(2016-01-06, 21:09)herrmeier01 Wrote: [ -> ]Yes, unfortunately there is a issue sine #0102. I check each new release and then downgrade again ;-)
Nothing stands out in that build. I'll try reverting a commit each night. Speak up if it works better.
(2016-01-06, 22:17)popcornmix Wrote: [ -> ] (2016-01-06, 21:09)herrmeier01 Wrote: [ -> ]Yes, unfortunately there is a issue sine #0102. I check each new release and then downgrade again ;-)
Ok I will test with next build again. Thanks a lot
For anyone that has installed iperf
iperf has just updated in the OpenELEC 7.0 Unofficial Repository to iperf3 v3.1, which is great news (thanks @lrusak) as the old v2.0.5 version was a bit... flaky.
However iperf3 is not backwards compatible with iperf2, so if you've been using iperf2 on your non-OpenELEC PCs (as the server or client) then you'll need to upgrade your PC version to iperf3.
To install iperf3 on Ubuntu - which still ships only iperf 2.0.5 - I had to...
cd ~
git clone https://github.com/esnet/iperf
cd iperf
./configure
make
and iperf3 can then be run as: ~/iperf/src/iperf3
To complete the installation:
cd ~/iperf
sudo make install
sudo ldconfig
For Windows users, iperf3 binaries are available
here (unverified, download at your own risk etc. etc.).
Great thanks, was hoping for that, didn't have high hopes for it.
New OpenELEC Krypton build #0106:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.0-rc8 #1 Wed Jan 6 21:33:46 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Jan 6 2016 20:11:41
Copyright (c) 2012 Broadcom
version 96fc00e9b8d219db428a0e7729cab3d4f766f6ff (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160106213255-#0106-gbcd8e12 [Build #0106]
# vcdbg log msg 2>&1 | grep DTOK
001736.979: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (bcd8e129,
changelog) and tip of
XBMC master (0fa5acec,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (2f625959, ahead +40)
- Includes latest libnfs master (6f4ff862, ahead +27)
- Includes latest p8-platform master (cce6a497, ahead +10)
- Includes platform master (a1e59058, ahead +8)
- Includes latest addons: adsp.basic (cb56e0eb, +4), adsp.biquad.filters (d63d8ac6, +6), adsp.freesurround (08b691d3, +1), asplib (2fac1bf3, +2), pvr.argustv (373f3eec, +3), pvr.demo (c6633579, +1), pvr.dvblink (8416b6eb, +2), pvr.dvbviewer (97f7865f, +3), pvr.filmon (97531a74, +1), pvr.hdhomerun (defd3358, +4), pvr.hts (a0503d6d, +23), pvr.iptvsimple (85a31ca5, +1), pvr.mediaportal.tvserver (636cc7ed, +1), pvr.mythtv (b2e23e9a, +3), pvr.nextpvr (13e5360f, +1), pvr.njoy (f0c8e8e2, +1), pvr.pctv (393c5a04, +1), pvr.stalker (b6e96ee9, +1), pvr.vbox (b8f8bb78, +1), pvr.vdr.vnsi (a10e192f, +2), pvr.vuplus (8e6931a9, +1), pvr.wmc (1d6cedf1, +1)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Exclude [env] libcec-01-add-repeating-keypress.patch: Already merged upstream
- Exclude [env] libcec-02-fix-crash-on-some-systems.patch: Already merged upstream
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] compare: Disable Tearfree & Triple Buffering; Bump Intel video, include completion signal
- Include [env] compare: EGL/4K/HEVC, Use Limited Range by default, bump xf86-video-intel; linux cleanup
- Include [env] patch: Add p8-platform package
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4500: kodi: update to 17.0
- Include [pkg] patch: Fix libcec RPi platform detection (libcec)
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
Build Highlights:
- New firmware
- Fix crash caused by PR:8080 (reverted in #105b)
- New VideoDB schema v102 (Note: drop any existing MyVideos102 database created by #0105)
- Fixed build issue with Confluence package that hadn't been updating correctly since #0102... my bad.
Build Details:
- Firmware (Jan 6):
- firmware: gencmd: Add methods to set and get arbiter priority settings See: link
- firmware: hdmi: Provide a hacky way to boot with hdmi output disabled. See: link
- firmware: platform: allow avs to use a second ring osc. Cache more ring osc values on startup
- firmware: arm_loader: Load touchscreen overlay before users overlays
- XBMC:
- [FileBrowser] - fixed credential disclosure when adding network location (PR:8768, 1 commit, 1 file changed)
- drop obsolete libmpeg2 (PR:8687, 3 commits, 138 files changed)
- fix to use the selected player after PR 8525 (PR:8764, 2 commits, 4 files changed)
- Fixes for rating (PR:8771, 1 commit, 2 files changed)
- [TVOS] - make depends arm64 and tvos aware (PR:8737, 24 commits, 32 files changed)
- cleanup (PR:8772, 6 commits, 8 files changed)
- VideoPlayer: fix and cleanup ffmpeg sw deinterlacing (PR:8773, 1 commit, 4 files changed)
- FFmpegImage: Fix Orientation of image (PR:8780, 1 commit, 1 file changed)
- GUIInfoManager: Move SetCurrentItem into a background job (PR:8766, 1 commit, 2 files changed)
- Fix broken DXVA deinterlacing (PR:8770, 2 commits, 5 files changed)
- newclock5:
- New commits in this build:
- stereoscopicmanager: Ensure we don't have a stale value of videoplayer stereoscopic mode (e092c8e0)
- Revert "[mmalcodec] Don't send zero sized extradata" (b5c36922)
- threads: fix waitforever when using CSharedSection (014a18e4)
- Commits no longer in build:
- FFmpegImage: Fix Orientation of image (8a12d435)
- GUIInfoManager: Move SetCurrentItem into a background job (7124c1ff)
- [stereoscopicmanager] Ensure we don't have a stale value of videoplayer stereoscopic mode (c44774de)
- kernel 4.4.y:
- BCM270X_DT: Restore alphabetical order to overlay README (18cb8dcb)
- SQUASH: fdt: Remove stray brace in CONFIG_CMDLINE_EXTEND support (e2c2072d)
Not tried music files added to library in a while, with build #0105b I thought I would try a small single figure number of existing albums (FLAC) that were already on PI in standard Music Folder but never actually added into music library. Whilst requested files appear to get loaded to library correctly and additional options appear within Kodi interface with expected meta-data when drilling through options like when Videos are first loaded into Video library.
I was surprised I was unable to play the files from music library options, as they all play fine when read directly from the folder?
Additionally had a couple of (unrealted?) kodi crashes this afternoon/evening?
Recent Kodi log which includes a number of crash reports
http://pastebin.com/BU8TrazZ
Hope log info is useful.
popcornmix
Build #0106 still has the audio problem.
Is "Revert "[mmalcodec] Don't send zero sized extradata" (b5c36922)" for testing? Thanks you again. Maybe we have more luck with the next one ;-)
Missing channels issue resolved in #0106, channel tuning speed greatly increased as well. Great work.
(2016-01-06, 23:57)Milhouse Wrote: [ -> ]For anyone that has installed iperf
Looking at my add-ons, I have iperf 7.0.0 (unofficial.addon.pro) and via
#iperf -v I still show
iperf version 2.0.5 (08 Jul 2010) pthreads
I am running build #0101
(2016-01-07, 00:34)MikeKL Wrote: [ -> ]Additionally had a couple of (unrealted?) kodi crashes this afternoon/evening?
Recent Kodi log which includes a number of crash reports http://pastebin.com/BU8TrazZ
These crashes all seem to be SQLite related, specifically when querying PVR details - I'd suggest deleting the TV29.db and EPG11.db files.
(2016-01-07, 02:01)J_E_F_F Wrote: [ -> ] (2016-01-06, 23:57)Milhouse Wrote: [ -> ]For anyone that has installed iperf
Looking at my add-ons, I have iperf 7.0.0 (unofficial.addon.pro) and via #iperf -v I still show iperf version 2.0.5 (08 Jul 2010) pthreads
Can you try forcing an addon update ("Check for updates" in the blade menu).
I did that, no change, 7.0.0 seems to be the latest version and installed. reports iperf 2.0.5 via cmd line
I did not uninstall and reinstall however.
