(2016-03-03, 20:56)Milhouse Wrote: [ -> ] (2016-03-03, 17:05)zaphod24 Wrote: [ -> ]I don't appear to have access to the Estuary thread you linked to.
Oh right, sorry - turns out that was a private discussion thread. You'll have to trust me the issue has been seen in Windows - as soon as there's a fix I'll include it in these builds.
Ha! I will always trust you Milhouse
You're doing everyone a great service in providing these builds. Despite the complaints (some of which are valid) I've seen in the public Estuary thread, I really like the new skin. It's great to finally have something new that will be considered the default and standard. I look forward to seeing the improvements it will get.
Most of features in Yatse isn't working with the Estuary release. Can someone confirm this?
(2016-03-03, 12:42)noggin Wrote: [ -> ] (2016-03-03, 12:12)f1vefour Wrote: [ -> ] (2016-03-03, 11:22)Milhouse Wrote: [ -> ]@opeters: you'll need to test it yourself, I don't have a 3D TV.
Does OpenELEC or KODI not provide developers with test equipment?
In general I believe no. OpenElec and Kodi are community run development teams, with almost everyone working voluntarily (there are some devs who are also employed by manufacturers). Some manufacturers may donate development boards to devs, as they see the value in Kodi running well on their devices (which will trigger sales), but AIUI neither OpenElec nor Kodi have the money to buy their devs expensive 3D TVs...
I was simply asking, not saying they should.
I was under the assumption that large projects which accept donations have a surplus of funds beyond what is output to servers and associated costs. This surplus going to fund core development, not by paying developers but by supporting their needs as developers.
Sorry if my question offended anyone, no further responses necessary as it will disrupt the thread.
(2016-03-03, 21:44)opeters Wrote: [ -> ]Since I use DVBLink.. when will it be available again (#215 "stop building pvr.dvblink and pvr.dvbviewer") ?
Those add-ons have been dropped because they don't work with Kodi 17 and there is no active maintainer. Unless someone steps forward they're going to remain dropped, so there is no estimate I can give you. My advice would be to find an alternative.
New OpenELEC Krypton build #0303:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.3 #1 Thu Mar 3 21:05:59 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Mar 3 2016 20:05:15
Copyright (c) 2012 Broadcom
version dde4ad1fe6f2d1f0fde268be91c5faed754153bc (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160303210507-#0303-gbe987d4 [Build #0303]
# vcdbg log msg 2>&1 | grep DTOK
001783.071: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (be987d4e,
changelog) and tip of
XBMC master (6d20fcba,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest bcm2835-driver master (7f7b3681, ahead +23)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (eebe56ce, ahead +10)
- Includes latest p8-platform master (38343e0a)
- Includes latest addons: pvr.argustv (501f56b3, +21), pvr.demo (116a172a, +16), pvr.filmon (4beb05da, +23), pvr.hdhomerun (3f0dd8e6, +29), pvr.hts (0814da42, +55), pvr.iptvsimple (1dfc3547, +24), pvr.mediaportal.tvserver (4860e622, +48), pvr.mythtv (44df4430, +25), pvr.nextpvr (1871323c, +23), pvr.njoy (4f30f4af, +16), pvr.pctv (522f9603, +21), pvr.stalker (0402f465, +20), pvr.vbox (b0916449, +23), pvr.vdr.vnsi (2089549a, +21), pvr.vuplus (4cf6ad02, +19), pvr.wmc (9a83292f, +22)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 2f83a1cf: xf86-video-intel: bump to 8b8c9a36 (fixes segfault when refreshrate changing)
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] 858f6461: xf86-video-intel: bump to 371219c
- Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
- Include [env] patch: Enable other binary addons
- Include [env] patch: Enable OpenELEC add-ons and repositories in manifest
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4500: kodi: update to 17.0
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4661: stripping changes
- Include [env] PR:4808: projects/RPi*/patches/linux: Add various options required by latest RPi kernel
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8723: Implement filecache retry logic
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9225: Fix out of memory crash in CArchive
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- New firmware
- Bump OpenELEC 8.0
- [VideoPlayer] Added new msdk-mvc decoder, with upstream libbluray support
Build Details:
- Firmware (Mar 3):
- firmware: pwm_sdm: bugfixes See: link
- firmware: Correct Camera GPIOs for Pi3 rev1.2. See: link
- firmware: arm_loader: Avoid spurious assert when turbo mode is limited
- firmware: arm_display: Avoid losing warning square when display is powered off
- OpenELEC:
- Package updates (PR:4809, 6 commits, 6 files changed)
- libssh: update to 0.7.3
- gdb: update to 7.11
- libass: update to 0.13.2
- nano: update to 2.5.3
- libinput: update to 1.2.1
- xf86-input-libinput: update to 0.17.0
- xpad: update Xbox 360 wireless controller driver w/latest fixes (PR:4810, 1 commit, 1 file changed)
- XBMC:
- [Estuary] - Skin sync (PR:9251, 1 commit, 30 files changed)
- [RendererIMX] release locked m_buffers on destroy to cleanup all used… (PR:9255, 1 commit, 1 file changed)
- [DVDVideoCodecIMX] update after process info (PR:9254, 1 commit, 2 files changed)
- IMX: Do not call non existing method SetSkipMode() (PR:9182, 1 commit, 2 files changed)
- Implement ignore url options in CFileItemList (PR:8822, 1 commit, 3 files changed)
- fixed: Screensaver would lockup Kodi when stopping on slow systems (PR:9204, 1 commit, 1 file changed)
- Fix stuttering on Android (PR:9250, 3 commits, 3 files changed)
- newclock5:
- New commits in this build:
- [VideoPlayer] DemuxFFmpeg: Properly demuxing h264_mvc streams. (de048e06)
- [VideoPlayer] DemuxFFmpeg: ssif remux (47ba144c)
- [libbluray] bump libbluray to 0.9.2-mvc. (2f8ae423)
- [VideoPlayer] Fix enabling stereo when resume MVC playback. (17ce4f8c)
- [3DBD] Added support of 3D-BluRay playback. (1c1ebd96)
- [StereoscopicsManager] Added mvc modes. (64059768)
- squash: new modes (789c57ba)
- [VideoPlayer] Added new msdk-mvc decoder. (b2e5633a)
- ssif: Avoid corrupt images when mvc queue is empty (a3753f8b)
- [BaseRenderer] Fix aspect for TAB/SBS (ced30d30)
- [VideoPlayer] Notify player about video parameters change if stereo mode of decoded picture was changed. (f82023b4)
- Commits no longer in build:
- [VideoPlayer] Support filename mangling for MVC files v2 (c78a450f)
- [videoplayer] Use InputStream's filename for determining stereoscopic mode (dc8687ec)
- ffmpeg: hack: skip continue in timestamp wrap update it breaks ssif seeking (2b84db82)
- Properly demuxing h264_mvc streams. (3ab29539)
- [VideoPlayer] ssif remux (52049c68)
- fixup! [VideoPlayer] ssif remux (bd7b718c)
- fixup! [VideoPlayer] Support filename mangling for MVC files v2 (fb44d086)
- ffmpeg: Revert the upstream MVC patches (2355b5eb)
- Revert "fixup! [VideoPlayer] Support filename mangling for MVC files v2" (d4175593)
- vcxproj: Sync to master to avoid conflicts (5f28f50b)
- fixup! rbp: Support zero copy interface with hevc acceleration (95b9b8e8)
- kernel 4.4.y:
- DT: Add overlays to configure I2C pins (7e5b6875)
- Added: [env] patch: Bump libbluray - include MVC support
(2016-03-04, 01:40)Milhouse Wrote: [ -> ] (2016-03-03, 21:44)opeters Wrote: [ -> ]Since I use DVBLink.. when will it be available again (#215 "stop building pvr.dvblink and pvr.dvbviewer") ?
That’s unfortunate. Can’t use another backend since only DVBLink works with my current AnySee tuners.
A new dual tuner with CI interface will cost me 200 euros.
As a paying customer I will contact DVBLogic and ask them to get back on track with KODI.
Any 3D fans please test latest version. This has 3D support in libbluray, which means things like audio/subtitle track names should work, and hopefully fix issues with choosing the right files with Pixar movies.
Report if anything is fixed and if anything new is broken.
(2016-03-04, 09:34)opeters Wrote: [ -> ] (2016-03-04, 01:40)Milhouse Wrote: [ -> ] (2016-03-03, 21:44)opeters Wrote: [ -> ]Since I use DVBLink.. when will it be available again (#215 "stop building pvr.dvblink and pvr.dvbviewer") ?
I could be out of place here but maybe this would be the time to switch to TVHeadend?
(2016-03-04, 13:23)popcornmix Wrote: [ -> ]Any 3D fans please test latest version. This has 3D support in libbluray, which means things like audio/subtitle track names should work, and hopefully fix issues with choosing the right files with Pixar movies.
3D MVC MKV dit not work. Movie was playing in 2D. 3D ISO did work however. This was working in the build before. How is 3D MVC detected?
(2016-03-04, 16:41)pappaganush Wrote: [ -> ]I could be out of place here but maybe this would be the time to switch to TVHeadend?
More of a Windows Guy. Was using Argus before with the FloppyDTV cards. Recently switched to DVBLink since I couldn't get the AnySee E30 to work on Argus.
Wouldn't TVHeadend work ?
(2016-03-04, 17:44)opeters Wrote: [ -> ]3D MVC MKV dit not work. Movie was playing in 2D. 3D ISO did work however. This was working in the build before. How is 3D MVC detected?
mkv files need to be named correctly (e.g. with .3D.MVC. is filename).
When named correctly they play in 3D. Are you sure yours are correctly named?
(2016-03-04, 18:50)popcornmix Wrote: [ -> ] (2016-03-04, 17:44)opeters Wrote: [ -> ]3D MVC MKV dit not work. Movie was playing in 2D. 3D ISO did work however. This was working in the build before. How is 3D MVC detected?
3D MVC MKV works flawlessly. Files are named with .3D.TAB.mkv
(2016-03-04, 18:50)popcornmix Wrote: [ -> ]mkv files need to be named correctly (e.g. with .3D.MVC. is filename).
I suggest to set hints.stereo_mode at oppening decoder to indicate videoplayer what movie is 3d. I did similar on windows.
Hallo, I had Problem with Build 03032016. Android App Yatze (Kodi Remote). I can not use yatze as remote control. Last time (Build 02282016) Yatze works just fine.
yatze could connet to Kodi (Webserver) but no remote function.
is that problem from yatze or from kodi?
with webbrowser there's no problem with remote function
Sorry or my bad english
