2016-02-02, 16:34
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146
2016-02-02, 17:43
(2016-02-02, 02:25)Milhouse Wrote: [ -> ]I'm able to hit a stable 600MHz with the following and this new firmware (your mileage may vary):
The increased sdram bandwidth is a benefit with HEVC playback, particularly at 1080p.Code:sdram_freq=600
over_voltage_sdram=5
sdram_schmoo=0x02000020
Hi Milhouse , I wanted to consult you if it is modified the SDRAM can cause significant increases in temperature ? . In my RPI2 , I do not have sink or fan , so the query. Thank you!.
2016-02-02, 18:48
Please add support for BD J Menu
2016-02-02, 18:57
(2016-02-02, 17:43)zequiqac Wrote: [ -> ]Hi Milhouse , I wanted to consult you if it is modified the SDRAM can cause significant increases in temperature ? . In my RPI2 , I do not have sink or fan , so the query. Thank you!.
If temperature gets too high, you will see a red square in top right corner and overclock will be disabled.
As long as you don't see that you should be fine.
2016-02-02, 19:00
(2016-02-02, 18:48)movie78 Wrote: [ -> ]Please add support for BD J Menu
That would be a general kodi feature request.
Best to follow this thead
If that becomes stable, and a PR is submitted we'll include it for testing.
2016-02-02, 19:51
(2016-02-02, 18:57)popcornmix Wrote: [ -> ](2016-02-02, 17:43)zequiqac Wrote: [ -> ]Hi Milhouse , I wanted to consult you if it is modified the SDRAM can cause significant increases in temperature ? . In my RPI2 , I do not have sink or fan , so the query. Thank you!.
Excellent Popcornmix!! That was my fear, now I'll give it a try. Thank you very much for the excellent work carried out, this is amazing!! .
2016-02-02, 19:55
For the record, any temperature increase as a result of sdram overclock has been negligible.
2016-02-02, 22:10
With 0201 the picture is frozen upon Start of pretty much every file.
You see the first frame and have no audio.
Opening the info menu it looks like it is paused (current play time stands still)
Once you skip forward or backward everything starts playing fine.
It also seems as if the file was playing in the background. If watch the frozen screen for example for 30s and then skip 10s forward you will end up at 40s playtime, even though the current play time was stuck at 0 all the time.
2016-02-02, 22:41
(2016-01-04, 17:42)niwa2 Wrote: [ -> ]Hi, i started using a PI2 with the #1203 build and a couple of things have bugged me since:
1) with 3D MVC iso files there is no language information for the audio streams and the subtitles --> i have already reported this in the old Kodi 16 thread. As i understand this is due to not using libbluray in this case and fixing this is not trivial at all. Is this beeing worked on?
I'm with niwa2 that this is really annoying - I think it might not be a problem for users that want the english language that is usually the first in the list - but in case you prefer to watch a movie for example in german it's getting complicated.
As there are no language names available Kodi can't select the proper track from the beginning, so you need to wait until something is spoken and next have to try one audio stream after the other because you also don't know which is the right one.. you can only listen if the spoken language is the supposed one
Would be great if we could get language names again.
The same problem is also available for subtitles - they are also all labelled 'Unbekannt' (unknown).
2016-02-02, 22:56
2016-02-02, 23:03
One last question for the moment: 'Enable Full HD HDMI modes for stereoscopic 3D' is activated in my settings - but my screenshots all look like top/bottom and the final picture size is only 1920x1080 although I expected them to be 2 times this size. (I've created the screenshots with the ssh command 'texturecache.py screenshot')
Is this correct as it is?
On the screen everything looks perfect
2016-02-02, 23:25
(2016-02-02, 23:03)nalor Wrote: [ -> ]One last question for the moment: 'Enable Full HD HDMI modes for stereoscopic 3D' is activated in my settings - but my screenshots all look like top/bottom and the final picture size is only 1920x1080 although I expected them to be 2 times this size. (I've created the screenshots with the ssh command 'texturecache.py screenshot')
What does "tvservice -s" report when playing 3D video?
2016-02-03, 02:59
New OpenELEC Krypton build #0202: RPi / RPi2
(Supercedes previous build)
Based on tip of OpenELEC master (476db3ce, changelog) and tip of XBMC master (20ab7bd2, changelog) with the following modifications:
# uname -a
Linux rpi512 4.4.0 #1 Tue Feb 2 23:52:35 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Feb 1 2016 17:54:49
Copyright (c) 2012 Broadcom
version b3dc56931507f355d503ea69397778643f7a3dc3 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160202235144-#0202-g476db3c [Build #0202]
# vcdbg log msg 2>&1 | grep DTOK
001749.941: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (0e074384, ahead +139)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (4476f11b, ahead +49)
- Includes latest p8-platform master (38343e0a)
- Includes latest addons: adsp.basic (598900a9, +2), adsp.biquad.filters (71087c48, +1), adsp.freesurround (990fee29, +2), asplib (d8a34587, +8), pvr.argustv (c8f64fd4, +8), pvr.demo (32952941, +8), pvr.dvblink (ff02fe16, +8), pvr.dvbviewer (d10f17c6, +7), pvr.filmon (618594a7, +8), pvr.hdhomerun (41184673, +7), pvr.hts (5eceedaa, +30), pvr.iptvsimple (baaae159, +11), pvr.mediaportal.tvserver (39e89190, +22), pvr.mythtv (da0a6f50, +11), pvr.nextpvr (0c5d81d3, +9), pvr.njoy (13bd96fd, +7), pvr.pctv (ddef4bc9, +8), pvr.stalker (1a3cf911, +9), pvr.vbox (49f16911, +10), pvr.vdr.vnsi (894555c6, +14), pvr.vuplus (b27f0819, +8), pvr.wmc (9b43f0be, +8)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Exclude [env] kodi-995.20-black-screen-when-switching-channels-during-live-tv.patch: Merged upstream
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] f26415ab: libass: bump to 0.13.1
- Include [env] 3a6268c9: VAAPI: Enable EGL
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] 518f5e6f: FFmpeg: Bump to 2.8.5-Jarvis-rc1
- Include [env] 858f6461: xf86-video-intel: bump to 371219c
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: ffmpeg: Drop unpack()
- Include [env] patch: Enable other binary addons
- Include [env] patch: [update] pvr.vuplus (thanks @seo)
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4500: kodi: update to 17.0
- Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
- Include [env] PR:4661: stripping changes
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8822: Implement ignore url options in CFileItemList
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:8923: [GUI] Replace thumb size with images res
- Include [pkg] PR:8937: [guilib] Add animated png support
- Include [pkg] PR:9018: CGUIListContainer: reset scroller position too on GUI_MSG_LABEL_RESET.
- Include [pkg] PR:9034: [mysql]: Fix limited songs query after #8993
- ffmpeg: Revert the upstream MVC patches
- French keyboard layout
- OpenELEC:
- bug fix for http://trac.kodi.tv #16515 (PR:4662, 1 commit, 1 file changed)
- various build fixes (PR:4656, 2 commits, 2 files changed)
- mkpkg_binary-addons: update to include platform (PR:4671, 1 commit, 1 file changed)
- XBMC:
- Make artist count aware of the include compilation artist setting (PR:8978, 2 commits, 2 files changed)
- Remove TestTimeUtils.cpp after 01ba7b80380f2f8af721d0c40388d504a6517b54 (PR:9026, 1 commit, 2 files changed)
- Don't show "* all entries" for widgets (PR:8975, 1 commit, 16 files changed)
- videolibrary: support manually setting dateadded through NFO and JSON-RPC (PR:8872, 2 commits, 5 files changed)
- AE: fix inverted logic on timeout for error calc (PR:9028, 1 commit, 1 file changed)
- [PVR] [guiinfo]: Fix start time and duration for channels with no epg data. (PR:9025, 1 commit, 1 file changed)
- Bump gtest to 1.7.0 (PR:8751, 1 commit, 57 files changed)
- Remove the unused folder tools/rbp (PR:9029, 1 commit, 36 files changed)
- Created french keyboardlayout (PR:9020, 1 commit, 1 file changed)
- [xbmc] Fixes that have come from the migration to vs2015 (PR:8991, 1 commit, 14 files changed)
- pvr.mediaportal.tvserver:
- Timer fixes (PR:34, 2 commits, 6 files changed)
- pvr.vbox:
- Slow startup fix and workaround to channel numbering issue (PR:106, 2 commits, 5 files changed)
- newclock5:
- New commits in this build:
- ffmpeg: Revert the upstream MVC patches (8b6aab00)
- Commits no longer in build:
- Added: [pkg] PR:9018: CGUIListContainer: reset scroller position too on GUI_MSG_LABEL_RESET.
- Added: [pkg] PR:9034: [mysql]: Fix limited songs query after #8993
2016-02-03, 04:09
@popcornmix: I've noticed a regression when playing "Sintel-Bluray.iso" (http://download.blender.org/durian/movies - first item, 1.4GB)
This plays normally using MMAL (mmal-mvc in Codec OSD) up until #0120, but from #0121 onwards it plays at 1 fps with no audio (it gives the impression that it takes about 45 seconds for any video to appear, but I think this is because there's a few seconds of black frames at the start and when played at 1 fps this takes about 45 seconds to play out).
Debug log: http://sprunge.us/feFX - playback is started at 48.974854, with the "Show Blu-ray menu" item selected at 58.677135.core.
2016-02-03, 05:04
Wrong thread - meant to post in the other test build thread :oops:
