Jester Wrote:Upped Rev17458
just to make sure: ffmpeg-mt is not in svn yet, so it won't be part of every build you make, right?
Upped Rev17515
-Updated keymap.xml
-Changed behavior of the -p switch. Adding it means now to run in portable mode. This will then use the UserData folder within the XBMC folder itself to store all user data.
-libass updates
-Absolute Numbering for tvdb.xml
Think I'll wait until this hanging at the end of playback is completely resolved.
PolliSoft Wrote:Elupus latest fixes on Rev17519/17520 works. My videos no longer hangs!
hangs at end of videos seems to be resolved
waiting to test on a new build
Jest, please compile a video hang 'fixed' build
thx!
Upped Rev17520
- Fixes hangs at the end of video
Jester, I tried your previous build and it made all my movies thumbs disappear (also, it froze when entering Music screen). Tried reverting back to the latest external player build I had previously. Thumbs still missing, now from TV Series as well.
I'm afraid of being banned for bad words if I express my current feelings. I did not use -p, I removed it from all my shortcuts. That is not the problem.
Also, I previously backed up my videolibrary to videodb.xml (it's 6MB which suggests me it does not contain the thumbs, did not check that before. Really useful. NOT).
Christ, I don't want to redownload everything, for crap sake!
Edit: this is not against you, Jester. It's against... I don't know, the world, my being unlucky, don't know.
Edit 2: in my user folder I have 250MB of thumbs files. They don't show. WHY?
ashlar Wrote:Jester, I tried your previous build and it made all my movies thumbs disappear (also, it froze when entering Music screen). Tried reverting back to the latest external player build I had previously. Thumbs still missing, now from TV Series as well.
no clue really, I know the user profile bit has changed (as per my comment on the previous build (check trac) dunno why your thumbs are gone....
Jester Wrote:no clue really, I know the user profile bit has changed (as per my comment on the previous build (check trac) dunno why your thumbs are gone....
It probably has to do with what 17521 fixes.
Quote:http://trac.xbmc.org/changeset/17521
fixed: Removed a stray "u".
Files: 1 modified
*branches/linuxport/XBMC/language/English/strings.xml (modified) (1 diff)
EDIT: Well, it doesn't 'fix' anything, except getting XBMC to actually start. Everything seems to be reset back to defaults tho.
