2018-04-08, 18:56
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
2018-04-08, 20:32
Tomas -
I've been using the skill for more than a month now, and it's been working really well. Love the shortness of the voice commands, especially once Alexa knows you want to control Kodi. Even if I didn't initiate playback using Alexa, one "Alexa, pause HTPC" and from then on "Alexa, pause" or "Alexa, resume" does the job -- just great!
One request: Could you add the ability to turn on/off notifications about Kodi Connect? My setup is mobile, and as a result my Internet connection varies, and this can occasionally lead to a distracting number of notifications about Kodi Connect while watching TV.
Cheers,
Scott
Cheers,
Scott
2018-04-08, 20:45
(2018-04-08, 20:32)benicehavefun Wrote: [ -> ]Tomas -Oh. Sure, I'll try to find the time for that. But generally, it shouldn't be that hard to implement.
Cheers,
Scott
2018-04-08, 20:46
(2018-04-08, 18:56)UnderFact Wrote: [ -> ]kodi connect error, check the log for more informationWhat log? did you forget to attach it?
2018-04-08, 21:08
i cant for the life of me find a log on my media center, usually uninstalling and then reinstalling the addon resolves this issue, but i tried and it didnt work, is there a way i could find the error log?
2018-04-08, 22:03
(2018-04-08, 16:01)tkislan Wrote: [ -> ]I'm able to play videos now, but, I'm still getting locked up when exiting Kodi. Kinda makes the skill a no go for me. Here's my latest log. I'll keep watching to see if this ever gets corrected. Thanks.(2018-04-05, 15:43)bobrap Wrote: [ -> ]Hey. I've found out what the problem is.(2018-04-05, 07:05)tkislan Wrote: [ -> ]Did you enable debug logging? Because I can't see any KodiConnect logs thereSorry about that. Need to leave debug on all the time. Here's my latest log, but, now , again, Alexa says playing "show" on kodi video and nothing plays. However, I can now exit out of Kodi without any problems.
l
Should be fixed in the newest 0.1.13 version. Can you please try it out?
2018-04-08, 22:38
(2018-04-08, 09:16)tkislan Wrote: [ -> ]Hi again,(2018-04-07, 11:17)kotzo Wrote: [ -> ]Hi,Thanks for the feedback, and the log. I though, that I've already fixed this before.
Made all the steps.
You put me also in the email list.
Skill responds to commands:
* Resume
* pause (instead of stop)
* forward XX minutes
Unfortunately play [movie] is not working:
Alexa responds to the command with:
"Getting XXXXXX from Kodi Video" but nothing happens
Regards
But it should be now
Can you try new version? https://github.com/kodi-connect/kodi-con.../readme.md
Everything works know (except the stop error).
Thanks for your efforts.
Keep up the good work.
Kotzo
2018-04-09, 04:12
(2018-04-08, 08:34)tkislan Wrote: [ -> ]For all those that received email about finished Beta testing, Amazon only allows one to run for 90 days.Awesome!!
But I have started a new one, with the new link for the skill:
https://skills-store.amazon.com/deeplink...9292f311cf
Hopefully during this test, I will be able to get the skill submitted, so everyone can just use it freely.
Thanks again. I do love the skill and hope it gets submitted.
For anyone having issues after reinstalling the skill for Alexa: I had to uninstall the addon in Kodi and delete my user data because Alexa thought I had two instances of this skill and asked which instance I wanted the media played on.
Anyway, great skill Tomas!!
2018-04-09, 04:30
2018-04-09, 05:16
it works on the kodi on my pc, but i need it for my tv
2018-04-09, 09:01
(2018-04-09, 04:30)UnderFact Wrote: [ -> ]this is the best i could get when it comes to a log file. this seems to be the only part related to the addon, if you need the full log file, i could probably try and get it some howThanks for the log. This error actually never happened before.
Can you please try newer version? https://www.dropbox.com/s/ts1v9dilj64j0t...4.zip?dl=0
2018-04-09, 09:04
(2018-04-09, 04:12)bigjpayne90 Wrote: [ -> ]I am having the exact problem above, Alexa asks which instance of the skill to use, and then lets me use neither!(2018-04-08, 08:34)tkislan Wrote: [ -> ]For all those that received email about finished Beta testing, Amazon only allows one to run for 90 days.Awesome!!
I have uninstalled and reinstalled the addon in Kodi, and deleted my user data under user data addons kodi connect, but still the skill is duplicated, any suggestions?
2018-04-09, 09:13
(2018-04-09, 09:04)captainfearless Wrote: [ -> ]Well that seems really odd. In my case, I didn't have to enable it again. It just kept working again.(2018-04-09, 04:12)bigjpayne90 Wrote: [ -> ]I am having the exact problem above, Alexa asks which instance of the skill to use, and then lets me use neither!(2018-04-08, 08:34)tkislan Wrote: [ -> ]For all those that received email about finished Beta testing, Amazon only allows one to run for 90 days.Awesome!!
2018-04-09, 09:35
Same here initially, i enabled the new skill yesterday morning and it kept working. Went to use it last night and it was 'kodi video or kodi video'.
No matter what i delete or renistall now , it appears that my Echo sees the old skill and the new one.
2018-04-09, 10:19
Kept on rebooting and re-enabling stuff and now it's working again!!!
