2006-01-11, 01:12
2006-01-11, 02:20
regarding listitems.*
many video db users/skinners have requested listcontrol + db info in a single window. perhaps this could eventually be implimented before 2.0 as well? there has been talk of restructuring videodb into something more music library-esque so perhaps its best to wait till that is complete.
tanks
loto
tanks
loto
2006-01-11, 02:35
ceomr:
1..4 are all fixed in cvs.
will look into the problem with the fadelabels and the toggle buttons.
font colour in numeric dialog is also fixed - i may have change the default disabledcolor, as that may be what's wrong with the toggle buttons (unsure).
keep them coming!
cheers,
jonathan
keep them coming!
cheers,
jonathan
2006-01-12, 00:25
is there a label for showing the selected caption in the listviews and thumbview?
like when you select halo2 game is there a way to show halo2 at the top of the screen?
if so it would be nice if we could have access to a compare function in visibility.
example:
<visible>listview.caption='halo2'</visible>
listview.caption would be the listviews selected items label.
this could open up alot of posibilities!
with a compare function and maybe 2-4 global variables we could assign stuff to for the comparisons. 2-for text and 2 for numbers. these would be assigned in your home xml and would stay the same until changed. this would allow a skin to assign a different number in each xml file and then you would be able to tell what window was previously visible before, or if you are in this window you assign 2 numbers to your variables and then if a dialog box came up it would use those variable for placement. this would allow different placements based off of what window is open. just an idea.
example:
2006-01-12, 02:16
insted of a comparison i think the functionality you desire would be accomplished like this
<control>
<type>image</type>
<info>listitem.thumb</info>
</control>
this would display the thumbnail of the currently selected item. more 'listitem.'s exist including text labels for the currently highlighted item
<control>
<type>image</type>
</control>
2006-01-12, 15:40
you cant do a condition like that.
the info items are listed in the wiki, here:
http://manual.xboxmediacenter.de/wakka.p...infolabels
and the conditional visibility items are here:
http://manual.xboxmediacenter.de/wakka.p...visibility
2006-01-12, 20:26
will you be adding a <shadowcolor2> for the listcontrol or applying <shadowcolor> to the right column?
2006-01-12, 20:31
if i boot up my xbox my buttonscroller works perfect, but if i than do "reload skin" i can no longer navigate.. untill i do a cold boot again. rss is also using the wrong colors... if i use intime="?" or outtime="?" on my home bg's than they don't work so as outdelay="?" for my volume/seekbar... i can only use time="?"... if i use fade effects on my home bg pics, they always fade from black to visible, and not fade from bg to bg.. my skin is a totall mess.
i'm not getting the slide effects to work correct, they always do everything except the thing i want.
buttonscroller must slideout to the left of the screen when player has audio and system idle for 5 seconds... this is what i have :
same for home backs, by normal usage pdm back 1 is visible.. but when player has audio it must fade away and pdm back2 must be visible, that works..but if i then turn off the player it ends up showing no images at all.
Quote:<visible allowhiddenfocus="true">!player.hasmedia | ![player.hasmedia + system.idletime(5)]</visible>
<animation effect="slide" start="-100,0" end="0,0" acceleration="1" time="500">windowopen</animation>
<animation effect="slide" start="0,0" end="-100,0" acceleration="1" time="500">visiblechange</animation>
Quote:<control>
<description>pdm home back 1</description>
<type>image</type>
<id>1</id>
<posx>0</posx>
<posy>0</posy>
<width>720</width>
<height>576</height>
<texture>4x3-main.png</texture>
<visible>!player.hasmedia | ![player.hasmedia + system.idletime(5)]</visible>
<animation effect="fade" start="100" end="0" time="500">visiblechange</animation>
</control>
<control>
<description>pdm home back 2</description>
<type>image</type>
<id>1</id>
<posx>0</posx>
<posy>0</posy>
<width>720</width>
<texture>4x3-main2.png</texture>
<visible>player.hasmedia</visible>
</control>
2006-01-12, 22:58
nuka1195: probably won't bother with <shadowcolor2> - using the one from the normal text label will probably suffice i think? will add tonight.
smokehead:
1. the visiblechange hidden anim wasn't working correctly (would just hide immediately) - this has been fixed in cvs.
2. the visiblechange animation states the "forward" animation (ie the animation to perform on the control becoming visible). i suggest you want start="-100,0" end="0,0". same for your fade tags on the images - start should be 0 (transparent), end should be 100 (opaque). the visiblechange animation is exactly the same as a visible animation, but it also adds a hidden animation the reverse of what you specify (ie start and end swapped over, and acceleration reversed).
3. there is no in* tags. there is only time and delay.
cheers,
jonathan
smokehead:
cheers,
jonathan
2006-01-13, 01:24
pm3 - cityname in weather is overlapping arrows in build from 11 jan.
2006-01-13, 01:31
thanks for the report - already fixed though.
2006-01-13, 04:36
jmarshall...
i got a favor to ask... could pin a topic with the require changes to make the skin complete updated to the current build before the rollover? or point me to the full list of requirements?
i keep reading this thread and i'm have dificultly weeding out the required changes.
thanks,
hades_666
thanks,
hades_666
2006-01-13, 05:01
i'll do my best to grep through this thread and pop them down in one spot. until then, just look through this thread for all my posts
2006-01-13, 05:26
that is what i have been doing... ill continue that way. on a side thought, great jon so far.
2006-01-13, 05:29
jonathan,
are we able to have several items on the <execute> line?
if not, i'd like to request that in v2.0
this would allow some very cool stuff... specifically, i'm thinking of running python scripts with certain triggers.
