2012-03-01, 18:30
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
2012-03-01, 19:23
teefer22 Wrote:springroll: I'm in Canada and I just watched the entire 43 minute episode #1 of the river without issue. I know that doesn't really help you specifically, other than it doesn't seem to be a geo-blocking type problem.
Yes, that was the one I watched without an issue as well.
2012-03-01, 22:23
mrdally204: I will try to add more comments. I tried to be descriptive of the variables so it could be understood.
PatrickBateman: I am planning a little pop up menu with the list of stations that you can click to enable or disable a station by selecting one.
I had a few stations mostly complete so I just put them up. they include GSN, Nickelodeon , Nick Toons, and Teen Nick. they work for full episodes.
I am liking this WB site. It has some good shows.
2012-03-01, 23:10
springroll Wrote:Yes, that was the one I watched without an issue as well.
After watching episode #2, I found the same thing.
I think the problem will get resolved when bluecop gets around to updating ABC because Free Cable is resolving episode #2 to this:
DVDPlayer: Opening: rtmp://abcondemandfs.fplive.net/abcondemand playpath=mp4:/abcvideo/video_fep/mov/riv_102_marbeley_episode_478cffe3-a6ce-43c6-8b22-6ff37cd6783a_4254960_768x432_1600.mov swfurl=http://livepassdl.conviva.com/ver/2.27.0.42841/LivePassModuleMain.swf swfvfy=true
and Navi-X (which doesn't seem to have this issue) is resolving the same episode to:
DVDPlayer: Opening: rtmp://abconline.fcod.llnwd.net:443/a4473/e1/ tcUrl=rtmp://abconline.fcod.llnwd.net:443/a4473/e1/ app=a4473/e1 playpath=mp4:/abcvideo/video_fep/mov/riv_102_marbeley_episode_478cffe3-a6ce-43c6-8b22-6ff37cd6783a_4254960_768x432_1600.mov swfUrl=http://ll.static.abc.com/IMPORT (wiki)/livepassdl.conviva.com/ver/2.8.0/LivePassModuleMain.swf pageUrl=http://abc.go.com/watch/the-river/SH55126546/VD55168730/marbeley?br=1600
2012-03-01, 23:12
WildBill Wrote:The ABC show been doing that to me for a few months so I just watch the ABC shows on Hulu.
Thanks for confirming that it's not a Geo-blocking issue. Whew, good knowing that I'm not the only one experiencing the same issue.
BlueCop - Were you aware of the issue (i.e. ABC shows only play for about 5-10 minutes before abruptly stopping and returning to episodes menu)?
2012-03-01, 23:44
Awesome update bluecop. Here are a couple more fixes for the next time you update:
thewb.py (adding proxy support in two places in this file):
def rootlist(db=False):
xbmcplugin.setContent(int(sys.argv[1]), 'tvshows')
if (common.settings['enableproxy'] == 'true'):
proxy = True
else:
proxy = False
data = common.getURL(BASE_URL,proxy=proxy)
AND
def fullepisodes(url=common.args.url):
xbmcplugin.setContent(int(sys.argv[1]), 'episodes')
proxy = True
else:
proxy = False
data = common.getURL(url,proxy=proxy)
tvland.py (just need to comment out two s1url related lines, this makes hot in cleveland work. I don't believe this has anything to do with the fact i'm using a proxy. I think this is required because hot in cleveland has no season 2 episodes online anymore.):
def hic_episodes():
epoch = str(int(time.mktime(time.gmtime())*1000))
#s1url = 'http://www.tvland.com/fragments/search_results/related_episodes_seasons?_='+epoch+'&showId=25573&seasonId=41909&episodeId=43520'
s2url = 'http://www.tvland.com/fragments/search_results/related_episodes_seasons?_='+epoch+'&showId=25573&seasonId=27283&episodeId=43520'
s3url = 'http://www.tvland.com/fragments/search_results/related_episodes_seasons?_='+epoch+'&showId=25573&seasonId=44996&episodeId=46849'
#episodes(s1url)
episodes(s2url)
episodes(s3url)
Super big thanks if you consider these updates for the next update and as always, thanks for taking the time to update this awesome plugin.
proxy = True
else:
proxy = False
AND
proxy = True
else:
proxy = False
def hic_episodes():
#episodes(s1url)
episodes(s2url)
episodes(s3url)
2012-03-02, 01:51
Hi all...
Having problems with theWB shows...none of them have sound, and they're all pretty choppy. Shouldn't be a problem with the site itself, I was scraping a few of the shows from the old KidsWB plugin, and the same shows were fine there. Any tips/suggestions?
2012-03-02, 01:53
binarybomber: I would need to know much more about the specifics of your setup and logs of the problem.
what do you mean by choppy? playback or buffering?
also specify which videos you have problems with
2012-03-02, 02:05
Just glad to see that BC is continuing his amazing work. Thank you so much for all the time and effort you put into this and all your other plugins.
2012-03-02, 02:23
Thanks a lot for the updates on this, and ESPN3. I'm glad you're back at it!
2012-03-02, 03:05
Hi BlueCop!
I can perhaps send you a log tomorrow (i'm @ work now, and won't be home until later tonight).
My setup is as follows:
XBMC Eden Beta 3 on Ubuntu 10.10...using XBMC boot option, so no GUI is loading to take up background resources. Using Aeon MQ3 skin
Nvidia GeForce 4 MX 440
SoundBlaster 5.1 soundcard, using ALSA drivers
AMD Athlon 2500+ processor, overclocked to 2ghz
The video is choppy, as in it seems the framerate is less than 30fps...somewhere around 20fps is what it looks like, it's not buffering. Also none of the shows, that I played anyway, have audible sound. I have played a couple episodes of Chuck, Flintstones, Gilligans Island, Jetsons, and Looney Tunes...all doing the same sort of thing.
Again, sorry I can't send you the log file as of now...I should be able to look at that early tomorrow morning. Nothing else is acting like this with the other chanels, just the WB...so glad you added it! Just wondering if anyone else was experiencing these issues, or if its only on my end.
I cannot tell you how much I appreciate your hard work on these plugins!!! I have been without cable for over a year now, and wouldn't have been able to do it without the great plugins that you make!
2012-03-02, 06:03
binarybomber,
Here is a little trick to see if its a cpu/gpu issue. Play the video, then on your keyboard press the "o" letter. It will bring up onscreen some extended details such as frame drops buffer and cpu usage. Good place to start, then check out the log file. If you see high CPU usage, make sure you have hardware acceleration turned on in the Settings -> Video.(Windows Vista + and Linux/Live)
2012-03-02, 20:58
Well, not sure what the problem was, but they're all working fine this morning. Must have been an issue with the site when I tried yesterday, as I haven't changed anything...oh well, thanks all!
2012-03-02, 23:12
Wow I am so pleased to see this plugin is being continued BlueCop you are the man mate.
Really appreciate your work.
2012-03-03, 02:49
I have been on vacation for a week but does anyone know if Comedy Central stuff (in particular Jon Stewart & Colbert) broke? I have the hacked version of librtmp and it was working in the previous version of Free Cable.
Trying to figure out if its me or something else. Thanks
EDIT: here is the debug log http://pastebin.com/hxK8SrMf
