Still no luck so far. I just tried to debug this for a few hours more, with no success.
(2013-05-27, 09:15)Millencolin007 Wrote: [ -> ]Do you use the xbmc stable release 12.2 on all your installations or have you installed a nightly build?
Yes, I use 12.2 stable on Mac, Windows7 and Raspberry. Switching to Nightly on raspbmc didn't make a difference, it's a May 03rd build anyway, I think.
(2013-05-27, 09:15)Millencolin007 Wrote: [ -> ]In the unlocked version there is an option to download (make available offline) songs. Check if you can download a song from the server. It will be stored on your sd card in /Music/Artist/Album. Streaming uses the same url.
Indeed - I cannot download any songs. The download notifications in my tablet's top left corner just flash quickly (10 songs takes a second, which doesn't really happen on my network). Also, the playlist I create for the local files, is not created at all.
All my music files are on a Windows Server 2008 R2 shares. Somehow it makes sense that Windows 7 XBMC can access those files ok. But I can't understand why other clients cannot.
First I thought it might be my multipath smb source. Only SMB3.0 can handle it. (I have SMB 3.0 installed on Windows 7.) So, I noticed I can't browse the multipath smb share from Music Pump Remote (using Files tab -> Sources: Music -> share name. When I changed my file source to use only one smb share, I could access the files just fine. So, Samba works while connected to raspberry xbmc, if it really accesses the files directly with smb? ...or does it just represent the path the remote xbmc sends? I can play the files on remote xbmc from the file view, but still cannot download or stream the files.
I use centralized mysql library for all my XBMCs, and I have replicated also the Music file fources locally on every xbmc. I also tried using direct IP address of the file server instead of the friendly name.
If I had to give my best guess, it's still my SMB Share that requires a user account and a password (guest account is likely disabled), and even though music pump xbmc remote can access every aspect of the remote xbmc, the downloading fails because of this. But I have no idea how to go around this... Does the remote client download the files directly using its own SMB connectivity, or does it use some xbmc feature (in which case it really should work) ?
(2013-05-27, 09:15)Millencolin007 Wrote: [ -> ]I tried to stream music from my raspberry pi using a nightly build and it worked.
Can you share more details about your configuration - how do you access your music files, how are the sources set up, what kind of file shares do they use, etc?
