Here's an odd issue. Can anyone reproduce it?
If I go to Music > Artist most displayed artists are wrong. The artist artwork displayed in the left field is not the expected artist default or the artist but an album art it somehow picked. It always picks the same one. I would expect that it should display defaultartist.png or the correct artist.
Any way to fix this? If I could substitute an image of my choosing for the randomly picked image, that would be fine.
When subtitle offset overlay is being utilised to carefully adjust/sync subtitles with voices.
Difficult to clearly read subtitles with progress bar and time "played/to be played" overlay, sitting on top of the subtitles.
Also central overlay panel position when using various video playback options, thought it cleaner when it was locked to bottom of screen above parent option.
(work in progress or preferred this way?)
Using milhouse nightly build #1125 on rpi2 at the time.
If RSS is turned on, it seems that the new layout somehow did not leave any space for rss to display without the background making the rss hard to read at times. The V1 has enough space for rss nicely.
(2016-11-27, 01:14)Shomei Wrote: [ -> ]Impossible to clean library.
I tried two options:
1. From Video library settings
2. change directory content to "none" and then: Actions - update library
The only solution right now is to delete file MyVideos.db
KodiSetup-20161126-3067efc-master.exe (26-Nov-2016 15:55)
windows 7 x64
Try this. Do a clean. Reboot. Clean again. Reboot. Clean again. Reboot.
Should be three cleans and three reboot. This works for me on the music library.
(2016-11-27, 18:16)bill_orange Wrote: [ -> ] (2016-11-27, 01:14)Shomei Wrote: [ -> ]Impossible to clean library.
windows 7 x64
Well, obviously library cleaning is broken in current nightly. But is that a core-kodi issue or skin-related issue? Is it a known bug?
duplicated post, deleted content
(2016-11-27, 20:32)Shomei Wrote: [ -> ] (2016-11-27, 18:16)bill_orange Wrote: [ -> ] (2016-11-27, 01:14)Shomei Wrote: [ -> ]Impossible to clean library.
windows 7 x64
Cleaning works for me on rpi2, your sure your going to main settings option?
i.e. Settings -> Media Settings -> Library -> Video Library -> Clean library
(2016-11-27, 22:09)Shomei Wrote: [ -> ] (2016-11-27, 20:52)MikeKL Wrote: [ -> ] (2016-11-27, 20:32)Shomei Wrote: [ -> ]Well, obviously library cleaning is broken in current nightly. But is that a core-kodi issue or skin-related issue? Is it a known bug?
Yes.
Shomei,
If it does not screw up your setup too badly can you try removing your music and cleaning to see if the library/index goes away? I have a rather large library (1.5G). That may have something to do with it.
(2016-11-27, 22:30)bill_orange Wrote: [ -> ] (2016-11-27, 22:09)Shomei Wrote: [ -> ] (2016-11-27, 20:52)MikeKL Wrote: [ -> ]Cleaning works for me on rpi2, your sure your going to main settings option?
Yes.
Shomei,
I don't use music library in KODI,
I've just added a few albums, cleaning doesn't work.
I'm having a problem when I select an entire TV Series from the main menu (Such as "unwatched tv series").
The default behavior is to take you to a screen listing the TV seasons and then episodes. However, I have the library setting -> media -> video -> default select action from the default "play" to "show information"
Therefore, when I select a TV series on the main menu under "unwatched TV series" it takes me to an overview screen of the entire TV series with a synopsis of the series. There is a "play" button on this screen but no way to select a specific episode. Pressing the "play" button displays an error and goes back to the Kodi home screen. Here is my debug log:
http://pastebin.com/uzGxse5A
(Note the comment about connecting to the network location without a username and password. That is OK, I am still able to connect and play videos normally, I only have issues playing back videos as described above)
This is a fresh install of Kodi v17 B6 on Windows 10 running Intel graphics with all drivers up to date. My media is stored on an SMB share (unRaid server).
Hello,
I noticed an error with the option to adjust resolution to video resolution. Interface elements are not properly scaled. The font is too big and top bar is cut off. When I turn off this option GUI elements are ok, but video stutters. I use kodi on RPi 2 with LibreElec alpha-9 (Estuary v2).
Please make the Icon in files section for folders to be a folder and not a square, separate it from a plain file again please.
in 2:17.0~git20160801.0855-alpha3-0xenial it was a folder.
in 2:17.0~git20161202.1733-beta6-0xenial the icon is a square.
This is very useful when scrolling in a big list using the scrollbar to the right.
I know that there is a big icon on the left side, but that only show the element selected and doesn't update when scrolling with the scrollbar.
Unfortunatley I am unable to find the 2:17.0~git20160801.0855-alpha3-0xenial release now, but here are pictures of the 2:17.0~git20161202.1733-beta6-0xenial where I marked the problem.
Here are screenshots of the 2:17.0~git20161202.1733-beta6-0xenial version.
The problem is that it's not possible to tell the difference of a file or a folder based on the Icon.
Folder used to be a "folder icon".
A file is selected in this image:
And then a image with a Folder selected:
Br
eslin
Using estuary on mobile device as well as an Nvidia shield android tv, on the add-on section, install from zip has no functionality, would post a video but no way lol
Sent from my LG-H918
not sure if it is mine side error or a known issue
when i have watched a movie or serie it is not marked as watched
if i switch to the titan skin it is still not watched however if i watch the episode again with the titan skin it got the watched mark and everything is working fine
device shield TV
version kodi 17 beta 5
(while typing this i figured i need to test a nightly first)
