usage very high when horizontal text scroll happen.
To reproduce, create an empty folder, name it with a long character string or/and rename a music/video file with a long string.
Compare CPU usage between no scrolling and a scrolling name with debug or ssh/top
With my RPi1-512 overclocked at 1000 I get:
Low: 15-20%
High:65-75%
When I play HD multichannel music I get drops.
I still can't play some files, a lot of drops due to scrolling text.
Is there any improvement in the new build, fix or workaround?
(2015-12-14, 14:21)popcornmix Wrote: [ -> ] (2015-12-14, 14:18)Kougami Wrote: [ -> ]Only with OE 5 works. I have the problem since OE 6+.
Ok sorry for the wrong infos, after testing:
-> OE 6 : Seems works
-> OE 6 build with libCEC 3.0.1: works
-> Milhouse build: after switching off-/on my Samsung TV , no signal to PI2
But i have discovered something: switching off-/on my Samsung TV -> no signal to PI2 -> push a button on remote control -> connection to PI2 . It's not a bad resolve
(2015-12-13, 18:23)popcornmix Wrote: [ -> ] (2015-12-13, 15:04)MikeKL Wrote: [ -> ]Been using ITV Player (plugin.video.itv-2.2.6) successfully for ITV catchup until switching from last testbuild of (Kodi 16.0) to latest testbuild of (Kodi 17.0)
Hope information is useful/helpful.
Thanks. I can reproduce the issue and have identified the commit (from fernetmenta's branch) that causes the problem.
I've reverted for now, and reported it, so ITV player should be working in the next build.
I have just installed and confirm that ITV Player catchup content is working normally in build #1213
(2015-12-14, 19:50)MikeKL Wrote: [ -> ]I have just installed and confirm that ITV Player catchup content is working normally in build #1213
Cool. You might want to test again tonight. That reinstates the reverted commit and adds a fix from FernetMenta.
ITV player is still working fine for me.
My useless statement to the new build :-|
DVD 9 (video_TS.ifo) Menue works in that build. Next Chapter and last Chapter works also.
O.K.
ISO file (9GB) works also - with fast buffering - chappooo ;-)
Video Addon MTV.de also running (although in Windows Kodi a little better - more songs)
O.K.
*rec files from my topfield2410 TwinHD-Sat-Recorder also playable over ftp.
O.K.
some wishes...
...only on one miniDVD in DTS5.1have problems - if i make "stereo upmix" with hifiberry DAC i here my Alan Parsons Projekt sound.
...On the other RPi2 over HDMI on LCDtv wit DTS6.1 Receiver this mimiDVD didn't work (hmm) proceed as normal in #1001.
#1001 plays perfect without exchange sth. in the settings.
New OpenELEC K* build #1214:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.3.2 #1 Mon Dec 14 21:06:33 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Dec 8 2015 14:44:44
Copyright (c) 2012 Broadcom
version e591b5eb05e2cdb1b5ae25512b27d33127d7bee9 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151214210542-#1214-g564e22f [Build #1214]
# vcdbg log msg 2>&1 | grep DTOK
001710.818: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (564e22fc,
changelog) and tip of
XBMC master (17fb8a30,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.3.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (8044e23a, ahead +114)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (2f625959, ahead +40)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest p8-platform master (cce6a497, ahead +10)
- Includes platform master (a1e59058, ahead +8)
- Includes latest addons: adsp.basic (cb56e0eb, +4), adsp.biquad.filters (d63d8ac6, +6), adsp.freesurround (08b691d3, +1), asplib (2fac1bf3, +2), pvr.argustv (3d8f13f9, +1), pvr.demo (e6f4d317, +1), pvr.dvblink (1cbc6dc1, +6), pvr.dvbviewer (03ed8718, +1), pvr.filmon (e74e9714, +1), pvr.hdhomerun (070aca3b), pvr.hts (f6a37db7, +4), pvr.iptvsimple (eda38ccf, +1), pvr.mediaportal.tvserver (93de38e2, +4), pvr.mythtv (1f123bba, +5), pvr.nextpvr (0547ce53, +2), pvr.njoy (eac0f6fc, +1), pvr.pctv (2ca34f92, +1), pvr.stalker (9400b421, +17), pvr.vbox (5571c04b, +1), pvr.vdr.vnsi (a3cf9de0, +11), pvr.vuplus (42b2af59, +1), pvr.wmc (4e291de2, +3)
- Exclude [env] bcm2708-rng.conf: No longer required
- Exclude [env] kodi-999.22-PR8254.patch: Already using VideoPlayer version
- Exclude [env] kodi-999.23-PR8411.patch: Merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] libcec-01-add-repeating-keypress.patch: Already merged upstream
- Exclude [env] libcec-02-fix-crash-on-some-systems.patch: Already merged upstream
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] compare: ffmpeg: Bump to 2.8.3; Disable Tearfree & Triple Buffering; Bump Intel video, include completion signal
- Include [env] compare: ffmpeg: Package kodi's ffmpeg releases directly
- Include [env] compare: EGL/4K/HEVC, mesa, Use Limited Range by default, bump xf86-video-intel; linux cleanup
- Include [env] patch: Add p8-platform package
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: CONFIG_TOUCHSCREEN_FT6236 is not set
- Include [env] patch: Fix OE after platform move
- Include [env] patch: ARCH_BCM270X: Drop ATAGS support, https://github.com/raspberrypi/linux/pull/1178
- Include [env] patch: Enable DMA_BCM2835, needed by i2s audio cards in 4.3 kernel
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4484: Bump kernel 4.3.2
- Include [env] PR:4487: libaacs: add upstream patches
- Include [pkg] patch: Fix libcec RPi platform detection (libcec)
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8196: jsonrpc: expose profile directory in Profiles.GetCurrentProfile/GetProfiles.
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8481: fix saving of skin settings when switching profiles
- Include [pkg] PR:8545: [mysql] Querying optimizer_switch needs to be non-fatal
- Include [pkg] PR:8561: [PVR] Feature: Separate windows for "Recording Rules" and "Timers"
- Include [pkg] PR:8583: FFmpeg: Implement image thumbnails
Build Highlights:
- dcadec updates
- FFmpeg: Implement image thumbnails
Build Details:
- OpenELEC:
- ffmpeg: enable mjpeg encoder (PR:4488, 1 commit, 1 file changed)
- XBMC:
- [gui] move cancel button in select dialog to core (PR:8417, 3 commits, 23 files changed)
- fixed: Typo in README.ubuntu (19628423)
- dcadec:
- Remove unused argument. (386f1f05)
- Remove unused define. (a1184b52)
- Merge X96 decoder into core structure. (7276d154)
- Parse X96 extension after XBR. (d818bef0)
- Use defines for number of downmixing coeffs. (76f1ca40)
- Validate XXCH downmix channel mapping mask. (a4a3e9ab)
- Clean up XXCH structure fields and related code. (08c3ef1d)
- Shrink core frame data arrays. (e324c83a)
- Fetch SEL once per channel. (9e0bd2ca)
- Remove unnecessary use of size_t. (f59665d3)
- Sanitize XLL decoding delay. (7914774b)
- Sanitize maximum packet size. (3485b2ce)
- Sanitize NAVI table size. (47e29aec)
- Fix reading large linear and Rice codes. (876ae149)
- Remove assertions from bits_get(). (6959a721)
- Make locally used function static. (da7eb885)
- Simplify some nested if () statements. (ec9d520b)
- Simplify X96 VQ decoding. (a0204989)
- Refactor NAVI position validation. (f93bc056)
- Group per-band data into separate structure. (ae6a0a72)
- Use define for maximum prediction order. (c66683c6)
- Remove channel set looping macros. (b9b5582f)
- Refactor how inactive channel sets are skipped. (1a22f91b)
- Simplify dequantize(). (ea7023c1)
- Remove dca_clz64(). (bcc1f7e8)
- Refactor core audio extraction. (b86a097f)
- Optimize initialization of core arrays. (8cf6a422)
- Use defines for number of EXSS channel sets. (b32e72fb)
- Move channel layout defines to common header. (8044e23a)
- pvr.wmc:
- Child timers of an AnyChannel parent should show the actual channel (PR:29, 1 commit, 1 file changed)
- newclock5:
- New commits in this build:
- squash to simplify demux pause (bf370c28)
- [build] Add patches to ffmpeg for native build (7aaec093)
- Commits no longer in build:
- Revert "VideoPlayer: simplify pausing of demuxer" (41c6f2c1)
- Updated: [env] PR:4487: libaacs: add upstream patches
- Added: [pkg] PR:8583: FFmpeg: Implement image thumbnails
(2015-12-14, 19:59)popcornmix Wrote: [ -> ] (2015-12-14, 19:50)MikeKL Wrote: [ -> ]I have just installed and confirm that ITV Player catchup content is working normally in build #1213
Just checked and ITV Player catchup content appears to be working normally in build #1214 with quick test
After updating to #1213 last night (still using TVh #1205) I found that there was stutter/audio drop about every 15s. Watching the overlay, I saw that the err ms were increasing by about 10 every second and the stutter occurred when it got to about 150ms and then reset to 0ms.
I haven't been able to consistently reproduce it this morning after a reboot. It didn't happen with the first channel I tried, BBC One, but did when I switched to Channel 4 but then I couldn't reproduce it on that or any other channel.
Log:
https://drive.google.com/file/d/0B1fDI89...sp=sharing
I'll try updating to the latest TVh and keep an eye on it.
