(2018-06-19, 14:02)tkislan Wrote: [ -> ]Stopping doesn't work, but that is an issue on Amazon side.
Does Amazon send separate commands for pause and play/resume? If so, then maybe you can consider a pause command when the video is already paused (ie: a second pause command) to be the stop command.
(2018-06-19, 14:15)badbob001 Wrote: [ -> ] (2018-06-19, 14:02)tkislan Wrote: [ -> ]Stopping doesn't work, but that is an issue on Amazon side.
Yes it does. And yes, that might be a workaround of sort. But I would much rather appreciate, if Amazon would get this right. Because in documentation they do mention a request to Stop playback, they just don't send it through, and instead change it for Pause
Can you please add me also?
I can't PM you. What to do?
Hello!
I would like to also test and use this skill! If you could also add my e-mail address I would really appreciate it!
I will try to send you my data, but currently somehow I am having problems PM-ing people.
Thanks in advance!
Could you add me as well please?
deandjd @
mikeycbd If you can't PM me here, you can find me on reddit (same username), and PM me there.
Has anyone gotten this to work on a firetvcube? I previously tested it fine with kodi on windows but on the cube, it doesn't send the voice commands to kodi but has the firetv interface itself respond.
Hi, i can not see the kodi video skill. I have just started following you. My email is
[email protected].
Good work! Looking forward to test it!
Can you please check my mail in your database? And is it working for amazon.co.uk accounts?
can you pleae add me for testing?
kramf@
amazon.com
