you need to compile ffmpeg with external libfaad library support. never tried that.
WiSo Wrote:you need to compile ffmpeg with external libfaad library support. never tried that.
Ok, I've got my build environment up and working now. Do I just add "--enable-libfaad \" in the list of configure options? I've tried just doing this and its said that the faad test failed. I'm guessing thats because I haven't compiled it yet. Any ideas on what to do for that?
Hello,
I have one question about new build [22520] in changelog. There is one feature added:
Quote:Added: Directx Rendering for Win32. Work in progress
Does it mean that XBMC will support Graphic Acceleration?
I have Intel Atom 330 and ION based computer (Asrock ION 330) that needs Graphic Acceleration to play 1080i/1080p videos.
Sorry if it is Off Topic and sorry for my English, I am from Slovakia...
Thanks for any answers...
Dominick
this is not from the same branch and its really far from being done for the dxva(direct x video acceleration)
It doesn't mean it will; it just means that using dxva ought to eventually be easier to make happen than it currently is. Whether it will remains to be seen.
Dominick Wrote:I have Intel Atom 330 and ION based computer (Asrock ION 330) that needs Graphic Acceleration to play 1080i/1080p videos.
You can dual-boot your system with XBMC for Linux to get VDPAU graphic acceleration (supposedly the ION does a great job with this). Search these forums for more info. Welcome to the XBMC forums, and thanks for staying on-topic
NS
kay.one Wrote:are you guys putting a hold on daily builds to cover for this http://xbmc.org/theuni/2009/08/31/follow-up-breakage/
if you are please avoid uploading them to XBMCUpdate server to avoid automatic updates.
I am holding off. I won't post a build until a notification that things have been smoothed out.
kricker Wrote:I am holding off. I won't post a build until a notification that things have been smoothed out.
that's good news,
thanks for all your effort.
I try to build from time to time, but at the moment there are build errors and i try to upload only builds that plays videos, at minimum
